Question about Kenmore 44109 / 44102 Side by Side Refrigerator
Icemaker i have a kenmorecoldspot and it has stop making ice what could be the problem
Re: icemaker
Changed filter ice maker will not fill with water but the water dispencer works
Posted on Jul 08, 2008
  • 473 Answers
Re: icemaker
Look at the ice maker and see what position the ejector bar (white bar with fingers that turns and ejects the ice).  Looking at the ice maker from the front (front is white plastic cover) the ejector bar should be in the 2-3 o'clock position .  If it is not then the module is broken.  In this case the module and ice maker thermostat need to be replaced.  If not sure how to do this repair then just buy a new ice maker.  Let me know what you find and we can go further if necessary.  This is the first thing to check.
Posted on Oct 20, 2007
0 characters
3 Points
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ...
    • 4 MIN
    • ADDED 2013-05-15
    Video embedded · How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    PFSF5RKZC Icemaker stopped making ice.
    Most of the time is the ice maker itself that is defective. inside ice maker is an small circuit board that freezes up, if you take ice maker out and leave it overnight out to melt any ice inside the board it may work after that.
    Apr 03, 2014 | GE Refrigerators
    Amana model tg21vl stops making ice
    pull on icemaker fingers to force icemaker , check for ice in tube to icemaker and listen for the valve to open , if all checks ok replace icemaker
    Feb 24, 2013 | Refrigerators
    How do I get my my GE refrigerator model no. GSS201EPJWW to stop making ice? Bin fills with ice but don't know how to turn off icemaker. Thanks
    slide the panel out from in front of the icemaker,there is a slide switch on the icemaker marked on/off
    Jan 11, 2013 | Refrigerators
    Ice cube tray won't stop making ice.
    This is due to the arm that controls the switch on the icemaker itself either being shorted or froozen in the toggled position. Usually the arm would lift as your ice container becomes full and shut the icemaker off until it reached a level where the switch would then toggle to the make ice position and then start makeing ice again. There are three 1/4" screws that hold the icemaker in place remove these screws unplug the icemaker and then use hot water to dethaw your ice maker for about 2-4 minutes after wards dry the icemaker then try reinstalling the icemaker if the problem persists replace the icemaker itself. If you have any further questions message me back I await your reply.
    Thank you
    Mar 12, 2012 | Refrigerators
    Icemaker not making ice
    Pull the line off at the icemaker and check for a filter at the inlet...often **** builds up there and stops off the water...
    Here are some basic tips for ice maker troubleshooting2_bing.gif...
    Ice Maker Problems and Ice Maker Troubleshooting
    Jul 13, 2010 | Kenmore Refrigerators
    Ice maker stopped making ice
    Pour about 1/2 cup of water into icemaker . If it dumps , replace the water valve . If doesn't dump , replace the icemaker . Also make sure the coils are clean of dust , lint , etc...
    Aug 15, 2009 | Refrigerators
    Icemaker want stop making ice
    The quick answer is to turn the water off to the refrigerator so it quits making until you get it fixed.
    If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board.
    If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker.
    You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
    Post back if you need instructions on reparing it.
    Oct 25, 2007 | Whirlpool ED2FHEXN Side by Side...
    Kenmore 44109 / 44102 Side by Side Refrigerator Logo
    178 people viewed this question
    Top Kenmore Refrigerators Experts
    Fred Sops
    John Tripp
    John Tripp
    mike cooper
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
