My top half not staying cold both freezer works fine
SOURCE: side by side freezer
Check that the freezer circulating fan is running. The frige section may have dampers or vents (lets the freezer air cool the refer section) that are open too much. Usually the bottom area in the frige has a control lever to meter how much cold air gets to that section (lots for meat, little for fruits, etc.). Check the owners manual for operation of those vent dampers.
SOURCE: bottom freezer not working
Hi, sorry I do not have any advice to offer. We have the same model. Three weeks ago the red light came on and freezer stopped working. Last week the fridge packed up. We may have been unlucky but I thought it might be worth mentioning incase they were related and your fridge gave up as well.
SOURCE: Jenn-air side-by-side: freezer & frig cold on the bottom not top!
It sounds like 1 of 4 things...
1. It could be related to the evaporator becoming Iced over and when this happens it insulates the area iced over and the temp rises...this is caused from the defrost cycle not being activated...(Thermostat, or loose or broken wire)
2. There is a device called the thermistor which senses temp and Ice build up which will cause the unit to go into defrost...this could be bad.
3. The previous fixes may cost a little but not as much as the next which could be a restriction in the evaporator. This is serious and usually requires the replacement of the same...very pricey. Is there only 2 compartment or a pull out drawer for freezer foods..If so you could have an isolated problem in the upper freezer compartment which may be remedied without great cost
If your husband or yourself ..or a handy person can access the back of the freezer by removing the back panel I'm sure you will find either lots of Ice good..as far as cost to repair goes....or no Ice...bad...bad.. as far as cost to repair..the later falls in line with a restriction.
I hope I have helped....please rate me ...The Fang
Remove the back panel from the freezer to verify no ice behind the freezer panel. Look inside the air vent on the freezer panel for ice buildup. Make sure the freezer control is set to minimum not coldest freezer.. Make sure the freezer fan motor is working.
SOURCE: my refrigerator won't stay cool but my freezer works fine
You have something wrong with the vent going from the freezer to the fridge. You probably have a defrost problem and ice is blocking the vent that goes from the freezer and comes out in the roof of the rerigerator compartment. Replace your defrost timer and bimetal.
