Question about Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated
No air pressure at the hose
Ec12 twin bottle has the gauge which measures pressure in the bottles. Second gauge regulates pressure to the line. It reads 120 and bottle read 120. Plug a tool into the end (bypassing a hose to rule that out) and when the trigger is pressed the needle drops to zero on the line gauge and a small puff of air comes through the tool. Once released the gauge rises back up. ???
Jim in Sacramento
  • 234 Answers
It sounds like you have trouble with your pressure regulator. Make sure that the knob for the regulator is turned clockwise to increase pressure. If this doesn't work, you may need to replace the regulator.
Posted on May 27, 2009
Gauges show 90 psi but can,t inflate car tires past 10 psi
A lot of compressors today have a regulator where the hose hooks on ,Most times there is two gauges on it, one is tank pressure and the second is line pressure, and a knob to twist in and out to increase and decrease line preasure. Air Compressor Line Setup and How to Use Air Tools for Beginners
Mar 23, 2016 | Psi Air Tools & Compressors
Ec12. Runs fine. Tanks fill fine. Just run out of air when using large volume items. i. e. framing nailer, filling tires. Like its taking too long for air to get from tank to end of hose. Almost like there...
You are correct in suspecting the regulator. Easy fix however. Remove the safety pop valve and install a tee fitting. Reinstall the safety on one port and install a quick-connect fitting on the other port. Now you will have access to full tank pressure when you need full power. In the process of regulating pressure, the 1/4 inch port size adjustable regulator will restrict the air volume. A 3/8 port size (larger air regulator ) is less volume restricting however more expensive. You can install a 3/8 port size regulator on your compressor in place of the small one installed now. Other possible trouble areas are too small inside diameter air hose , too long of a hose and air hose that has inner liner torn and is restricting airflow. Good luck
Apr 15, 2011 | Hitachi EC12 Portable Electric 2hp Air...
Sanborn Blackmax B3511 The part that has the gauge on it. This part is a black square about 1.5" square. Off of it is the handle to turn the air off and the hose connects to it. The black square is...
i assume your are talking about the pressure regulator. if it won't adjust to raise and lower the outlet pressure it is broke. you will have to replace it with an in kind type.
Aug 31, 2010 | Hitachi EC12 Portable Electric 2hp Air...
I can't adjust these gauges. How do I do it?
The only part of the gauge that adjust is the tee handle in the middle. the gauge on the left tells you the line pressure to the torch, the gauge on the right tells how much oxygen is in the bottle, usually on a K bottle it is 1800 to 2000 lbs. if you turn the tee handle and the left gauge that tells line pressure does not respond you probably have a bad diaphragm in the gauge. Seek qualified repair man. Thanks
Feb 02, 2010 | Victor CSR350D Oxygen Regulator
I have a Hitachi EC12 Portable Electric 2hp Air Compressor. It builds air pressure fine and shuts off normial. But if I attach a blow nozzle or another attachment to the hose and try and use it, the...
This is a stab in the dark.....but have you emptied the condensation out of the tank? It may reach max pressure....but have little air compressed inside the tanks. Just a guess.
Dec 13, 2009 | Hitachi EC12 Portable Electric 2hp Air...
My hitachi EC12 compressor starts up and fills the two tanks. When I connect my hose, the pressure in one tank drops to zero, then goes back up to about 60 psi, then very slowly builds back up to max...
how do you know one tank drops to zero unless you have a pressure gauge on both tanks sounds unlikely unless you are looking at the gauge on the pressure regulator
Nov 18, 2009 | Hitachi EC12 Portable Electric 2hp Air...
The air tanks fill with air, but the pressure
The regulator sounds like it is cranked closed. Try slowly operating the adjusting knob in the opposite direction. As the valve moves, you should see the pressure rise on your gauge (it probably does work).
Hope this helps....now go make something!
Best regards, --W/D--
Jul 18, 2009 | Hitachi EC12 Portable Electric 2hp Air...
No propane flow to grill using bulk bottle system.
the office that is open on the bottom of the burner sound like a spider has taken home to.. the hole.... This happened to mine. a small pipe cleaner or wire will break it up...try that. also did you feel the top of the tank regulator and see if it has froze. try turning the tank upside down and turn the unit on.... this may also help by forcing the spider debris out.
Jun 05, 2009 | Coleman Roadtrip Grill LXE 9949-750
How do you get refrigerant from the bottle into the air con
hook up the gauges to the large line at the condenser, press in contactor, place ref can in hot water or at least water. the hoter the can the higher the pressue, dont use a torch. with the unit running the will be less than 65 psi at that low sidevalve. Outdoor pressure should be 200-285.
Mar 31, 2009 | Mitsubishi Heating & Cooling
Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated Logo
262 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
