Question about Samsung HLR5067WX 50" Rear Projection HDTV
Loud whirring. Not the fan.
Sometimes my set starts whirring for no reason while watching it.   When I turn it off it sounds like a playing card in bicycle spokes as it slows down.  The sound usually starts off soft then becomes louder.  Sometimes it's so loud it's hard to watch my program.  I removed the back cover and looked around and it's not coming from the fan.
    I have smacked the back of my tv in frustration --- and it helps!  But after a period of silent running, anywhere from a few hours to all day, it starts whirring again. While hitting the back of my tv is a successful short term fix, and somewhat satisfying, I need a more long term solution.
Please help,
Thank you
  • terrydennehy Oct 21, 2007
    I believe my cooling fan is functioning properly.  The noise I'm
    complaining about is much, much, much louder than a normal  whirring
    fan noise.  Unless the fan is rubbing against something and stops
    rubbing when I hit it, and I don't see how that's possible, it can't be
    the fan.
        There must be another component in my tv set that spins and
    randomly starts rubbing up against something and stops when I smack the
    set besides the fan.
    Thank you for trying.  Any more ideas?
  • terrydennehy Oct 28, 2007
    PROBLEM SOLVED!!
    There are only two moving parts in my TV.  The fan and the color wheel.  It turns out that samsung DLP televisions are notorious for color wheel problems.  I found this website very helpful and plan to replace the color wheel myself.http://www.jangro.com/a/2006/07/24/samsu...
    Genius:
  • 1,694 Answers
Noisey, intermittant color wheel?? part of light engine assembly.
Posted on Oct 25, 2007
  • 4,889 Answers
The fan noise is normal on this set. The lamps are cooled via this method. Your users manual explains this issue..and it is the fan as you can see it slows down after the tv is switched off..
Posted on Oct 20, 2007
  • 1 more comment
  • eagle338
    eagle338 Oct 20, 2007
    They start spinning as soon as the temperature reaches a certain point..Thats why it is loud...The fan speed also depends on the temperatur thats why its louder sometimes...
  • eagle338
    How ever if you think its too loud you can get it checked with the showroom guys..But from what i have seen so far the fan noise is louder than that of x-box!!!And i do agree its disgusting!:-(
  • eagle338
    eagle338 Oct 21, 2007
    OK i will find it out and let you know..
The sound on my emerson isn't very loud while watching tv or movies, but is extremely loud while playing video games
There could be a setting on this model in the menu to set the type of scene you are watching...like movies, sports, etc. Sometimes these settings will affect the sound. Also check all that is included in your sound menu. Test each setting in the sound menu.
Jun 12, 2011 | Emerson LC320EM9 32 in. LCD HDTV
My rca hd61lpw42 is having trouble. there is the loud whirring noise, and the whites on the show i was watching distorted and then the screen turned off. is the issue with the color wheel or the lamp?
it sounds like the lamp or fan. do you feel airflow? Unplug the set and wait. When you plug it up is the whinning imedate. the color wheel generally is the first thing to come on. If it dosent reach speed it will shut down
Oct 31, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
Desktop computer fan runs constantly
Desktop fans do run constantly, you cannot avoid this.
The reason they get loud is because there will be a build up of dust on the fan blades.
To rectify this problem turn off the computer and remove the power cord from the rear. Then you need to remove the side panel from the base unit to expose the motherboard.
You will see that inside the case it is full of dust. Look at the CPU fan (the fan on the motherboard) also take notice of any case fans too, they are at the back.
To clean the fans and the case you can use a clean dry paintbrush or compressed air.
Once the inside of the case is cleaned you will see a noticeable drop in noise.
Regards.
Jul 03, 2010 | HP Compaq Presario SR2150NX PC Desktop
My Galaxy NVIDIA Geforce 9600 is making loud whirring sound
You can see if the fan is getting pluged up with dust. Yes I have seen lots of these do that. You can also take the fan off the card and clean it. or replace the fan..If you are having trouble already with gaming it is because the card is getting way to hot..
Feb 24, 2010 | Nvidia GeForce 9600 GT,, PCI Express...
Loud Fan and Slight Overheating
most likely sounds like your hard drive. Mine did the same thing starting that loud whirring noise and overheating a lot. i took it into geek squad at best buy and it cost 199.99 for the diagnosis of the problem and the repair ( if you want just a diagnosis its 69.99) and then had to buy a hard drive ( i went for the 320 GB for 109.99) and they installed it for free same day in and out. took the whole process about 5 hours on a friday afternoon.
Apr 19, 2009 | Toshiba Satellite A135-S4527 Notebook
Loud whirring noise from home theater receiver
Sounds like a cooling fan is worn out. If the warranty has expired, remove the cover and there should be a cooling fan. Remove the fan. Try cleaning it out with a can of compressed air. If this does not work take the fan to best buy or circuit city and buy a replacement. I hopet his solves your problem!
Jan 09, 2009 | Samsung HT-TZ512T Theater System with...
Loud whirring noise when mains switched on but PC still off
Most likely worn bearings in the fans.
If that's the case, replace the fan/s.
Jan 23, 2008 | Dell (S423) for Dimension 8100 (3F546)...
GE SidexSide PSS26SGPASS Makes Humming Noise
GE refrigs have a variable speed evaporator fan motor that is controlled by a computer board on the back of the refrig. now the noise you are hearing is most likely the fan motor ramping up and down in speed (some of my customers say it sounds like a ghost). if its a continuous ramping up and down then the speed cotroller on the board is bad and must be replaced. if its just an occasional sound then thats normal and nothing to worry over.
Btw the reason the noise stops when the door opens is because the fan shuts off when you open the door.
Dec 19, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirring noise. No other problems.
Sounds like you have a noisy color wheel. Very common on all Samsung DLP`s. The part # is BP96-00250A for model HLN5065W.
Oct 16, 2007 | Samsung HLN5065W 50" Rear Projection...
Samsung HLR5067WX 50" Rear Projection HDTV Logo
502 people viewed this question
Jerry Greenberg
Jerry Greenberg
