My Viore 52" rear projection DLP HDTV is two years old and started turning itself off after about 10 - 15 seconds. you can turn it back on just fine, but the problem is non-stop.
  • chadcrad May 23, 2009
    I appreciate that...do you have any estimate as to what I shoud failry be charged for repairs? I've never dealt with TV repairs as I generally replace them...Economy negates that option at this time, however, I don't want to have my ignorance of the repair costs taken advantage of. Again, thank you a million for getting back with me.
  • 19,396 Answers
This kind of faults are not easy to diagnose.
When a rear projection TV turns off after a while , that is because of overheating or because of a different internal fault, typically a fault capacitor either on power board or ballast board.
When it is overheating , that usually happens because the fan(s) in the lamp/ballast/optical group assembly are not working (sometimes there is more than one , up to three fans) . Ofen there is only one fan near to the lamp.
If the fan is fine, then the problem happens because of a a faulty capacitor. The TV restarts after a while just because capacitors discharge the electricity that they are holding after this time.
This kind of problem is usually due to a fault either on power supply board or on ballast board, that is the AC board powering the LAMP.
If instead of lamp model has CRTs, then the CRTs power boards must be tested.
Both parts must be tested before replacement.
A first this can be done visually inspecting the board , looking for bulged or leaking capacitors, cold solder joints, blown components and burnt areas.
If nothing is seen at a glance , the power board first , and then the flyback converter and mainboard must be tested.
Your TV capacitors will hold charge for a while, even when power cord is unplugged, and can release a dangerous high voltage discharge. Do not service the TV by yourself unless you have previous experience in repairing TVs.
If you want to buy parts or the service manual for this model, contact one of the sellers below:
Encompass Parts Distribution
electronics parts & more from PartStore.com
Posted on May 23, 2009
VIORE DLP goes off 30 seconds after i switch it on
Listen closely at the rear of the set for any noise from a fan. Most projection sets have them to cool high temperature areas common in these and if the fan fails, the set will shut itself off before any heat damage results. If you hear nothing, use a portable fan directed at visible openings in the lower cabinet and see if this delays the shut-off of the set. If so, the fan is likely dead.
Jul 30, 2011 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
4 year old Mitsubishi wd 52528 has had flashing timer light then turns itself off since power outage. After turns itself off, can't get it back on, even with reset.
Need to unplug for computer to power down then plug back in, light will blink for a few then go out and you should be able to power on!
Feb 12, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I have a 46' viore ipt46dl30 and when it turns on all the screen is really flickery. and most the colours come up purple, but this goes away for about 5 ten minutes and the flickery purple screen comes...
Viore ipt46dl30
Same problem, cleaned color wheel, put a few drops of wd40 on bearings, worked good for two months.
Started flickering again, need to replace color wheel.
Feb 03, 2010 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
Our RCA high-def 52 inch TV is shutting off on
It has you Posted as a projection TV and Not DLP, if Fan to Lamp stops running set will shut off to protect Lamp,I had a DLP that would play sometimes 30 mins then shut off drove me crazy trying to firgure it out and it turn out to be Fan would stop running I replaced Fan TV working fine . When you remove back engage toggler switch to up position put a piece of tape on it to hold it is a safty switch ,then turn tv on watch to see if all fans are running also if when tv trys to come on is there a spark coming from Ballast Board if so your new Lamp is defective it does happen if not your ballast board maybe Bad it is what turns on Lamp.If all fans are running Ballast Board.
Sep 22, 2009 | RCA HD52W56 52" Rear Projection HDTV
Zenith 52'' dlp tv won't turn on
after an hour tv shuts off and you have to wait to turn it back on
Jun 12, 2009 | Zenith Televison & Video
RCA HD52W27D
I just fixed my D52W20 by replacing three CAPS. Two of them were vented(bulging at the top). I replaced CP150 2200uf 16v with a 2200uf 50V, CP110 220uf 200v and CP114 220uf 35v. It was also recommended to replace CP120 but I did not have one. Check the green CAPS and replace any that are vented.
Oct 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Viore DLP TV
The lamp is most likely over heating. Check the fan in the lamp assembly compartment. Its located in the rear of the tv... try removing the lamp compartment and replacing the fan.
A quick fix is to put a small 7-10 inch box fan with its back flush to the lamp
compartment's vent - this will draw the heat out.
Sep 10, 2008 | LG 42LC2D 42 in. LCD HDTV
Tv turning off by itself occasionally
Just had mine repaired yesterday.
They relaced a TD4611 voltage regulator and a C2200uf 50v part.
Total including service call $188.00 in Western Canada.
Phil
Jul 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
