Picture won't come on
My husband touched something on the remote, he's not sure what, & now the tv comes on & off with no picture.
Sounds like he pushed the input select button. It is now looking at the video jacks and not the tuner. A couple more clicks on the input select should get you picture back.
Posted on May 24, 2009
Red light goes on and off
Needs the button put back into place. Look under the cabinet to see if there is an access panel below the switch, would go for all external controls. There would be a chassis with all the controls mounted to it.
Pull the plug before doing any repairs.
Look to see what it would look like in it's normal position. Something has moved out of place that holds the switch to the panel. Very tedious if you have to remove the whole housing.
Mar 14, 2013 | Toshiba 36A43 36" TV
I HAVE SOUND BUT NO PICTURE
Make sure whatever your playing videos from is properly plugged in. iPod touch or iPhone (via HDMI): the iPhones and iPod touches don't show picture, just sound. TV (via Aerial): make sure is plugged in properly. If your TV remote has a Display button on it, press it again so it comes on. Hope this helps. Get back in touch. Steven :D
Jan 01, 2013 | Televison & Video
I havea Sony KV-40xbr800 screen won't turn on red light blinks 6 times, tried plugging directly into wall outlet & no picture still. Any help please ?
Power supply. Disassemble and be careful tv is not plugged in. Check capacitors on power supply for bulges on top. Replace but make sure u deenergize before removal by touching the two poles together. I use a small nail file
Aug 08, 2012 | Sony Kv-40xbr800 Fd Trinitronr Xbrr Wegatm...
Tv has no picture but sound is ok
First of all, change the input device to something you know works for sure. Look for any jammed buttons on remote or on control panel. (This can happen, if you inadvertently sit on the remote hidden under a magazine or newspaper) Check the picture settings to ensure that these are ok. If problem persists, it might need attention by a qualified service technician.
Jul 22, 2012 | Televison & Video
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
Good morning, My tv is only 3 1/2 years old. It just stop working, I changed the batteries in the remote and still won t work, I will try to turn it on, it comes on for about 2 seconds then goes off...
Hi, there must be something wrong in the power supply circuit, usually because of bad or off value components, if the TV actually gets a picture and cutts off, the power supply could be the circuit to suspect, if the tv does not give a picture, it only does the click and the power light turns on but nothing else happens, there could be something else wrong besides the power supply circuit.
Mar 20, 2010 | RCA 20F610TD TruFlat TV/DVD
I have lost the instructions for my jumbo touch screen remote
I was here originally with a problem identical to one posted and found that the best solution posted was only partially working. My husband and I were able to get the tv on but that was the extent of it. Once on the remote was not working. Out of frustration we figured out the that if you practice the exact steps after the tv is turned on,
1 hold the set button untill the red light comes on
2 press what you want to set (tv,vcr,dvd,ect.)
3 press power botton aim at unit and wait until it turns OFF then quickly press ent.
This did it for us and we are now happily watching tv again without having to toss our beloved giant remote into the garbage. Hope this helps!!!!
Dec 03, 2008 | Televison & Video
Remote Worked Until my husband played a video cassette
Change The Batteries and then try reprogramming the remote..
Dec 02, 2007 | Philips PM435S Remote Control
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
