Will not wash, spin or drain out water
I have a GE washer model# WPGT9150HMG. I started it, the water did fill, but now it is seems to be "sensing", it is not washing, spinning and i dont' know how to drain the water out. water has been in washer for 3 days, i turned it off and restarted (still nothing, only sensing) I unlugged the machine for about 5 hours and plug back in to restart (still nothing) what can i do to get it started or at least get it to drain the water out?
  • 351 Answers
Use a plastic container that will fit in the machine and bail the water out into a bucket, only takes a few minutes.
If it has a removable panel at the front take it off and that will expose all the pumpout hose,the pump and the undercarriage of the machine.
You can drain the remaining water from the machine by removing the large rubber pump-out hose from under the plastic bowl, use a bucket to catch the water.
Check under the washing machine for a belt that may have broken or just come off.
hope this helps you
Posted on May 24, 2009
The washer fills agitate but won't spin & drain
Possible fault with the program controller unit. You need to check the program cycle outputs using a multimeter connected to measure the output voltage. On start the inlet should open and then close as the water level sensors works and then proceed to wash. So this much seems OK. Now in the next step the drain valve must open to drain off, then fill once again with the inlet working and water level being sensed. If there is no output in this section cycle then the prrogram controller has errors within the memory . You can remove the panel and reset all connectors and connections.
Oct 30, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
GE washer model WJRE5550K2WW - will fill water and drain but does not agitate and spin.
It new to me I am working on a GE washer model wjre5550k2ww it fill but not washing I can put it into the spin and it release the water but do not spin
Jan 05, 2011 | Washing Machines
Whirlpool washer WTW57ESVW0 won't fill with water. I bought this machine two months ago was working fine and then just stopped filling water. Spin cycle and drain cycle work but it won't start fill...
Solution for WTW57ESVW0 Whirlpool Washer that won't fill or agitate, but will spin and drain water.
Replacing the Auto Load Sensing Switch (W10177795 - Illus. No. 12 on Control and Rear Panel Parts) fixed the problem.
In addition, a defective switch can also cause the machine to start agitating while it is filling.
It is relatively easy to replace and there are online videos that can help with the replacement.
Oct 27, 2010 | Washing Machines
No water no Spin
Check your 2 in 3 out water valve part# WH13X10029, this responsible for filling of water. By the way wash cycle will not run, until washer sense enough water.
Jul 27, 2010 | General Electric WBVH5200J Front Load...
GE Washer does not drain or spin
Inspect the drain hose for kinks
Test the timer control
Test the lid switch (some models)
Inspect the water pump
Inspect the drive belt (belt drive only)
Inspect the motor coupler
Jul 15, 2009 | GE WDSR2080D Top Load Washer
Washer filles with water can hear timmer then drains never spins
you have transmission problems. When your washer is empty and off you should be able to turnthe agitator by hand if you can't then the transmission is bad.
Apr 03, 2009 | GE WDSR2080D Top Load Washer
GE washer won't spin
you need to post your model number
Mar 31, 2009 | GE WDSR2080D Top Load Washer
GE Profile washer won't spin cloths after wash or rinse cycle
My GE washer model number WLSR2000G3WW washes and pumps water out but will not spin...can someone help me to solve my problem PLEASE?
Jan 23, 2009 | GE WBSR3140DW Top Load Washer
Fixn my GE washer spin cycle
It sounds like it could be the lid switch, check to make sure the lid switch is clicking when you close the lid.
Jun 27, 2008 | GE WHRE5260E Top Load Washer
Washing Machines Logo
117 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
