MY 52 INCH PANASONIC DOES NOT COME ON, I PRESS THE ON BUTTON AND IT SOUNDS AS IF IT WANTED TO BUT EVENTUALLY CLICKS OFF, AND THE FLASHING RED LIGHT FOR THE LAMP STARTS BLINKING. DO I NEED TO REPLACE THE BULB OR LAMP? AND IF SO WHERE CAN I BUY ONE. THE SERIAL NUMBER TO THE TV IS: E6AA11526R, 2006 MODEL. AGAIN THANK YOU FOR YOUR COOPERATION.
If you haven't replaced the lamp yet, that is the first thing to try. Its not hard to do at all.
You can get the lamp just about anywhere on the web.
Here is a link to one site
http://lamps-dlp.com/ProductDetail.asp?PartNumber=TY-LA1001&A=G&B=LA1001
Here is the procedure for replacing the lamp.
Unplug the unit from the wall and wait for all the lights to stop blinking. Ensure that the lamp and the area around the lamp has cooled.
Remove the front cover of the set. You should be able to see the lamp door at this time, loosen the screw and remove the door. You will now have access to the lamp, loosen the lamp screws and remove the lamp cartridge. Reverse the above process and you should be back in business.
For the full instructions and how to reset the lamp timer go to the following site
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I have helped you, please help me, and rate this suggestion a the highest FixYa rating (Give it Two thumbs up). If not then please comment to this post and I will try to help you further.
Thank you for your support.
There are lots of places on the internet to get dlp lamps. The model for your particular TV can be found at:http://dlplamps.com/products/panasonic-dlp-lamp/panasonic-ty-la1001.htmlHope this help you and anyone else having problems with this particular TV model.
