Question about Technics SA-EX400 Receiver
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
Technics SA-GX550 - Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
    New Friend:
Check the power relay RL703, I have seen these with burned contacts cause this problem a few times on this unit. Replace relay or bypass the two normally closed contacts.
Posted on Dec 06, 2012
    Guru:
  • 417 Answers
Try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
Posted on Aug 12, 2009
Same problem with my Sa-Gx350, the overload light comes on after setting the volume higher than 3-4 and it shuts off.. I had it in the shop but they can't seem to find the problem.... Everything works on it exept when I turn the volume up... Please help... ruben6580@live.com Thank you..
Posted on Jan 08, 2012
3 Suggested Answers
  • 4234 Answers
SOURCE: overload protection
Doe this always go into overload independent of the volume level? Try disconnecting the speakers completely and running the set. Does the set shutdown then too?
Thanks,
Dan
Posted on Jan 16, 2009
SOURCE: I have a Technics SA-gx550 receiver and it i turn
wich is low imp in my technics sa-gx550 please tell me?
Posted on Nov 24, 2010
Overload sa-tx50
Most overloads are caused by the main output devices. They will go short circuit if for example speaker wires have come into touch. Another cause is high volume or a faulty speaker. Or poor ventilation around the amp causing excess heat.
The only cure is to replace the device(s) generally located on the heat sink.
Dec 01, 2013 | Technics SA-TX50 Receiver
Technics sa-dx1050 overload
if any one of the channels was shorted out, even momentarily, that channel's output transistors would likely be blown causing it to stay in protection mode. (or overload as you put it). Time to visit the repair shop.
Jul 23, 2012 | Technics SA-DX1050 Receiver
Overload protection
Thanks,
Dan
Jan 16, 2009 | Technics Audio Players & Recorders
I have a Technics SA-AX610 receiver that says overload .
From the manual pg 27....... "The protection circuitry has functioned because the positive and negative speaker connection wires are "shorted," speaker systems with an impedance less than the indicated rated impedance of this unit are used or under severe use, such as loud volume, excessive power and in an excessively hot environment."
Nov 16, 2008 | Technics SA-EX110 Receiver
Technics SA-DA10 jumps into overload after 10 minutes
Have you tried connecting speakers? What was the result?
Yes, when you turn the volume up on these amps (or when the output gets past a certain level) the cooling fan should automatically come on.
Oct 14, 2008 | Technics SA-DA10 Receiver
Overload message in technics model SA- EX400P-K I have an older Technics system. It has worked great for years but now I get overload whenever I turn it on. Have changed speaker wires but no use. Any...
The overload message is the old version of "protect" mode. This means that a problem has been detected in the output amp section and that section is shutdown to prevent further damage. Your unit uses amp-pacs. One or more are bad. These are marked RSN3305P and cost about $66 each.
Dan
Jul 15, 2008 | Audio Players & Recorders
No, its my Technics SA-GX550 amplifier - have a problem - HELP!!
Im having the same problem with mine. The problem seems to have started after I placed a vcr on top of the unit. I am thinking that It may be getting too hot. But don't really know.
May 05, 2008 | Technics SA-DX750 Receiver
Technics SA-DX940
overload, usually means that is overloaded. i've had the receiver for about 4 or 5 years now and never had problems with it. It was sitting ontop on my tv for those 4 or 5 years, and i haver noticed it untill just recently, (when i bought a new tv and i had to get a stand for it, and i had to stick the receiver in it)that is runs very hot, very quickly; Maybe that is the problem you are having now, that the thins is older and maight be able to handle it as it id b4. Maybe you made some changes to your set up: new speakers, etc.
Jan 25, 2007 | Technics SA-DX940
"Overload"
Check your wires for cross polarity
Dec 20, 2006 | Technics SA-DX940
Open Questions:
See all Technics SA-EX400 Receiver Questions
2,068 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
