Question about LG VX6100 Cellular Phone
Black screen/no signs of life
Just purchased a refurbished lg vx6100 cell phone, charged battery for 24 hours. will not power on or show any signs of life. battery is new and seems good using test light. box showed signs of water damage (usps) but phone was sealed in bubble wrap, battery too. used vacuum cleaner,blow dryer on low to dry it if there was any moisture in it,still nothing. is there some special procedure to first time start up? it didn't come with a manual. thanks in advance for any tips.
    Problem Solver:
  • 7 Answers
1. Check the battery and terminals of the phone.
2. check the LDI (liquid damage indicator) of the phone. It's in the battery compartment. If it's all white, then something must have happened to your phone--soaked in water or due to moisture.
Posted on Nov 05, 2009
    Problem Solver:
  • 10 Answers
NO THE PHONE SHOULD POWER RIGHT UP... THERE IS NO SPECIAL PROCEDURE TO GET THE PHONE TO TURN ON....... AS LONG AS THE PHONE HAS A CHARGED BATT THEN YOU SHOULD BE ABLE TO TURN IT ON... I WOULD SAY THAT YOU HAVE A DAMAGED PHONE AND IF AT ALL POSSIBLE I WOULD SEND IT BACK TO WHERE I GOT IT IF ITS A REFURB MOD...THANKS
Posted on Sep 19, 2009
My brand new lg transpyre is a black screen. No power at all. Does nothing. Took out battery,pluged it in still nothing. It was working one minute then I took it out of my pocket and it does nothing. Three...
Scott when you plug your Motorola Luge in does it blink or have any sign of life from the light either at the top of the phone or backlight of the screen?
Motorola Support
Mar 02, 2015 | Cell Phones
Lg vx6100 won't turn on or charge
There may be liquid damage present. First using a flashlight, inspect the battery contacts and data/charging socket for green mold/water damage. If nothing unusual is discovered you could disassemble and inspect the inner circuit boards for white residue that would be left behind from water calcium, clean the calcium from the circuit board with a slightly wet toothbrush and dry with compressed air or a hair dryer.
Dec 22, 2013 | LG VX8300 Cellular Phone
Battery dies within 24 hours
Hi, what makes the phone battery to die to quickly, is because the battery cell to weak and almost damaged completely and it's unable to power the phone for too long.
The battery cell is damaged.So you will need to replace the battery with a new battery.
You can go to any phone store around your area and get a new battery to replace the old battery.
When a new battery is is purchased, usually comes with a factory battery life whic is not yet fully charged.You will need to charge the battery for longer hour before use.
After purchasing a new battery, make sure you take time out to charge the battery properly for about 4 to 6 hour before use,otherwise battery cell can go flat again in no time.
Hope that helped.
Thanks for using fixya...
Jan 16, 2011 | Samsung Convoy Cell Phone
Battery & charging Problem on my LG KS360
Is the phone still under warranty? if so I would take it back to be replaced. It does sound like the battery is bad if loosing power that fast. You can overcharge the battery and that will lessen the battery life.I've done that before.
My LG VX9600 I'm able to change the screen settings for when it is charging, maybe yours was changed somehow, check your Settings & Tools / Display Settings. I hope this helps.
Aug 14, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
My nokia 9300 is dead, i received a phone call and while i was talking i got the low battery message and then it went off, i tried to turn it on again, it is dead, the nokia logo appears for few seconds...
1. let the battery fully discharged without connecting to power supply,
2. remove memory card
3. remove battery
4. remove sim card
5. insert the sim card
6. do not insert the memory card
7. reset the battery
8. connect to power for charging for 24 hours
9. switch on and it will work
inamul@hudaz.com
+91 94350 62943
Jul 13, 2009 | Nokia Cell Phones
Vx6100 verizon phone screen white after charging
open the back cover of the phone and reconnect the flex to the pcb.
Jun 25, 2009 | LG VX6100 Cellular Phone
LG VX6100
I was able to get mine to work for about ten to thirty mins with a new battery and using a toothpick to spread the charger port parts. The flat one with two notchs away from the black with the gold contacts. GENTLY press toothpick (nonconductive) against the two notchs part and GENTLY wiggle it away from the other. It took 5 snatch sessions to get all my stuff off. I used the battery that came with my LGvx8100 as they are the same. DO NOT CHARGE THE new BATTERY IN THE 6100.
Oct 01, 2008 | LG VX6100 Cellular Phone
My screen is blank it doesn't show anything
If it is a recent purchased phone, it would be best to leave it on charge for a while, after which you can switch the power button on. This should enable you to use your phone, hassle free.
Apr 20, 2008 | LG VX6100 Cellular Phone
Correct procedure for charging battery
read da manual which cms wid da battery on hw lng 2 charge it wen newly purchased. charge wen battery is cmpltly drained.smtimz it may refuse 2 chrg so get a universal charger nd alwz use it 2 crg
Sep 06, 2007 | LG enV VX9900 Cellular Phone
LG VX6100 Cellular Phone Logo
146 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
