Question about NEC MultiSync FE700 17" CRT Monitor
Nec 700 crt
I have an older monitor its a nec multi sync 700+
when booting up the monitor turns on, with the front led green, while booting it turns amber and the screen sounds like its turning off
and stays black, any suggestions
  • Anonymous Jan 18, 2008
    i have an older monitor its a nec multi sync 700+
  • Anonymous Mar 05, 2009
    Mine is similar to the symtoms above but it may take up to one half hour +/- before it comes on. Sometimes we get lucky and we can jump start it by waiting about 20 min +/- and turning the monitor power button off, then right back on followed by pushing the reset button just below the screen. One other difference; we have noted a decided loss of brightness, even though the colors are near perfect. We have tried adjusting both the brightness and the contrast but they are all the way up and no difference.
    Any suggestions short of replacing the monitor?s10sl5q
    savorhes@aol.com
Not a solution at all, but I'll post that I have a NEC MultiSync FE700 monitor that I purchased back in 2001, and have I been using the monitor since that time. Lately the monitor has been showing signs of 'acting up'. I read on the Internet that CRT monitors generally have a working life of about six years. It may be, depending on years of use, that the monitors are just reaching the end of their life.
Posted on Feb 11, 2008
In a move my NEC MultiSync 5FG monitor got disconnected from its BNC cable (5 BNC). Now I don't know which leads connects to which ports. Can anyone help?
The cable should be labeled with R (RED video signal), G (GREEN video signal), B (BLUE video signal), V (Vertical Sync signal), and H (Horizontal Sync signal), so you just have to match the plug to the sockets.
I hope it is clear explanations.
Dec 31, 2010 | NEC MultiSync 5FG (White) 17" CRT Monitor
CRT Monitor power led is green then becomes yellow. The monitor is blank or black. Pls. help.
Signal from Pc is weak and may indficate a failing video card or a loose connection
Aug 02, 2009 | NEC MultiSync FE700M (White) 17" CRT...
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Nec multi xv29 plus.lost the remote front keys disabled
Let me pull up the .pdf...the DIP switch on the back position 3 set to on to enable front panel.
Mar 17, 2009 | NEC MultiSync XV29 (Black) 29 in.CRT...
NEC 17'' Multisync CRT monitor does nothing when turned on
the green is working ok but orange is usually waiting for an input from the pc (no input signal)
Mar 08, 2009 | Computers & Internet
Degaussing a NEC LCD1700M+
LCD type monitors don't use a degaussing coil. Older CRT type monitors used/needed a degaussing coil built around CRT for de-magnetizing.
Jul 20, 2008 | NEC LCD1700M+ Monitor
Doesn't respond
Compaq MV 540 (old dog monitors) DEAD 100% DEAD.
OSD dead too. it seems.
built in year 2000, its 17 years old, and you fix things that old
why> why do that, used LCD can be had for 20 bucks.
why slave over any relic CRT like this,,, for a musiem??
using the VGA cable
the monitor will go to sleep, lacking any PC sync lines Vert/horz
by design per VESA rules on that !
step one , use a PC.
set the PC up to do the max resolution on the CRT
some PC cant do that, (new PC)
im reading your users guide now, 1sec, google , hit.
first force the PC to 1024x768 resolution and 60 vert. refresh max.
now the CRT can work an not any of above number higher .
see? use working monitor to do that FIRST.
now plug in the vga,cable last. on the monitor under test.
power led means
green = power ok
amber or yellow are sleep or standby.
so that means, there is no sync.
or if the OSD works (does it>) turn the silly sleep timer off in the monitor. via OSD .
the operators guide, tells you to go to PC safe mode.
this mode sets reso real low. 800x600 and all monitors work there.
no sleep timer inside monitor i can find.,
lots of ways for any CRT to fail even the CRT itself
(loss of sweep)
loss of cathode video drive
the VGA card inside, can fail. killing dead all cathod drive.
the power supplies or regs inside can fail.
the HV can fail. 10,000 volts (dont touch it if long life is good)
some survive, or fly back hit head on wall and crush skull,
seen it and done it so,,, there you go.(ripped gash in arm once)
the 2nd anode is very high voltage, avoid it, and win,.
respect it.
Sep 20, 2017 | Compaq MV 540 15" CRT Monitor
No picture; power LED blinking amber/green 2-2-2-2...
You can TRY to look for cold solder at the board esp popwer section.
Apr 24, 2008 | NEC AccuSync 120 (White) 21" CRT Monitor
NEC MultiSync FE700 17" CRT Monitor Logo
222 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
