Question about ASUS Eee PC 701 Notebook
Blue blank screen is my problem
I dont know y u people are not getting my problem....i cant find and control pannel option....when system is starting it is showing blue blank screen...there r no options how can i go to system restore.....i have tried every possible thing./....but cant fix it ....tell me wat can i do
  • oasisofrose May 23, 2009
    give me the solution pleaseeeeeeeeeeeeeeeeee
Problem: An update being pushed out to EEE PC 701SD causing machine not to load to full GUI
Symptom: Machine will start to load into GUI but will get stuck after loading taskbar.
To fix:
Open the Terminal window by pressing Ctl-Alt-T.
Enter the command 'sudo apt-get remove asus-p901-system-update azurebt'
Press power button to turn off machine.
Turn machine back on, open the terminal window again with Ctl-Alt-T.
Enter the command 'sudo apt-get install asus-eeepc-core'
Restart the machine.
Posted on Jun 03, 2009
    Champion:
  • 381 Answers
Insert the wimdows/OS CD if you have then run automatically then choose repair windows or install windows w/live the files
Posted on May 23, 2009
MY LAPTOP CRASHED WHEN PERFORMING A START UP REPAIR NOW I CANT FIX IT, IT KEEPS BLUE SCREENING AND COMES UP WITH LOTS ERRORS .. ALSO WHEN IT TRYS TO SYSTEM RESTORE IT WONT DO IT IT HAS AN ERROR THE...
get a bootable dvd of the same version of windows and start booting from it. instead of installing start repair option. it may help you.
good luck
Sep 03, 2011 | Computers & Internet
I am using XP SP3. installed a game and it did put the wrong video driver file (Direct X) on my computer. Now window screen goes blank (no signal) after initial start up. I don't know how to fix...
Does your monitor have more than one cord?If yes one should be white,which you connect to your gpu.The other should be blue.The blue one is vga,and will connect directly to the mb.Turn off the pc and disconnect the white cord and connect the blue.This should get you a picture.Now down load the newest Direct X and install then power down and switch the cords back.
May 12, 2011 | Computers & Internet
I just got a AXE PC Camera. I installed it, but i dont know where the file is now... Help me please.
please go to start program files and see the axe program name which you install and could be able to use it eassly or can go to controll pannel and imaging devices and there you can find your camera and double click on your came and you should find options to use it
good day
Dec 05, 2010 | Computers & Internet
I have a acer aspier 3515-2153 laptop.It wont go to the user screen.it will turn on say configuring updates then it shuts off agin.How do i fix it i cant afford another computer pleasehelp!!!
HI Steel,
For this you dont need to buy another computer.
Follow the steps.
1. Try safe boot, F8 key @ BIOS screen just after you turn on the system. Choose safe boot from menu.
2. In safeboot.
Go to control pannel and choose option Show windows updates. else they may also be visible by default.
3. Minimise the window.
4. after you find the system is turned up completely.
close the opened window without touching anything.
5. give the system a complete shutdown.
6. reboot.
7. System may say " System has recovered after a serious error"
Still if it does not works.
1.insert the OS disk.
2. choose to follow wizard seriously reading each step.
3. It will ask you ro repair your OS.
Choose this option.
4. let the system recover (The process is slow; may take 30 mins or more)
Rate this solution, Write a comment to keep in touch, let me know how it worked the first way or the other.
WisBee
Sep 16, 2010 | Computers & Internet
I can't find the System Recovery option in the Control Panel after I went from Windows 7 back to Windows Vista due to some problems.
you will not find system recovery options in control pannel, as it is either in the systm tools or you can get it from advance boot menu options by pressing F8 key on start up of computer ,
second way to get system restore is type system restore in start search box and it will show it , third way click on start then all programs , then accessories then system tools , you will find option of system restore.
Sep 04, 2010 | Computers & Internet
Getting a blue screen stop error, but cant log
Please try to start from the beginning and reformat the hard drive by shutting down the system with the cd drawer open. Then insert the windows disk and turn on the pc then the drawer closes and when it tells you boot from cd press enter. Then windows will load. It will give you a couple of options. Always choose format partition. Then you should not have any problems. Unless your hard drive is bad.
Dec 14, 2009 | Microsoft Windows XP Professional With...
Dell Dimension 5150 (& WinXP) - failure to boot up
you could try booting into safe mode, then you could try a system restore
look for the F8 option at the bottom after the first boot window,
youll know youve got it when you get the option to boot into safe mode, if this works you should get to your desktop, if you get the admin login its normally admin as user and leave the password blank.
if you cant get into safe mode, wait till you gt the recovery disks and try a system recovery before reinstalling
Oct 21, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Blue screen arrives ...system not working
At bootup press F9 to restore to factory condition
May 23, 2009 | ASUS Eee PC 701 Notebook
I have PHILIPS 42pfl5332d/37. I was watching tv, and suddenly the screen goes blank. There's a blue light that turns on when the tv's on, however when the screen went blank, that blue light turned orange...
I don't have that problem, my problem is that I lost my remote control, so I can't configure de channels.. I just have 4.. =S.. I can see the menu, but in the part that say start configuration, I cant activated without the control, I don't know what to do.. aNybody Knows??
May 19, 2008 | Televison & Video
Powersave problem
If you are using a desktop computer, chances are that you don't want the computer to go to sleep automatically. This is even more the case if you are running Vista in a virtual machine for testing purposes.
Disabling power management is simple and easy. First go to the start menu and click on the Control Panel.
Click on the System and Maintenance link
Then click on the Power Options link:
It will disable automatic sleep mode, but will still turn off display.\
You can click on change plan to disable.
If you are using XP than.
Open control pannel-> click on power option -> keep turn off monitor setting to never.
Feb 10, 2008 | Compaq Evo D500 PC Desktop
ASUS Eee PC 701 Notebook Logo
383 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
