FixYa.com
Tags:
Brother PE-150V Computerized Sewing Machine
Adjusting timing on brother pe 150 embroidery... (by 7 users)
posted by jlarck on Oct 20, 2007
How do I adjust the timing on my machine?  My husband took off bottom plate and tightened the screws that hold the little arm that puts tension on the belt.  It is much better, but the timing is still slightly off.  Any suggestions?  Don't tell me to take it somewhere for repair because there isn't anyone nearby.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
6 Other Users Have The Same Problem
Comment by MJSH, posted on May 17, 2008
Me too! My thread was bunching in the bobbin area, I cleaned it out and tried again... now it is skipping picking up the bobbin thread. I have a Babylock Espree and am very frustrated. I bought it used. ;-( So sad.
Comment by carlesec, posted on May 06, 2008
I have put in 6 needles and mine keeps breaking the needle wouldn't that be timing. carlesec
Comment by Guest, posted on Feb 26, 2008
I am also having a problem with the Brother PE-150. It is my brother in laws machine. The bobbin thread and top threads are not connecting. I took the top plate off and watched while I ran the machine and nothing is moving in the bobbin area. I'm thinking something is very wrong. I would be grateful for any help or suggestions.
Comment by toots5, posted on Jan 20, 2008
i have the same problem. i was sewing and now the thread in needle will not pick up the bottom thread. i would appreciate any help.
Comment by quiltee, posted on Jan 06, 2008
I have changed the needle, bobbin, thread, . Rethread , cleaned the bobbin area. It won't stitch at all. It is an embroidery only machine. I was sewing a heavily stitched item and it jammed. Now it will not stitch. The machine goes on sewing the pattern, but keeps stopping because it's not stitching.
Best Solution
posted on Oct 20, 2007
Helpful (85)
allmakes
Rank:Wiz Wiz
Rating: 84%, 1039 votes
Are you absolutely sure the machine is out of time?  have you tried a new needle ? that is the most common fault, if you have and it is still missing stitches and you are not sewing on a fabric that causes static such as nylon or silk then it is out of time but very rare for that model, try that first and if it is till missing stitches contact me drivewithken@blueyonder.co.uk and I will type up a complete sheet on how to retime it but be aware it may take several attempts, you may need to buy a set of allen keys.
Ken
Rating Locked! (?) jlarck has rated this solution as Helpful
Can you Help with these Sewing Machines problems?
EMP6 Babylock
#4 thread path sews only a few... Answer This...
Not picking up thread from...
My machine is not picking up... Answer This...
Needle bent - thread break...
My wifes PE-150 starts to... Answer This...
will not sew
I messed with the thread... Answer This...
Embroidery arm
I have a PE 150 it was sewing... Answer This...
6 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Nov 09, 2007
Hi, I am having a problem with timing ( I think) on Babylock Espree embroidery machine. Have you gotten help? Thanks, Lind
Repair Service
Find Sewing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
