Question about Car Audio & Video
Back of unit is getting hot while in use
I installed a sony cdx-gt420u today and the back of the unit is getting extremely hot. i would appreciate ur opinion in why this is
    New Friend:
  • 13 Answers
Check your ground wire. see if it is actually grounded.
Posted on May 24, 2009
Cdx-705
Most cd changes only work with like brands. Sony with Sony .jvc with jvc. Find a manual for a brand new model on google or the the manufacturer and see if it has a problems section
Dec 27, 2013 | Sony Cdx-705 10-disc Intensified Shock...
Subs not responding to Sony CDX-GT500
you cna switch the working rca's to the sub out put to check for sound if u get sound it means your rca's are bad but if no sound then your other outputs in your radio may be deffective
Jun 12, 2010 | Sony CDX-GT500 CD Player
Unhooked the harness in order to install an FM modulator. Now, after plugging back in, I get no power on. Any ideas?
Have you tried resetting the unit? Here is a link to Sony for your CDX-4000X operating instructions. Reference page 6 for the reset proceedure.
http://www.docs.sony.com/release/CDX4000X.pdf
And here is a link for wiring pinouts, fuses....etc.
http://www.docs.sony.com/release/specs/CDX-4000X_Spec_Sheet.pdf
Dec 04, 2009 | Sony CDX-4000X CD Player
Car speakers cut out (no sound) when volume turned up
I would check the crossovers.
If you are turning it up too loud, then the amp may be clipping (into distortion) and this is then setting the protection circuits off in the crossovers.
Jun 16, 2009 | Eclipse EA3422 Car Audio Amplifier
I need to uninstall my Sony 10 disk car CD changer
When removing display from dash make sure you remove ALL proprietary cabling, otherwise your unit is worthless...since the car is junk, do WHATEVER is necessary to remove the cabling....don't beat yourself up if you cant do it as Cd changers are pretty cheap nowadays.
Mar 10, 2009 | Sony CDX-444RF 10-Disc CD Changer
Sony cdx-m610 BIG PROBLEM
yal ever fix them? its the ribbon cable between the face and the circuit board inside the unit the ribbbon cable is very cheap on ebay just google for example cdx-m610 ribbon cable now for the repair close ur face before u take out ur radio assuming u guys still have ur remote to do so theres 3 screws on the bottom of the face when u go to carefully pop the front panel off after pullin them hold ur deck facing down (this will keep ur reset and open buttons from fallin out then theres 4 screws holding in the face's circuit board roll the board out of the face very very carefully pry open the little black lock holding the cable in the connector then open ur radio up pull out the cd player assy same thing with that connector then ull notice the cable goes thru a tension roller pull each end of the cable to unroll it hold it there while removing the cable and sliding in the new one then slowly let go of the roller reattach the cable ends and put everything back together with the face remember its easiest to hold the deck face down those 2 buttons will stay in place hook the top of the face's cover first then put the deck back in ur ride and enjoy these ol sonys r worth a $20 fix specially if they still work good hope this helps yal
Aug 30, 2008 | Sony CDX-M610 CD Player
Sound only coming from one side
you should have 3 leads going into you multi changer, two rca's and one bus lead. power up the unit and remove the first rca cable if the music goes off unplug the second rca and plug the first rca where the second was plugged in, if the music comes back on then the multiloader is working fine and you need to check the radio controller and its connections
Nov 06, 2007 | Sony CDX-646 10-Disc CD Changer
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
