Two or three times a week when we try to start our computer it will not start properly. The screen stays black the the Microsoft Corp wording and the green littler scroll going acroos the middle of the screen. We have to shut it down & restart it doing a repair fix or start it normally and then it will start ok for two or three days and then the same thing happens over again. How can we fix it permanetly?
With no more information that what you have provided I would start by reseating the memory and video card if you're not using onboard video. Then I would check the hard drive via chkdsk, run it from a command prompt. If the drive seems ok the next thing I would do is reinstall the OS. If it still gives you trouble after that you have a faulty component (memory, processor, power supply, video card, or mother board) and I would start swapping in known good components.
I have a similar problem:
I have a Compaq Presario SR2010NX desktop computer. Recently, very occasionally, the computer would freeze and the screen would scramble. It almost looks like someone chopped up the picture on the screen. Then we would have to manually shut down the computer and restart. It would always work fine afterwards.
Yesterday the computer did it again. It restarted fine but when my boyfriend tried to install a new mouse the computer froze again and the screen went scrambled. Well this time it did not start back up. I tried to unplug the computer from the wall and restart but that got me to the COMPAQ screen and then the computer froze again and the word compaq was doubled all the way down the screen. We continued to try to start it in PC recovery but it would get the the program and freeze. I actually got it to run once but I couldn't see what it was doing because the screen was scrambled.
Now we have restarted it so many times that it will start up, light turns green, and stays green. The computer sounds like its starting up and it seems louder than normal. The computer doesn't do anything and the screen is black. The lights on the keyboard do not turn on but the light in the mouse does. The CD drive will light up and run as well but nothing happens after that. I can't see the cursor and the keyboard does not work.
I opened the computer up, cleaned the dust off, tried to re-install my old RAM and that did not work either. I disconnected the CD drive but that did not work. Tried to start the computer with nothing plugged in except mouse, keyboard and monitor and that did not work.
I don't know what to do! Help!
Our computer is two and a half years old. We have Windows Vista installed on it. The problem just happens at startup. The screen stays black with the Microsoft logo and the little scroll bar going across the screen. Once we push the button to start it back up and do either the repair fix or have it start normal( that is the two options you have)it work s ok for another two or three days and then the same problem occurs again. We have taken it in to a computer shop and they can't seem to find the problem. Can a modem create this problem?
take out the wireless card on the back MINIPCI slot, see how?
this is possible one.
how old it is? if you only use adapter(take away battery) or only use battery which one appear dark screen? same or not?
