Question about Nintendo DS Lite Console
The top screen is hanging from a little wire.And, i can't turn it on because i left it in tesun.
My top screen is hangingby a little wire.And i can't turn it on because i left it in the sun
    Problem Solver:
  • 11 Answers
Try putting it back
Posted on May 24, 2009
How can I hang up?
okay heres how you do it..
Slide your finger from the very top going down
the wifi, bluetooth, gps ,sound and auto rotation screen will be open
on this page you will see that your call is still active
just press clear and you will hang up the call
after this just press the home button on your phone and your back to the main menu
Jan 17, 2012 | Samsung Galaxy S GTI9000 Smartphone
Trac light on
sounds like a broken wire on one of the wheel sensors usualy hapens when somone runs over somthing like a box or a tree branch turn the wheels left check behind them for danglers then turn wheels to right and re check for danglers failing that take somewhere like can tire or pep boys for a free brake inspection
they will notice little things like hanging wires and will inform you of the impending repair
Dec 11, 2011 | Toyota Cars & Trucks
Lg km900 blank screen during an incoming call -
There is a little rectangle shape thing next to the lg logo on the top of the fone screen. If this is blocked by screen protector it will cause the phone to blank of during calls. Its a power saver that blanks the phone when its near your face. Try it. Take off the screen protector & make a call. Then place your finger over the little thing & the screen goes blank. Just cut a lil space in the screen protector & that will fix the problem
Jul 15, 2010 | LG KM900 Arena Cell Phone
How do you remove inner tub to get to the outer tub of Fisher & Paykel gwl11
You need 2 people for this.. Unscrew plastic wingnut down the centre of the agitator.(2) undo 2 phillips head screws under little rubber covers just under lid at front top edge.(3)lift top of machine like a car bonnet,get someone to hold it up for you.(4)Unclip big round plastic ring on top of the bowl,you may find its attached with a spring at the front left hand corner,just lay the plastic ring over front of machine & let it hang.The bowl should just lift straight out.Be carefull,the outside of the metal bowl is like a cheese greater trust me! PS when you put it back together & you lower the top of the machine(make sure that little white plastic lever hanging down) the right hand rear go's outside the righthand rear of the tub NOT squashed on top.Its an out of balance lever & it needs to dangle outside of the bowl/tub right rear.GOOD LUCK!
May 27, 2010 | Fisher and Paykel GWL11 Top Load Washer
How do you remove a starter from a 1990 acura integra ls manual transmission.
This is a little tricky but you can do it without really taking anything off the engine.
The starter motor sits on the left hand side of the, underneath the engine block.
When you open your bonnet you will see the clutch cable etc stickign up and then a bit oif space behind that.
If you look into that space, hanging of the engine will be the starter motor.
The stater motor is connected by two bolts (top and bottom), you will need a good socket set and an extendable socket piece to get to the bolts but you can feel around find them.
1. Undo negative terminal to the battery
2. Undo the ground wire from the starter. (It will have a little rubber cap on it - it a 10 mil bolt in Australian Imports)
3. Undo the bottom bolt first (otherwise the top one is a little tricky to get out
4. Undo the top bolt.
5. Pull the starter out (to the left) - you will need to wiggle it aorund a little but it will come out without having to take of anything else)
Installation is the reverse.
When i first did this it took me about 30 mins....
Feb 14, 2010 | 1990 Acura Integra Hatchback
The picture wouldn't come up so we opened the back and found a wire that is hanging loose and were not sure where its supposed to go...apparently it looks like it gives power for the picture bulb to work
BE CAREFULL!!! Is it a red wire with a suction cup on the end? If it is, it connects to the top of the picture tube (there is a little hole in the back of the tube at the top). Unplug the set first and under the suction cup you should see two little tabs. Turn the suction cup inside out to expose the little tabs and insert the two little tabs in the hole. You may have to sqeeze them together a little bit. After they are in the hole they should spring out and latch on to the edges of the hole. Let go of the suction cup and allow it to cover the hole and tabs and all. Hope this helps. Thanks and be carefull. This is the high voltage lead.
Oct 28, 2009 | Televison & Video
Wires hanging in ice maker area
Look underneath the 2nd row from left in the ice tray there should be a white plastic piece that pops in and out from the bottom of the ice tray. Pop it off. There should be a piece of styrofoam on top of the piece you removed. the white wire runs along the bottom of the ice tray there may be little plastic hooks to place wire along the way. The sensor should fit right where the white piece of plastic and styrofoam you removed goes. Just place it there and pop that piece back in. It really doesn't attach to anything just lays there.
May 26, 2009 | LG LSC26905TT Side by Side Refrigerator
Need to know where do i have to hang the 2 resources that are on the side door
I believe the 2 springs hold your side door closed, alot of people use scotch tape to hold the door closed.
Anyway 1 goes on the left side and the other goes on the right side of the door. If you open the door and look down on the plastic frame, not part of the door, you'll see 2 holes on the left and 2 more on the right. The one end of the spring slide down thru the 1 hole and turn it 90 degrees and pull it up so it hooks on the plastic piece between the 2 hloes. Do the same for th other side. Now, the top end of the spring attaches to a plastic tab in line with the holes on the door, toward the top side. Some times those tabs break off.
If that's the case we'll have to get a little creative
Good Luck
Bob
Apr 17, 2009 | Canon NP 7130 Black and White Copier
Wire on tv screen
it is a simple job to fix that. you need to take the whole TV apart and there is a black gasket that falls down on all these TV's. the glue that was on the gasket and the weight of the screen pulls it down more and more. takes about 1 hour by an amateur doing this maybe less for a professional.
Jun 02, 2008 | Protron PLTV-32 Television
Dark screen
Turns out the little button on the top left of the device is for adjusting the contrast. Turn on the WorkPad. Press the little button. Then hold down the down button and the contrast will be adjusted.
Aug 20, 2007 | IBM WorkPad c3
Nintendo DS Lite Console Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
