Question about Samsung 731BF (Black) Monitor
731N monitor I have the 731N model and right in the center of the screen is a rectangle (dark blue, lighter blue border) and inside that rectangle is the word BRIGHTNESS and then a thin box with an orange stripe and the numeral 100 to the right.  It comes back constantly, goes away after 30 seconds or so and comes right back.  I cannot figure out how to dremove it, it doesn't respond to the mouse.  Button on the bottom of the monitor do not work to remove it.  Please help.
  • 7 more comments
  • Anonymous Nov 18, 2007
    Have the same problem.
  • malificnt Nov 19, 2007
    no idea how to fix - i tried new drivers, resetting image and color to factory default and pulling plug to reset. Nothing has worked, next step is to call samsung.
  • ciila Jan 04, 2008
    on my monitor a square box pops up with the brightness stay on for about 30second and sometime it don't go away.
  • pll8on Feb 11, 2008
    Monitor settings menu keeps popping up and is usually for
    brightness/contrast settings. Read the auto-adjust info on the
    CD but can not stop this annoying pop up problem.
  • artfox Mar 03, 2008
    Same problem - "Brightness" control notice in box suddenly appeared today 3/2/08 and won't go away. Controls on front of monitor stopped responding. I turned off computer and unplugged monitor, then reconnected and restarted - nothing helped. Monitor is about 1 year old.
  • ifrinimc May 20, 2008
    I've had the same problem with the 731N auto adjust brightness ... twice.
    I called Samsung ... they sent me a replacement that does the same thing.
    I run dual monitors and swapped top confirm ... the problem follows the monitors. It was/is the monitor.
    Last Samsungs I'll buy. Pieces of garbage.
  • D2383 Jun 08, 2008
    The Brightness screen stays on constantly. Sometimes if I hold the Auto button down for a long time it will turn off. Mostly it doesn't. I've tried blowing out the vents and it did allow me to turn the monitor off. Before the monitor would not turn off at all.
  • rizzolaverne Sep 13, 2008
    This just started today, (9-13-08) and we have had heavy rain and it is rather humid. I hope it does not continue after the humidity dies down.
    I bought this I bought this in early 2007 and I really hoped it would last long than this. We always shut off the monitor to prevent the "burning" of an inage to the screen. We took good care of it.
    I won"t be buying another samsung monitor.
  • Anonymous Jan 05, 2009
    it makes me crazy... it's non stop popping.. what should i do.. it really annoys me..
Posted on Sep 15, 2008
My samsung monitor pops the "brightness" menu up every thirty seconds or so, and it's making me really mad. There's nothing I know of that can fix it. It's about to go sailing six stories out my window...
Posted on Jun 15, 2008
The higher the humidity the more often it occurs even to the point of never going off at 85% relative humidity. Why does Samsung make this stuff?
Posted on Jul 08, 2008
The Samsung 731N monitors use the ILPI-013 power supply board. The capacitors on this board can cause the issues you are having when they start to fail. Here is a link to some information about replacing the capacitors on the board and repairing the unit.
I hope this helps.
Jul 01, 2012 | Samsung SyncMaster Computers & Internet
My monitor menu on my samsung syncmaster 731n keeps popping up on the screen and I cant get it to stop
this is a normal condition for that kind of monitor, because it was design only with Samsung syncmaster 731n in which the old model. The reason why it always popping up is because it always adjust the setting of the images. The only way to solve this problem is if this menu appears again you only press the reset button there at the left side of the power button.
Aug 31, 2011 | Samsung SyncMaster 720N/731N
Brightness bar stays in the center of my screen Samsung SyncMaster 731N
I'm Adam and i'm a computer-technicien!
I should do these 2 things do hide this brightness bar:
-You can click the MENU button again!
-You can simply disconnect the power-cable from the monitor and
let it unplugged for like...10-15 seconds!
-You can remove the button with a screw-driver and take the
little plastic on the second button.
If this all doesn't work...
I can recommend you to send a email to SAMSUNG with this info:
-Date when you bought this product:
-When did this start:
-And your CPU information:
If this all doesn't help...
You ned to install a driver called 'Syncmaster 720n/730n driver'!
Thank you,
May 25, 2011 | Samsung SyncMaster 720N/731N
How do I increase the size of my desktop and remove the blue border?
There are three size settings you can choose from, Normal, Wide and Zoom. Try changing it using the 'Size' button on the remote or by going into the On Screen Display (OSD) settings. If you don't have a manual you can get one here. Hope this helps.
Mar 14, 2008 | Samsung 192MP (Silver) 19" LCD Monitor
Philips 107C55
no its not a virus the problem is your monitor itself.try to contact an expert technician of monitor.i think there is a part of your monitor that is already defective.
Feb 16, 2008 | Philips Brilliance 107 17 in. CRT Monitor
Picture is not centered on monitor leaving a 2 1/2" black border on Philips LCD
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Nov 13, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Samsung 731BF (Black) Monitor Logo
355 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
