Question about Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television
Panasonic PT-50DL54J DLP TV service mode - Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television
SOURCE:
SOURCE: Panasonic PT-50DL54J DLP TV Flashing Light
I had the same problems that most of you have been having, tv turning on and off, lights flashing in all different colors, having to unplug tv to reset and all of that good stuff. I noticed that most of the time this would happen once the tv would start to heat up, and I could hear the fan working a little harder. Well I am not an electrician but It was very simple to unscrew the lower bottom park of the tv, where the fan and most of the electronics sit, then I used an oxygen tank ( I work for a medical company ) to blow out all the dust in the tv, ( you can olso use the compressed air use for computer, but if grandma or grampa have some O2 laying around, it works really good, LOL. )and was very surpriced to see how dusty it was, then I removed the MAIN FAN ( you only need to remove three screws, however there's a box in fron of it, which you'll have to remove first in order to get to the fan ). this may sound a little complicated, but trust me it is not, once you have taken the fan off, clean it all the way around ( best to use a clean rag, the compressed air was not doing the job.
long story short, once I cleaned the fan and put it all back together. The TV still didn't work LOL, Just kidding, It has been working perfect for a little over a week.
If I can help in any other way, please e-mail me @ [email protected]
hope this helps.
Posted on Feb 19, 2009
MNfisherman
  • 11896 Answers
SOURCE: I am about to replace a DLP lamp. How do I reset
This all probably comes a couple years too late, but when you install a new lamp, you’ll want to reset the hours on the counter your television has. Doing this will allow you to avoid getting any messages about the lamp needing to be replaced despite you having a new lamp inside your set.
If you need to get into the service menu, you can do so by following these directions:
With power on, hold down VOL minus button on projection display and hold down the PIP or SPLIT button (try both) on the remote simultaneously for more than 5 seconds.
Posted on Jan 31, 2010
  • 50 Answers
SOURCE: I have a Panasonic PT-50DL54J DLP projection TV.
I have similar problems. I removed the back panel and use compressed air to blow out all the dust from all the components. Just remember not to blow into the main fan on the right as that is the one cooling the lamp. I don't know for sure if this is the only problem.
Dust built up caused heat built up on the components.
Posted on Feb 17, 2010
  • 50 Answers
SOURCE: Panasonic PT-50DL54J DLP. power light flashes red
I have the same exact problem. I opened the back panel and used compressed air to blow out all the dust inside. Be careful not to blow into the fan on the right as that will get the dust inside the lamp module. Use a vacuum hose to clean out the dust from all around. This helps a bit. The unit will only turn off after a few hours of use rather than every 5 10 minutes.
I am surprised you still have the original lamp. It is only rated for 10,000 hours.
Posted on Feb 22, 2010
SOURCE: projection lamp timer reset
The others are almost right. You first hold down the minus button on your "TV", then at the same time hold down 0 on your remote. Make sure if you have a universal remote to swich it to TV.
Posted on Feb 27, 2010
Need service manual for panasonic pt-50dl54j
You should be able to download a technical manual from this site.
Scroll down below the cover image and press on Download File link that shows up in about 10 seconds after opening the link.
PANASONIC CHASSIS GN1D PT 50DL54 PT 60DL54 DLP TECHNICAL GUIDE Service...
Aug 28, 2014 | Televison & Video
HI, I GOT PANASONIC DLP TV MODEL # PT-50DL54J, I CHANGE THE LAMP BUT, POWER GREEN LIGHT IS KEEP BLINKING. PL HELP.
On a HP 4266w, Jumper is behind the sheet metal where the cooling fan and radiator is located. You need to remove the three spring screws, fan and sheet metal screws (3), one is deep on the right. Once you remove the clip, holding the radiator, the sheet metal will come off and the dip switch, jumper, is marked. Take the clip off the top and you are ready to go. The radiator clip is tricky to get off as it has a swivel type clip on both ends. I Pushed down one end and lifted the other off.; Take your time. Hope this helps.
Feb 24, 2011 | Panasonic Televison & Video
I am about to replace a DLP lamp. How do I reset the lamp time on a Panasonic PT-50DL54J, using a TY-2004 lamp?
Jan 31, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic HDTV DLP PT-50DL54J does not power up, instead power light flashes red eight (8) times. No repair service near us in rural South Dakota. It will probably be necessary for me to repair myself,...
Hi to all Panasonic HDTV DLP PT-50LC13 owners i have this TV for Repair or Parts. It does,nt powerup i know the fix but i dont want it so is for parts for $100 bucks
Dec 05, 2009 | Panasonic Televison & Video
I have a Panasonic PT-50DL54J DLP projection TV. It suffers from a shut down problem. Shortly after powering up, the TV shuts off, and the front LED flashes red 6 times. At this point, the TV will not...
Nov 15, 2009 | Panasonic PT-50DL54 50" Rear Projection...
MY PANASONIC PT-50DL54J DLP will just turn off. I
I have posted solutions for similar problems.
There may be a heat issue with the power supply components.
Remove the back panel and blow compressed air into all the component area, (except the fan on the right). The power supply is on the left.
Then vacuum all the dust out.
There may be a problem with the battery in the remote. Weaken batteries can cause the remote to send random signals (including turning off the set).
Aug 22, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Resting my lamp?
Hold the Volumn Down button on the TV,
and the MUTE buttom on the remote for 5 seconds.
Jun 23, 2009 | Panasonic PT-50DL54 50" Rear Projection...
How do i reset the hour timer on my PT-50DL54J
TO RESET THE LAMP TIMER PRESS THE VOLUME DOWN BUTTON ON THE FACE OF THE TV AND THE OK BUTTON ON THE REMOTE AT THE SAME TIME FOR 6 SEC.
Apr 25, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic pt-50dl54j
The 3 times LED code points to no fan rotation. There are 2 fans. Check the larger fan first, p/n = FBL12G12LS, located near the lamp. Even though that fan may be rotating, it may be slow.
thanks
scott
Dec 20, 2007 | Panasonic PT-47WX51 47" Rear Projection...
Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television Logo
83 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
