My ac unit is not working properly. It stoped working the other day and we called a HVAC out. He said it was the transformer. Replaced that and put a new stat on. Then in less than 24 hours the thing stops again. Replaced the transformer again. The unit will not work right. The fan blows on the (on) position and the heater part works but everytime we turn on AC it makes a buzzing or humming sound and does not come on. If we leave it like that it will burn out the transformer. We replaced the relay switch and that was not the problem. I went through the wires as best I could to make sure everything was contacting correctly. Then tried it again and it worked.. but then out of nowhere it stoped!! and now it will not come back on just humming . It is getting energized thru the transformer but not turning on and the transformer is getting to hot. so what could be the problem???
  • craftj00 May 24, 2009
    someone said it is the wire that goes from the stat to the outside unit it does have exposed wires have had problems before with the inside unit on and the outside not we tied the wires back together , but we didnt seal them prop. i think the dog that goes under there has made the wires that should be touching touch. he said when this happens that it will cause a temporay short and the inside unit will try to come on but wont and the transformer will burn out. so we should fix the stat wire that runs from the inside unit to the outside unit. does that sound right>>??
  • Dennis Boxerman May 11, 2010
    When you say you replaced the relay, are you talking about the contactor in the outside unit? Let me know and we'll try to get it going.
  • 700 Answers
You are going to have to eplace the contactor inside of the outdoor unit, the coil is weak
Posted on May 24, 2009
  • Todd Born
    Todd Born May 24, 2009
    yes that could fix it to wheere it comes out of the house you can put it into whats called sealtite and tywrap it to the suction line then the dog will have a tough time gettign to it again.
Indoor unit working ,outdoor unit fan and compressor won't start
Tell me more. But first "suspect" is a bad power relay. But are you sure the breaker has not "popped"? 2. 24vac transformer for thermostat signals is out. Does it have power? Could be on the same circuit as the outside unit (condensing unit), or another one that may have "Popped" First one will be a 220vac breaker, the second one will be standard 110vac. If you find a "popped" breaker and it pops again when you try to reset it, you need to call an electrician. Or HVAC technician. Be prepared for the worst.
Mar 12, 2015 | Heating & Cooling
Condenser fan replaced one year ago, fan not turning but can hear motor
the answer to your problem is most likely the motor start capacitor. A AC motor can run in both directions. The start capacitor is used to cause the current to lag behined the voltage which determines the direction the motor will turn. Its posible the start and run capacitors are in one can. so changing one will change the other. However look for a wiring diagram. Do not asume that both capacitors are wired in properly. They may be fighting one another causeing premature failure.
Sep 18, 2012 | Carrier 38CKC036 Air Conditioner
AC Power Failure
Providing that you the outlet is putting out proper voltage, check the voltage output of the plug in transformer. Used a voltmeter set to AC and attach the leads under the plug in transformer (where the wire normally go) and plug back into the outlet. The voltmeter should be reading around 9 volts AC. If there is no a low or no reading, you have a bad plug in transformer. It can be replaced with a 9 volt AC 25 volt amp transformer. Battery may also have to be replaced, if it is depleted. If this does not fix the problem, you have a bad panel and it will need to be replaced.
Jul 26, 2012 | GE Security Simon Xt Wireless Control...
My house was struck by lightning most of all my computers and tv's and phones are no working and my ac is not coming on at all. What happen to my AC unit
Hi and welcome to FixYa, I am Kelly.
The main Preinted circuit board (PCB) most likely has had a failure of the small PCB transformer. This is the most susceptable component (PCB transformer) in the Air Conditioner. Within the last 60 days I have personally experienced the exact same symtom. I replaced the PCB transformer and 1 diode on the main PCB of the air-conditioner and my AC unit is working fine. Unless you can find a source for the transformer your only option is to replace the PCB (Board).
Finding the exact transrformer for the PCB can take a very long time. It iwll look similar to this one: http://www.machsources.com/productimages/9913/pcb-mounting-transformer.jpg
If you have home owners insurance ALL STATE and State Farm often cover this type of damage. It is worth the time to find out if you are a home owner.
Thanks for choosing FixYa,
Kelly
Sep 13, 2011 | Frigidaire FAC085M7A Air Conditioner
Ac unit is working but not enough cold air is cooling off the house how can i recharge it my self
Hello, when a unit is low on refrigerant it is due to a leak, it is best to call a hvac tech out to fix the unit because they have the proper tools to find the leak, pull a vacuum, pressurisze with nitrogen and then recharge.
May 14, 2011 | Heating & Cooling
Having a problem with my AC/Furnace. AC was working fine and was turned on for about 3 weeks. Thursday night it cooled off and we opened up until Saturday morning. On Saturday morning the AC would not turn...
I think your problem is poor usage of the device,i.e. overloading the system. try running better cables to your furnace and ac. The reason i am lead to believe that is. If you already hired a pro to come and fix it for you,and he/she could'nt then what else could it be? in my experience ac units use electricity like microwave ovens.and power tools
Sep 12, 2009 | Heating & Cooling
No power or anything
So I had nearly the same thing, only no intermittent behavior - just alive one day, dead the next.
I took my unit to an electronics repair place. For $25 they diagnosed AC power supply failure and offered to charge me a total of $110 to refurbish the machine.
I balked since we paid far less for the unit on Ebay ($70 or so).
The store gave me the parts list for the estimate though - and I bought the parts and did the work myself. Total another $25 approx, plus time. If you are up for some small electrical work, get a soldering iron, some electrical solder and a soldering wick. You will need, some wire cutters / strippers, and a screw driver too. you may also want a Dremel tool with a cutoff wheel.
Anyway, just replace the first 4 diodes after the transformer leads to the main board and replace the transformer.
The diodes can be from any of a number of manufacturers - mine are Vishay part number 1N5408 - 0827J. The critical part of this part number is the first 6 characters. Put the diodes in using the orientation guide printed on the main circuit board (otherwise risk putting them in backwards).
The transformer part was a Stancor, part number P-8657 - it converts standard wall AC (117V at 50 or 60 Hz) to AC at 12V, 2A. This part is BIGGER than the OEM Hang Fung transformer. I used a Dremel tool and cut out the mounting pieces for the OEM transformer from the main housing. This made enough space to fit the new transformer. Now the new transformer is held in place by clamping action of the two-piece main housing when the screws are installed. I DO NOT KNOW IF THIS IS SAFE, SO YOU ARE WARNED!!!
Unit works fine now. Mouser electronics has the parts and will ship USPS in a few days.
Thanks to VY Electronics, Rochester, MN for diagnostic work.
Dec 14, 2008 | GPX KCL8806DT 7 in. Portable Television
Goodman central unit not functioning
You may be putting the incorrect transformer in. Try to get a OEM from your local HVAC dealer. Which capacitor are you referring to?
Mar 29, 2008 | Heating & Cooling
ALLURE II STOPED WORKING ??
If nothing is working Lights/Motor Nothing, Its the small transformer. Theres 2 transformers. you will see blue and yellow wires coming out of it. I do service calls for broan & Nutone
We have the part: www.inventex.com
Jean-Marc
Mar 20, 2008 | Broan-NuTone Allure II QS230SS Kitchen...
Everything stopped working?
Replace the transformer. Part #R501025 Its the smaller transformer of the 2. It has blue/yellow wires coming out of it.
I do service calls for broan-nutone.
Heating & Cooling Logo
102 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
