Question about OKI C5500n Laser Printer
540 : y toner sensor error
I have an oki c5500. The display is reading 540:y toner sensor error. how can I correct this problem?
    Novelist:
  • 125 Answers
Hi moneybaggz52:
Here is your problem.
Symptom:
When setting up a brand new C5100n or C5300n out of box, a toner sensor error is encountered.
The printer can display any one of the following errors:
543K: TONER SENSOR ERROR
540Y: TONER SENSOR ERROR
541M: TONER SENSOR ERROR
542C: TONER SENSOR ERROR
Cause:
This generally can be caused by two things.
1. The toner cartridge lock lever is not in the correct position.
2. The Transfer Belt lock levers are not in the correct position.
Resolution:
Check the appropriate toner cartridge lock lever (Shown below) and make sure that it is in the correct position.
540 : y toner sensor error - 0.110?openelement&fieldelemformat=gif
CORRECT POSTITION INCORRECT POSITION
Check both transfer belt lock levers (Shown below) to ensure that they are in the correct position.
5.2eea?openelement&fieldelemformat=gif
CORRECT POSITION
10.4086?openelement&fieldelemformat=gif
INCORRECT POSITION
Hopes this helps
Posted on May 24, 2009
Fatal error 983
This error is an "Incompatible toner" error for using non-original Oki toner. The problem is the chip sensor cannot read the chip on the toner. So either the sensor is not working or the toner is defective.
Regards Abhilash How do u rate the service?
Sep 20, 2010 | OKI 9800hdn Laser Printer
Toner sensor error
take out the magenta cartridge. and make sure the edges are clean. There are little metal pieces on the sides where the sensor reads the cartridge. Also, make sure the "lock" on the cartridge is locked.
Jul 22, 2010 | OKI C9300 Led Printer
I just installed a new toner cartridge. I now get
Are you sure that you removed the plastic strip that is used to ship the toner? If so unseat and re-seat the cartridge, and make sure that your installing a compatible cartridge.
Oct 06, 2009 | OKI C5150n Led Printer
Okie C5400 giving 162: Fatal Error
This is a Toner Sensor Error, Color:Cyan
and can be corrected by checking that the Cyan toner lock lever is correctly in position.
Mar 19, 2009 | OKI C5400n Led Printer
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Toner sensor error on an Oki C3520 Laser
Check the little switch/door on the right hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Oct 18, 2008 | OKI Electric Industry C3520 Laser Printer
OKI C7300
Reload the yellow toner and re-seat the drum assy
check for foreign objects under toner/drum assy
make sure toner is locked and drum is seated correctly
also, check the small door on the left side of drum
if stuck closed, gently push open with small screwdriver
Mar 03, 2008 | OKI C5300n Led Printer
Toner sensor problems
On the base of machine after removing drums and transport, there are 4 sets of 3 pins that connect to left hand bottom of each drum, these can get toner on them and not make proper contact, each set of 3 pins just pop out with the help of a flat blade, out of base to be cleaned. in yout case just switch the set under the cyan with another lot from different colour.
I am taking it that you are using genuinne non imported oki drum and toner. If this doesnt fix your problem then you must have fauly drum/toner
Nov 13, 2007 | OKI C9300 Led Printer
OKI C5500n Laser Printer Logo
3,151 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
