Question about Epson Aculaser C1100 Printer
Black Toner replaced
Black cartridge for Epson C1100 printer was replaced with a remanufactured cartridge, however supply status on LCD and screen show low toner near empty. Printer still prints but does not show toner level. Any suggestions to rectify this?
  • Anonymous Mar 19, 2014
    Toner is not supplying
This is what happens when you also do a refil, but the advice from the refill people is to ignore the low ink warning as it will print happily until the point that the next message comes up which is that you need to replace the toner. Effectively this is to do with teh chip in the cartridge thaht tells the printer that it is low and unless you buy a new cartridge you will still get the low toner message but it is safe to ignore.
Posted on Oct 25, 2007
  • Epson Master
  • 1,113 Answers
Replace Toner with gen cartridge.
Or Take cartridge back as faulty after checking that it was opened and installed correctly.
Check display on printer for indications that maybe it needs one of the 3 colour toners indicators are Y,C or M
K is black
Posted on Oct 20, 2007
How exchange cartridge for Epson C1100
Make sure that Ready or Sleep is displayed in the LCD panel.
Select Change Toner X (The letters C, M, Y, or K appear in place of X, indicating the colors Cyan, Magenta, Yellow, and Black.) in the Reset Menu on the control panel.While the cartridge X you selected above moves to the cartridge replacement position, Please Wait appears on the LCD panel.Replace Toner X appears in the LCD panel when the cartridge to be replaced reaches the cartridge replacement position.Then Open Cover A.Push up the right lever to unlock the toner cartridge. Then remove the toner cartridge from the printer.
May 15, 2010 | Epson Aculaser C1100 Printer
Where abouts is toner k
K toner is refering to black toner. Here is a link to Epson for your Aculaser C1100 Reference Guide. Look under Setup & Maintenence for >Replacing Consumable Products..... click on 'Toner Cartridge' for the proceedure.
http://support2.epson.net/manuals/english/page/aculaserc1100/ref_g/index.htm
Nov 27, 2009 | Epson Aculaser C1100 Printer
Override Toner Out on Epson C1100
This may or may not work but you can try taking the toner cartridge out and carefully shaking it, (don't spill it on yourself) then re-install it and see if you've shaken enough toner loose to fool the printer.If so it may make a print for you if this doesn't work you have no option but to replace the toner cartridge.
Aug 31, 2009 | Epson Aculaser C1100 Printer
What colour is K on low ink
Toner K low refers to the black toner.
May 15, 2009 | Epson Aculaser C1100 Printer
Cannot take out the ink cartridge out of the epson aculaser C1100
You must follow these steps to replace the toner cartridges:
  1. Turn the printer on.
    getimage.ashx?id=912&w=
  2. Open Cover A.
    getimage.ashx?id=913&w=
  3. Push up the right lever to unlock the toner cartridge.
    getimage.ashx?id=914&w=
  4. Remove the toner cartridge from the printer.
    getimage.ashx?id=915&w=
  5. Take the new toner cartridge out of its package and gently shake the toner cartridge as shown below.
    getimage.ashx?id=916&w=
  6. Hold the tag and gently pull the toner seal upward and remove it.
    getimage.ashx?id=917&w=
  7. Insert the cartridge all the way until it stops securely with the arrow mark on the top of the toner cartridge facing toward cover A.
    getimage.ashx?id=918&w=
    TIP: Hold the cartridge in the middle as shown in the picture. Push it gently all the way through the rails. Make sure both sides of the cartridge are inserted at the same time. Keeping some pressure in the middle of cartridge until you hear a ‘click’.
  8. Push down the right lever to lock the toner cartridge.
    getimage.ashx?id=919&w=
  9. Close Cover A
Apr 02, 2009 | Epson Aculaser C1100 Printer
K toner low
C - is for Cyan
M - is for Magenta
Y - is for Yellow
K - is for BlacK
Jan 25, 2008 | Epson Aculaser C1100 Printer
How to change cartdridge for other color???
If you wait until the colour has completely run out, you will see a message to that effect, and the correct cartride will be presented. If you wish to change before this:
1. On the printers' control panel, press the "right" button (labeled no. 3) once and then the "down" button (labeled no. 4) until you see the RESET MENU.
2. Press the "right" button (labeled no. 3) once.
3. Press the "down" button (labeled no. 4) until you see "CHANGE TONER X" appear on the screen (where X is either C, M, Y or K, Cyan. Magenta, Yellow or Black).
4. Press the "right" button (labeled no. 3) once. The printer will rotate the toner carousel to the correct position for you to change.
5. Open the printer door and change the toner as normal.
Jan 20, 2008 | Epson Aculaser C1100 Printer
Epson Aculaser C1100N - Black Toner problem
IF the problem persists with an original cartridge then the factory settings should be restored refer the manual or go through the settings in the control panel . minimise the tone of printing . If toner is getting accumulated in the printer then it might be due to refilled toner not the original cartridge . use the original cartridges
Nov 18, 2007 | Epson Aculaser C1100 Printer
Epson aculaser c1100 cant access empty ink cartridge.
go to the reset menu (right arrow and then down arrow until reset menu is displayed) on the lcd display and then choose change toner #(right arrow until the desired toner is displayed) Hope this helps
Sep 27, 2007 | Epson Aculaser C1100 Printer
Epson c1100
Yes, they do make this model, I'm using one now. I had the same problem
The solution for me was to clean inside of printer thoroughly, with the C (or whatever) cartridge removed. The sensors get dirty.
Sep 04, 2007 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
531 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
