Question about Hayward 100,000 BTU Pool Heater H100ID1 - Above Ground
The pilot light won't come on
The pilot light on my heater won't come on
    Champion:
  • 246 Answers
Make sure the gas is open if is check the pilot must need to be clean or replace.replace the gas valve must be bad
Posted on Aug 19, 2009
  • Florinda Ramirez
    Florinda Ramirez Jan 06, 2014
    so if i changed out the thermocouple,and i get a strong spark from the igniter,but pilot wont light at all,could it be gas valve?and if so ,where is it located,?and is it hard to replace it?
Pilot light wont light
Rita, Check the attached links,instruction and guides to trouble shoot pilot light, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Gas Heater Pilot Light Troubleshooting
What to Do if Gas Furnace Pilot Light Won Stay Lit DoItYourself com
Furnace Won Ignite Why and What to Do
Aug 03, 2016 | Heating & Cooling
Pilot light won't stay on
Dust gets inside the pilot safety during the months when it is not in use. Blow out the pilot safety without disturbing the flap. and retry.
ODS VENT FREE HEATER TUNEUP
Nov 12, 2012 | Empire ECS HearthRite HR18MN Heater
Delonghi Superser won't light there is gas getting
Clean pilot first see if it lights if not you could change thermocouple
Apr 03, 2012 | DeLonghi Heating & Cooling
My water heater won't light. The pilot light works. But, when I try to swtch the pilot to regualr, the flame goes out.
You probably have a defective thermocouple. The thermocouple sits in the flame of the pilot, and the heat generates a small electrical current conducted back to the gas valve, keeping the pilot gas line open after you switch it to the "on" position. That's why you have to manually hold the gas valve depressed (on) during lighting in the "pilot" position, allowing the thermocouple time to heat up enough to generate its current. A defective thermocouple will not generate the holding current.
Jan 06, 2012 | Heating & Cooling
Sterling RF-45 Pilot light comes on and the burner won't fire. The pilot goes out and fan keeps running.
clean pilot check flame sencor is clean , jump high leval limit first see if it lights , if not try low limit , check thermocouple is tight if fitted ,
Sep 24, 2011 | Sterling RF45 Propane Gas Heater (45,000...
I can light the pilot and the burner will come on, but it won't stay lit. I bought a new pilot assembly and installed it. the burner and the pilot light still won't stay lit. This is the unit that...
Most gas water heater problems can be solved by having service technician perform yearly maintenance. Or by doing maintenance yourself.
This maintenance includes cleaning burner parts and combustion chamber, checking gas pressure and supply, bleeding air out of gas line, checking vent draft, making sure air supply is adequate and not exposed to chemicals, cleaning air intake. Also adjusting flame sensor so it is positioned correctly. If water heater is connected to electric circuit, the outlet must have correct polarity.
You can get gas to appliance indicates the gas control valve and water heater are not locked out. But the gas control valve thermostat can still be bad.
Open following link for illustrations, typical service manuals, and maintenance information, and images of gas control valve thermostats.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Jul 20, 2011 | Reliance & Pilot Assembly for Natural Gas...
Pilot will light after 30 seconds when you try to move knob to on position the pilot goes out and heater won't ignite.
You need to replace the thermocouple.
When you light the pilot it is supose to heat the thermocouple.
the thermocouple produces a small electric current which allows the gas valve to open and keep the pilot going. and allowing the main burner to come on.
Jun 21, 2011 | RTO Atwood Water Heater - 6 Gal LP
Williams debonair wall heater + pilot light problems
THE flame from the pilot should shoot past the thermo-couple and heat this up and make a small amount of mili- amps to prove the pilot light is lit. ..So if the flame doesn,t go past the thermo-couple it won, make mili-amps or its tme to change out the thermo-couple, They only cost lest than $8:00 and you can change it!
Dec 22, 2009 | Williams 3003622 Ceramic Wall Mounted...
Open Questions:
See all Hayward 100,000 BTU Pool Heater H100ID1 - Above Questions
Hayward 100,000 BTU Pool Heater H100ID1  - Above Ground Logo
162 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
