Question about E-Machines eMachines Desktop PC
P.c. wont turn on
Little buz when pluged in
    Champion:
  • 381 Answers
Open case the CPU then remove the memory then make a clean all pin connectors of memory....
Posted on May 23, 2009
  • 111 Answers
You have a bad power supply. If you open the case, and take a look inside you should see a long (about 1.5 inch) connector connected to the motherboard with several leads going back to the power supply. Try removing and reseating it. If that doesn't work, than copy the input and output voltage numbers off of your existing power supply and order a new one. Should cost you about $70.00 USD
Wont turn on
Main digital board fault. Check and replace it. In most cases a firmware update too might be necessary. http://electronicshelponline.blogspot.com/
Feb 01, 2017 | Samsung Televison & Video
Blower not turning on , only if I turn it by hand first
thats a bad starting capacitor ... look for a small (about 2 or 3 inches) metal can probably rounded rectangle .. that would be connected to the fan motor with maybe 2 or 3 wires .. it is used to give the fan motor a direction to turn .. if its bad the fan wont turn at all .. just buz until you spin it ... there is a part number on the capacitor or you can replace it with one that has the same ratings for microfarads (mfd) and voltage (vac) and will phisically fit .. make sure the fan turns freely .. if not lub the bearings ..
Jul 25, 2010 | Dometic Rooftop RV Air Conditioner
My samsung 32'' lcd tv
poke it open, you'll find bloated capacitors at power supply board. biggest one, with power cord pluged into. replace with thesame value(s).
you good to go!
don't lie, next time! your set has been acting up fpr a while, before it quit. Remembering: few attempts to turn it on, then it works!
good luck.
Apr 04, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Wont turn on every thing is hooked up right pluged
A PLYE AMP IS NO GOOD AND ITS PROBABLY BLOWN SORRY FOR THE BAD NEWS
Feb 09, 2010 | Pyle PLA985R Car Audio Amplifier
Oven erupted like a blow torch why?
The broiler element burned into. Look at the top element and you will see a spot where it is rough, melted or burned. Replace the element by removing the two screws at the back of the oven and pull the wire out a little and unplug the element and plug the new on it.
Dec 26, 2009 | Kitchen Ranges
My turtle beach x1 wont turn on?
The green light (or red if it's muted) should glow on when you plug in the USB. If it doesn't, it means there's a problem with the power feed to your X1 and you should contact Turtle Beach tech support to get it fixed.
Aug 07, 2009 | Voyetra Turtle Beach Ear Force X1 Headset
Wont start
no fuel issue. check fuse for fuel pump check fuel pump fuel pump relay fuel filter could be pluged.if you turn engine over acouple turns and stop you should hear fuel pump buzz.also check wires at ignition coil for corrostion or broken fuel pump relay gets its singnal for negitive side of coil.
Jun 14, 2008 | 1986 Volkswagen Wagon Camper
My zodiac mp4 wont turn on when pluged in to be charged and wont turn on
if you are trying to use it while it's pluged in, it might not work because some mp4s and mp3s dont work while they're charging. but the zodiac mp4 should run while it's plugged in... if it's not turning on at all while it's unpluged, maybe try to plug it in for an hour or two and if its still not turning on or if its showing no signs that it was charged, i would try maybe getting a new battery or contacting the company
hope i helped a little... good luck :)
May 03, 2008 | Audio Players & Recorders
E-Machines eMachines Desktop PC Logo
67 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
