Question about HP Officejet 4110 All-In-One InkJet Printer
I canceled a print and from then on it will not print from comput
I printed 5 sheets from computer then I canceled the project. when I tried to print another project it does no print from the computer.
  • HP Master
  • 13,433 Answers
The queue is probably stuck, Try restarting the computer and the printer. turn both off and turn the printer on ones your computer is on.
you can check the print queue if it still doesn't print.
open up start -> control panel -> printers
find your way to printers and faxes or printers, depends on if the computer is xp or vista.
Right click on your printer and select open.
is there anything in the print queue? if there is then press PRinter, and Cancel all documents.
ones the stuck project is out of the way it should print normally.
if a project is still stuck in the queue.
press start and select run
OR hold down the windows key and press R
type in: services.msc
press ok or enter
In services find printer spooler. right click stop.
open the print queue again and make sure its empty, close it and open the queue again incase noting appears to have happened.
make sure its empty, cancel all documents again and so on.
one it is empty go back to services, right click on printer spooler and click start. close the window and try printing the project again.
Posted on May 23, 2009
Why is my printer going slow after only 3 or 4 sheets and almost stopping by the 5th print
First question, has the printing behaviour changed or has it always printed this way? If this is new then something has likely changed on your computer. Common problem is updates for programs like Adobe Acrobat which often cause printing problems. Try printing from a couple of different programs so you can determine if all programs are suffering this issue or if it is just one program or type of file you are trying to print.
Sep 01, 2014 | HP Officejet Pro 8620 e-All-in-One...
Hl 2270 won't stop printing
I would guess you were trying to print a spread sheet or similar. It has nothing to do with the reset gear on the cartridge. You need to open your printers folder on the computer, open the print queue for the printer, and cancel all documents waiting to be printed. That may take more than one try. When you are ready to print again, be sure you know what is to be printed before committing.
Apr 21, 2014 | Brother Reset Gear for TN-450 TN450 TN420...
HP 1500 will not stop Printing
Printer of all types connet to a computer and make use of a spooling service on the computer. You may need to go into the Printers and Faxes section of the computer from the Start button and open up the printer you are using and right click on all the documents that are listed there and click on cancel. There is a relationship between printer and computer with handshaking so you need to cancel and let the printer be connected to cancel the jobs. Pull out the paper tray might be a way to have it stop printing while to cancel the jobs. The cancel or clear on the printer only affect the jobs held in the memory on the printer and then as soon as that is clear the next job from the spool comes in. Clear printer spooling and then the printer should stop.
Jan 30, 2013 | HEWLETT-PACKARD Hewlett Packard Products -...
Prinnter not printing but showing 'put custom in manual tray'
There is still a print job in the queue. Place a sheet so it prints or kill the job.
Open Printers and Faxes. Open printer. Highlight jobs and Right click > Cancel, or Documents > Cancel.
For those stubborn jobs, Right click My Computer > Manage. Choose Services and Applications > Services > Print Spooler. Right click and stop. Then start. This may have to be done from the Print Server if it's network printer. Contact IT to kill.
Nov 09, 2012 | Office Equipment & Supplies
Error message stating 8documents waiting to be printed. I cancelled them but the printer will not print new documents. there were previous documents printed and I did not want to finnish those documents so...
Sounds like a driver problem. I would try disconnecting the printer from your computer and power cycling it (unplug it for a few minutes). While it's unplug uninstall and then reinstall the print driver. If that does work email me.
panderson@cartridgeworldusa.com
Jan 14, 2010 | HP Officejet 5610 All-In-One InkJet...
Usually won't print from upper tray
These printer have a problem grabing the paper from the upper tray it might look like it was ready to print but they usally miss grabing the second sheet of paper from the upper tray.
Jun 27, 2009 | Brother HL 2140 Laser Printer
Not printing and nothing is paused or on the print list.
First of all you must let canceled print jobs finish deleting before sending new jobs, if the job is taking too long try restarting the computer with the printer on to clear the jobs this usually works if not then after restart open the printers folder and cancel all jobs here. let them finish deleting while the printer is still on (they must remain in communication during deleting jobs. Once all jobs are gone, remove the power brick from the printer for about a minute then reinsert and let the printer start up if it doesn't after a minute or so just turn it on once it finishes then try printing again.
Oct 14, 2008 | Dell 926 All-In-One InkJet Printer
Problem getting hp deskjet 6540 inkjet printer to print
shut down the printer and computer both then on only the pc and cancel allthe pending documents from it then again shut down your pc check allthe wires connected properly then on both printer and pc.it will work properly.feel free for further assistance.
Aug 08, 2008 | HP DeskJet 6540 InkJet Printer
Cancel already sent job
turn off the printer, and disconnect from computer..turn it back on, and clear all jobs from front panel controls
Mar 20, 2008 | Brother HL-2040 Laser Printer
HP Officejet 4110 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
