Question about Gateway MX6453 Notebook
RJ-45 Ethernet driver
I recently reinstalled windows, and have found most drivers I need, but have been unable to find the driver for my RJ-45 Ethernet Connector. Any suggestions? Thanks.
  • swt_n_crzy_l May 23, 2009
    XP... maybe i'm just not too computer savvy, but I tried the gateway site and none of thedrivers I installed worked for this..
    Scholar:
  • 57 Answers
For whay ver of windows?
All drivers available here
http://support.gateway.com/support/drivers/search.asp?param=MX6453&st=kw
Posted on May 23, 2009
I have a cable modem that doesn't want to accept the RJ-45 cable (I think that's what it is called.) I've tried several different quality cables with no luck. Strange problem. Any tips?
Some RJ 45 jack cable has fault so try with another RJ 45 jack cable .. Purchase new rj 45 jack cable from nearest computer shop. There must be 2 port on modem 1 for ADSL phone line cable and otthr for LAN ethernet port means RJ 45 jack port. Try with another rj 45 jack cable it should be connect.Make sure that LAN port of modem is not faulty means make sure pins on that port are not break. Let me know if you need further assistance. Thanks for using FixYa.
Jul 24, 2010 | Computers & Internet
T636400000 does it have an ethernet card built in the unit?
You are probably looking at a RJ-11, used for telephone (dial up - modem). You are trying to put a RJ-45 connector in it.
The RJ-45 should have 8 wires while the RJ-11 may have as many as 6 connectors.
Thank you for your voluntary work with this organization.
Note: If you were to plug a RJ-11 into a RJ-45 port and if it happened that you plugged the other end of the phone cord (RJ-11) into a phone jack --- and the phone were to ring ... you would be pumping 60 volts into your computer. Be very careful with these connections. You would then need butter and jelly for your toast, which is what your computer would be.
Ok - recap: Both look very similar ...
Ethernet = 8 conductors - RJ-45
Telephone = up to 6 wires (may be 2 or 4 also) - RJ-11. NOT interchangable.
So how will you connect? If the laptop is not builltin wireless, you can get a PCMIA card for the slot on the side that will allow wireless or ethernet. Get the card at your computer store. ... Or ... use the built in modem for dialup., You would of course need a dialup account somewhere.
Thanks for your question at FixYa.com
Please vote.
Feb 17, 2010 | NEC Versa VXi PC Notebook
Need Drivers for 10/100Mbps integrated Ethernet LAN (RJ-45 port). HD was wiped clean and now do not have the driver for the ethernet port sos cannot access the internet. Need the driver for this unit
I'm sure the original poster of this question has found their answer but for future answer seekers this will do the trick..http://www.nvidia.com/object/nforce_winxp_15.24.html.
I just had to find it for a friend and it wasn't exactly cake to locate so I figure I'd come back and hopefully make someones day a little easier.
Jan 01, 2010 | E-Machines T6420 PC Desktop
RJ-45 - Ethernet LAN
What Operating System are you using? (ie Windows XP)
Try re-installing drivers from Here
Mar 27, 2009 | Compaq Presario 700 470024-192 Notebook
USB 2.0 to RJ-45 LAN Ethernet Network Adapter driver required
SMC2206USB/ETH Drivers
SMC2208USB_ETH Driver
SMC2209USB/ETH Drivers
If it's an SMC with a little luck you'll find the drivers for your specific model number, Otherwise, go to SMC Site and search for your model number. If it's not an SMC device, let me know what brand and model number it is.
Alex
Mar 25, 2009 | SMC USB 10/100 m Ethernet Lan Card Adapter...
Modem
Technical Specifications AAL and ATM Support
VCI 0-65535 address range
VPI 0-255 address range
AAL5 support
Bridging
IEEE 802.1.d Transparent Learning Bridge (dynamic learning of up to 255 addresses)
Spanning Tree support
Certifications
FCC Part 15, Class B
CE certification
Connectors
DSL interface: RJ-11 or RJ-45 (Europe)
Ethernet interface: RJ-45
USB Type B interface (5200, 5500 series)
Diagnostic LEDs
Power, DSL, Activity, Ethernet status; USB status (5200, 5500 series)
Management
Intuitive, Web-based GUI management access
SNMP support
Comprehensive hardware diagnostics
Media Interface
RJ-11 or RJ-45 (European) DSL WAN connection
10/100Base-T RJ-45 Ethernet LAN connection
USB Type B LAN connection (5200, 5500 series)
Power
12V power supply included, 700ma max. 5400/5500 - 12 VDC, 1000ma max.
Routing
DHCP server/DHCP client
Network Address Port Translation (NAPT)
Network Address Translation (NAT)
Packet filtering
RFC 2364 Point-to-Point Protocol over ATM PVCs (PPPoA)
RFC 2516 Point-to-Point Protocol over Ethernet (PPPoE)
RFC 2684 (formerly 1483) Bridged Ethernet and routed encapsulation Routing
Standards Compliance
IEEE 802.3
USB 1.1 T1.413 issue 2 G.992.1 (G.DMT) G.992.2 (G.Lite)
Oct 15, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Need ethernet controller driver for sony vaio pcg-srx51p/a
Did your sony vaio came with a cd installer? If it has one, you can use that to reinstall the ethernet controller.
May 05, 2008 | Computers & Internet
Connection of Paradyne 6211 to iMac (OS 10.5) via Ethernet
If you connect by using LAN port (RJ 45) you don't have to install driver. However USB connection will require driver. Do you have Ethernet adapter installed to you iMAC? If you have it will be resolved easily without using USB port. Check the following link for connection instructions
http://www.fixya.com/support/p200812-paradyne_6211_a2_200_router/manual-18800/page-18
If physical connection is successful you can go to internet browser type 192.168.1.1 and check your modem's settings. Please post if you need further assistance
Good Luck
Jan 27, 2008 | Belkin (F5D7233) Wireless Router
Gateway MX6453 Notebook Logo
4,950 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
