They both stopped working after not even 6 months
Both of my 750 GB external hard drives shut down completely. There's no blue light to indicate its on and it my laptop doesnt recognize them anymore when I plug it in it's like they crashed
  • 1 more comment
  • Chris Hingee
    Chris Hingee May 11, 2010
    Does the external hard drives have a built-in power supply or does it have a power adapter that plugs into the hard drives?
  • Chuck Gluth
    Chuck Gluth May 11, 2010
    What make/model are they?
  • Nelson Olaso
    Nelson Olaso May 11, 2010
    so what do u want/need Help about of this?..........
  • 32 Answers
Try the following:
1) Does the Power LED come on? (Y) the check the mounting slot for any pins that are bent. Did this solve your problem? (Y) Good (N) then step 2.
2) LED is DEAD, then check the circuit board on the external unit, if the caps are blown due to a power surge replace the caps with the correct Volatge (V) and Farrheid range (Mu). If this is fine then step 3
3) Does the hard drive make a clicking noise? (Y) then it can be the spindle or actuator that has packed up due to some external force (dropped or placed by a magnet or speaker) replace the drives. If it is (N) then does it make a spinning noise? (Y) then it is still working, now does the bios recognise these drives? (Y) then proceed to your windows platform, press start -> setting -> control panel -> administrative tools -> computer management -> disc management -> are they displayed there? (y) but not marked active, click the action bar next to file, select rescan, after that see if it is accessable, if yes exit to windows, if not, then right click and correct the problem by making the partition active on the selected device.
4) If the Bios doesn't recognise these external drives it could be hardware failure due to various reasons. Make sure that you checked the cables, usb slots, and that there are no conflicts in the device manager tabs.
Hope this helped
Posted on May 24, 2009
My Simpletech 500 gb external hard drive has been working fine for a long time, today it said something was corrupted and then the computer has not picked up on the drive, when you turn it on the blue...
Sorry, but that sounds pretty bad. Generally when a hard drive bricks, its done. However you can try taking it in somewhere like the Geek Squad at Best Buy, and have them try and recover all your stored data from it. Good Luck!
May 17, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
I hard drive is WD7500AAKS. it boots for few seconds only and then stops working. a blue screen appears showing system crash error. i would be grateful if you could help.
The blue screen signals that several critical files from Windows are corrupted. It's too late to repair that, you will have to completely reinstall so use the recovery cd that came with the pc when you bought it.
Apr 21, 2011 | Western Digital Caviar SE WD7500AAKS 750...
My computer doesn't detect my FreeAgent Pro 750GB (seagate)!!!
Do not despair - check out the documentation on page 3 (you'll need Adobe Reader to open this PDF file):
http://www.seagate.com/support/freeagent/FA_Pro_15_QSG_US.pdf
Hope this helps
Sep 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Simpletech hard drive not working
I have that problem similiar to yours. My simple tech stopped working for like two years so i decided to open up my simple tech and removed my HD away from the old enclosure so I can try building my own external hard drive for the first time. I bought another new 3.5 enclosure, IDE/ATA for the old HD. I put it in the new enclosure and it worked!
It's the only solution you can have. No need to retrieve data or re-format your HD. You can leave it the way you like...if you wanna reformat it...up to you.
Jan 27, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Iomega 250 GB external stopped working
This is really not a solution, but you should all try to connect your iomega to a imac, and use the Disk Utility (in Utilities folder), if you have any luck the hard drive will be recognized and you will be able to format it
Dec 18, 2008 | Iomega (33215) 250 GB Hard Drive
Segate FreeAgent 750GB external hard drive
my iqube extenal hard drive is not working was dropd down, I have tryed plag and play and it shows the light and fun inside working and when you staart uyou can ear like its start but stops after few seconds
Oct 15, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Drive not recognized by desktop.
Try checking your power cord adapter.
I found the same problem was with the cord.
Luckily, I had another Acomdata HD cord to check the problem.
Aug 25, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Turns on but nothing else
I have been using this hard disk for about 6 months now. It stopped working. The power and the usb cable are connected. I use Windows Xp and it doesnt read it. And for some reason most of the time when i open 'my computer' and the hard disk usb cable is plugged in 'my computer' stops responding !! However the 'safely remove disk' icon comes on the task bar and i can remove it from there. But i cant read it from explorer. The light on the HD keeps blinking. It reads my friends HD and flash drive. Please help me.
May 23, 2008 | Western Digital My Book Essential 500GB...
Computers & Internet Logo
106 people viewed this question
David Payne
David Payne
