Question about Genie Company Vacuums
Can't remove the top to get to the motor
I need to take the top off the motor of a Genie 300PH wet/dry vacuum. there are four screws; two are phillips head and the other two are different. How do I get the two different screws out? I don't have an screw drives that will fit the top of the two non-phillips head screws. Tom
2 of the 4 fasteners on my Genie were TORX head screws with the little round 'blocking post' in the opening.
I acquired a set of TORX drivers which have a hollow center to accomodate these particular fasteners. (Maybe the tools came from Harbour Freight)
The REAL problem is that a new motor seems to cost 2 or 3 times the price of a new wet/dry vac.
Good luck
Posted on Dec 31, 2010
I drilled out the fasteners.
Posted on May 24, 2009
Need filter for a Genie 300PH
Fixya does not sell filters.
Aug 31, 2017 | Filter Vacuums
My genie 10 gallon wet dry vac is hardly picking up any water. what is wrong?
Check the filter in the vacuum to see if it is plugged. Try removing the hose to see if there is better vacuum at the machine. Is there a hepa filter in the exhaust that might be plugged. Hope this helps!
Sep 26, 2010 | Genie Company GV150 Wet/Dry Vacuum
Where can I fet parts for a Genie SV300Q wet/dry
Depending on what parts are needed Home Depot for instance carries parts for these
Apr 13, 2010 | Genie Company GV150 Wet/Dry Vacuum
USE GENIE WET DRY VAC WITH OR WITHOUT PAPER LINER?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The PB15 uses a fairly large pleaded paper filter for dry use, but it is an odd ball, as most of these type filters are held in place bay some sort of plate, and plastic nut. The PB15 uses a filter that has a bottom, and is pressed into place. For wet use, I would see if you can use the foam filter for one of the Craftsman small W/D vacs, like the old 2 gallon model, held in place with a rubber band, which is slipped over the cage with the float ball. It needs to be sealed across the bottom. That should cut down on spray making its way to the motor. The PB15 does have one good feature as the vacuum inlet has an elbow which keeps the water from being sucked straight into the motor intake, so the foam filter should do the job pretty well. I’d also look at the bag and rubber band that is used on some of the smaller Craftsman vacs, which sounds like what has been done on yours already. They are easy to find.
Because Genie no longer makes any vacuums or blowers, and did not keep a parts inventory to support owners of their products (a reason not to buy one of their garage door openers) it might be best in the long run to ‘garage sale’ the Genie, and buy a new vac from a brand that will be around for awhile. I have two Craftsmen, and one Ridgid, besides the PB15, which is going in the nest garage sale, for the above reason.
As far as your blower to vacuum problem -- The hose is moved from the blower outlet, which is the top black piece with the handle and switch, to the hole in the canister for vacuum. The intent of the PB15 was to use the top piece as a hand held electric leaf blower, or when attached to the yellow canister as a vacuum, when you use the hose attached to the canister.
Apr 16, 2009 | Genie Company GV150 Wet/Dry Vacuum
Motor filter replacement
If you are talking about the motor cooling filter round filter like this here then you must have removed wrong screws. Screws that you want to remove are hidden under clear lenses on the sides of the unit. You will need a screwdriver to remove the lenses (2 latches at the top of each lens). Once you have removed lenses you will see screws (4 or 6 - depending on the e-series model). Remove them and you will have the access to the filter.
Good Luck
Aug 26, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Genie Wet/Dry Vacuum replacement part
Hi, you can find genie replacement parts on amazon, click here and take a look: WORKSHOP Vacs Suck It Up Get It Done. I hope this was helpful. Cheers
Feb 17, 2008 | Genie Company GV150 Wet/Dry Vacuum
Manual for genie vacuum
Take the top part off and look at it. there should be some screws around the circumference of the top holding the upper part. remove these screws and the motor/switch section should come off. You'll probably find more screws holding everything else together. the switch fits into an all plastic holder and is more than likely a slide switch.
Sep 01, 2007 | Genie Company GV150 Wet/Dry Vacuum
Vacuums Logo
178 people viewed this question
Top Genie Company Vacuums Experts
Michael Vincent Cruz
richie46
Are you a Genie Company Vacuum Expert? Answer questions, earn points and help others
