Posted on May 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error Code E07-12
I have a Panasonic DP-2500 that is showing the error code E07-12, then the words Check Scanner Unit. Can anyone offer any guidence on this, and what it means?
Everett Lin
Level 3:
President:
  • Panasonic Master 990 Answers
  • Posted on May 25, 2009
Everett Lin
Panasonic Master
Level 3:
President:
Answers
990
Questions
Helped
434384
Points
3069
HEllo sir; Try to make a copy without the cover,see the exposure lamp is on or not if not check the thermo fuse and exposure lamp.
How to setting E02-02 code panasonic photocopier machine
Hi.
Panasonic Workio DP-1820P error code E02-01 These instructions describe error code E02-01 solution for a Panasonic Workio DP-1520p, DP-1820P copier machine. This should solve your problem; this introduction will help you to troubleshoot some common error messages related to Panasonic Workio DP-1520p, DP-1820P Error Code E2-01, E2-02, E2-03, and E2-04 that you may receive.
Meaning of E02-01 the Error Code:
E02-01 means the Tray 1 cassette lifting motor unit fault. These machines use a lift motor encased in a plastic drive gear casing. Usually something inside the casing breaks, this usually happens in trays that have Ledger or Legal paper installed. The weight of the paper can cause these gear packs to break. Also if the customer loads letter paper in a tray set up for larger paper sizes.
How to fix the error:
Maybe a problem with tray 1 lift motor either you have a bad motor, Pull the paper tray out and see if the paper is lodged behind the tray, Also make sure the white coupling on the rear wall is in one piece. Check that the flag on the back of the tray is still present. Mostly it is broken and sometimes can be repaired, and otherwise, you have to change it, and to open the back cover and reach that (Part no is (DZTY000357 Paper Lift Motor Assembly, lift up drive).
Some of the possible causes:
  • Remove the tray and check for paper behind the tray.
  • Check paper falls back causing the gears to break.
  • Check cassette Lift Motor connector.
  • Replace the Tray 1 lift motor.
  • Check the Mainboard.
Good luck.
How does this proplem occur? panasonic dp 2500 error e04-01
This error comes in fuser unit. the temperature is to low. Check the heater lamp, thermoswitch, thermistor and HTC board. Sometimes draping electricity voltage can cause of low temperature.
3helpful
ERROR CODE READS CHECK SCANNER UNIT, E01-01 IS THERE ANYTHING THAT I CAN DO, OR DO I NEED TO WAIT UNTIL MONDAY FOR A SERVICE CALL? THANKS FOR YOUR INFORMATION.
ERROR CODE READS CHECK SCANNER UNIT, E01-01 IS THERE ANYTHING THAT I CAN DO, OR DO I NEED TO WAIT UNTIL SUNDAY FOR A SERVICE CALL? THANKS FOR YOUR INFORMATION.
1helpful
What does error code E05-11 mean?
there is a communication error on the device most propably caused by a problem with the large capacity tray feed unit loom. there is a techinical update for this problem and you would need a technician to attend.
8helpful
2answers
Panasonic dp 2000 pm error code e04-01 need help
this is fixing error
enter the service mode
f9
enter
3helpful
Where's the fuser unit on a Panasonic DP 3000
Hello sir;Cleaning the fuser unit not thing to do with the error code E4-01, but there is the way to reset just followinf the steps;
1, press and hold down following 3 keys by order "function", "original size", "3".
2, enter 9, press print,enter 04 press print.
3, press following two keys at same time "function", "'clear".
4helpful
3answers
My Panasonic DP-2330 .... Is Showing Error Code E04-02
How enter to service mode in panasonic DP2330 copier.
2helpful
Panasonic 2500
e4 errors means fuser error, probably you encountered lots of fuser jamming.
the best thing to do is to ask your service provider to check your machine but for the mean time, you could erase the error log.
press function + orig. size + 3
press 9
find ram initialize
find LBP FUSER RESET
note: make sure that LBP FUSER RESET is the selected one
press set.
restart your machine
if you still encountered an e4 error, it means that there is a physical/hardware problem on your fuser unit.
i hope this could help u. : )
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
