Question about Dell Computers & Internet
Power up I know my battery wont charge but it has always worked with the charger plugged in, now it won't power up. Also can the sensitivity of the scroll pad be adjusted less sensitive, my fingers are heavy hitting??! My laptop is a Dell Lattitude D800
  • 111 Answers
It sound like the power converter on the laptop may be dead. This knocks the house voltage down to an amperage that can be used by the laptop.
Check and see if the laptop is still under warranty with your service tag at http:\\support.dell.com. If you need any other help, just respond to my post.
Posted on May 24, 2009
Battery wont charge and wont work off power supply vaio vgn cr35g ?
i know they are not cheap but it sounds like you need a new battery. is there a light on your charger? is it still on and the same color?
Mar 20, 2013 | Sony VAIO Computers & Internet
Acer laptop 5551 wont charge
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
Replacement Acer Aspire 5551 AC Adapter 65Watt 19V 3.42A
Feb 17, 2013 | Acer Aspire Computers & Internet
My hp pavillion laptop will not charge my battery . It won't even work without the battery but plugged in with power supply even though i know battery and power supply are sound.
It won't ever be a 'software' issue....it will be either a :
Adapter/Charger issue (Have it tested by local PC repair shop.)
if it is good, then it is the other prob. If it is not good, then buy a new one.
OR
Laptop power connector issue. (expensive repair.)
Sep 06, 2012 | Toshiba Satelitte M300 St3401 Core 2 Duo...
Phone wont charge so will not turn on
Have you tried more than one power outlet? It could be the power outlet you're trying to use isn't functioning. If it won't charge on a different outlet, the issue is either the charger you're using or the phone itself. Try wiggling the charger around while plugged in to the phone, see if that will charge it at all. You should also trying getting a different charger and see if that will work. If not, you may just need to replace the battery/phone.
Aug 14, 2011 | Ericsson Cell Phones
Just replaced batteries and unit is operating good since i installed the battteries and i try to put on charger it says it is in the charge inhibit mode that is according to the flashing lights what does...
All that eans is that when you are charging the batteries you are unable to drive the chair. Its a safety feature to ensure that you won't accidently make the chair move with the charger plugged in. Just plug the charger into the charger port turn off the chair and then plug the charger into the wall charge overnight and in the morning unplug the charger from the wall and then from the joystick. Always have the charger off when plugging ang unplugging from the chair. With the M41 charger get a power strip with an on/off switch plug the charger into the strip and use the on/off switch to turn the charger on and off before you plug it into the chair Hope this helps you
Jun 20, 2011 | Electric Mobility Invacare Pronto M41...
My laptop charge wont charge my laptop
is there charging indicator light on ....... check battery maybe its dry
May 30, 2011 | ASUS Eee PC 1000, 1000H, 1000HA, 1000HD,...
My nikon coolpix camera battery dided and now when i plug it in to the charger it wont charge. is there some sort of reset i can do?
If you haven't use your Nikon Coolpix camera battery for a long time and now there is no power, when you first plug it to charger it maybe show none action. And charger longer it will be well. But if your battery Nikon camera battery are used well these days, and it won't be charge. It means you need a new Nikon battery charger
Apr 29, 2011 | Cameras
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Wont charge
if yuo dont let the battery completely drain and charge before ds wil never again comletely charge up.
Jan 05, 2008 | Nintendo DS Console
Computers & Internet Logo
125 people viewed this question
Alun Cox
