Question about Vacuums
My husband vacuumed up a pound of feta cheese into the upright vacuum. Cheese is inside, on wheels, etc. I cannot figure out how to open so that I can clean the brush and the isides. Help! Linda
  • 2 more comments
  • donalinda May 23, 2009
    kenmore model # 116.35922500
  • donalinda May 24, 2009
    this is an upright vacuum and I do not see how to disconnet the power bar from the unit. I
    the answer I got does not help. This is an upright vacuum Kenmore model 116.35922.
    This is beltless vacuum and we tried removing the screws and nothing loosened. It sounds like we are gong to have to take it to Sears repair as no one will touch a Kenmore.
  • 15,935 Answers
Yes - an independant vacuum repair shop is unlikely to repair (disassemble) - as this vac is no longer supported (in case something is broken during servicing).
You will (probably) find the repair to be more than the cost of a new vac.
Think about it before you get in too far.
Thanks for using FixYa!!
Posted on May 25, 2009
    Guru:
  • 462 Answers
Linda,
Usually there is a cover plate on the bottom of the vacume. The plate can be heldd on by screws or clips. Sometimes the screws are resessed into holes molded in the plastic body of the vacume and go into the plate especially if it is plastic too. Sorry I dont have any lidature on your peticular model from sears. Is the cheese also where the belt is? Remove all that you can bag, cover, anything else that may be removable especially from the lower side below the handle. Often the access to removing the lower section is under anotyher area maybe the upper part of the top or the area of the bag. Look for screws that holkd the bottom on. Examine each screw you remove and mark it on a piece of paper as to where it cam out of. Keep all the screws that are alike on 1 paper pay attention to the type of threads and the length of the screws. You dont want to put back a long screw where a shorter one was. Once you have the screws removed look for flat bars or clips that may be holding the pieces together.
This is standard way I try to disassemble anything Im not femilure with. Then do your clean up. I recomend you can use some WD40 it loosens wax and oil and dirt. Cotton q-tips or pipe cleaners may be needed.It dosnt have to be 100% clean but the more the better.
And for fathers day get your husband a new vacume. It is what he always wanted take it from a guy who knowes what we like. Its pratical too. Seriously Good luck and thanks for using fixya. If this helpd you gain confidence to remove and repair/clean what you needed please rate me with as high a rating as you can.
Posted on May 24, 2009
    Sergeant:
  • 296 Answers
Hi Linda
1. With the power bar disconnected from the vacuum, turn it upside down and you will see two inset screws at the rear side of the base of the power bar. Unscrew these two screws using your Phillips screwdriver.
2. With the power bar in the same position unlatch the two plastic tabs at the rear of the power par. [It may be useful to flip up the metal bar that you see on the base to use as a handle] On each side of the base you will see an arrow saying insert screwdriver here to release. Insert a screwdriver and lever the plastic of the base slightly apart from the plastic of the side. When you have done this for both sides the base should lift off.
3. Now lift the brush including the two end pieces straight up. It should just slide up. You will need to unhook the drive belt from the brush as you lift it out.
4.Pull of each end piece and clean the dust, lint, hair off the end piece and from inside the end of the brush.
5.Once clean, reinstall the end pieces on the brush. Hook the belt back over the brush to its original position and slide the brush back into the power bar.
6. Reinstall the base by hooking the tabs from the front of the base into the small openings on the power bar.then push the base down until it clicks back into place and the tabs are back in their original position. Reinstall the two screws you removed earlier.
OR
for manual or user guide:-
Go to www.managemyhome.com and sign up. You have to in order to access the manuals but it's free so no big deal. After you sign up, put your cursor on Home at the top left, then follow the dropdown list until you see product manuals and click on that. Then you just enter your model number and it pulls up a downloadable manual for you. If your manual isn't there, call the 800 number listed at the bottom of that page and they'll get it on there for you, usually in about 2 working days. Very helpful people on the other end fo the phone, excellent customer service especially considering that you are charged for NOTHING!
regards
  • Vacuums Master
  • 13,433 Answers
Can you send me the brand and model please.
Posted on May 23, 2009
  • Ekse May 24, 2009
    Hi again, I'm sorry I can't help you with that brand. You have a button for reposting the problem / request advice from other experts.
    Please press on it to get another expert.
    all I can say without being fimiliar with this one, is to unscrew all the screws you find and take it apart slowly.
    Please press on the repost or request another expert - something to that direction hopefully you will get someone who is fimiliar with kenmore.
My S7000 upright had a clog. My husband removed the bottom plate, the hose & the port door. He was able to get the giant hairball out, but in the process he has "extra" parts leftover: two springs
The springs are probably from the self adjusting floating wheels underneath and came out when he took it apart.Just a guess I'm not real familiar with that type of vacuum.
Jan 23, 2014 | Miele S7210 Bagged Upright Vacuum
Dyson DC41 animal complete stuck in upright position - how do I get it down. Have been on hold with Dyson for hours.
The wheels are probably jammed and won't recline. Mine was stuck pretty bad, and after a half hour of trying to figure it out I just picked up the vacuum and slammed the wheels pretty hard, and it came loose. No problem since. Pushing on it hard did nothing, and gave me the impression I could break the vacuum, but all it needed was a good jolt.
Aug 03, 2013 | Dyson Bagless Upright Vacuum DC41 Animal
Someone put the nozzle of the cheese bag thru the dial rather than around it. now it has no power
I would check to see if it blew a fuse or my have tripped a safety breaker on the motor. I believe those have a tension sensor on them to prevent the machine from ripping the bag open.
Jul 06, 2012 | Vacuums
Do you have a grater blade for a Farberware 286 processor. It is used for grating cheese and vegetables.
Hi gee helen...
Go to the following website they carry parts for Farberware food processors.
They also have a toll free number to contact them: 1-800-675-9491
Please take time to rate me
http://www.bettervac.com/menu_farberware.asp
Sep 01, 2011 | Vacuums
Replace the belt on a upright vac
There is a very small wheel attached to the motors drive. Belt goes around the motor drive wheel and then around the drive roller assembly
Feb 22, 2010 | Kenmore 34612 Bagged Upright Vacuum
Spring on bottom wheels eureka altima
look up inside where the wheels go and you will see a open notch clip the spring in there and on the wheel assembly itself oon the inside you will see a holeclip the other end of the spring to that .your done
Apr 22, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka 411B Upright Vacuum
It goes in a slot beside the right wheel. It is a detent for the hinge. Metal spring first and then the nylon piece round edge up.
Nov 14, 2008 | Eureka 411A Upright Vacuum
Replacing spring in wheel height adjustment
I just solved the problem. Go to this website: http://www.completevac.com/kirby_schemo_5.html
It will show you where the spring goes (left side inside the ratchet - when you remove the ratchet you will see that it is hollow. That's where the spring goes!) and a good picture of that assembly
Jul 30, 2008 | Kirby G6 Bagged Upright Vacuum
Vacuums Logo
130 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
