Question about Maytag Neptune MAH5500B Front Load Washer
Power went off in the house and the washer won't start up
I tried to start the washer after we had a power outage. The washer won't resume washing. What do I do?
  • mamamo37 May 24, 2009
    Thanks so much!
    I did what you said. Turning completely off and then on again and that was all it needed.
    You are wonderful!
  • KEN LaPOINT
    KEN LaPOINT May 11, 2010
    Did you attempt to restart the cycle?
  • 10,865 Answers
It is likely that the circuit breaker or fuse which sends power from your electrical panel to your washer overloaded when the power came back on and either kicked if it is a circuit breaker or blew if it is a fuse.
Look in the circuit panel. If you have breakers look for one that is about half way off. Turn it on and all the way off and back on again to reset it. If you have fuses look for a blown fuse and replace it with the same amperage fuse as the one in there now. good luck and let me know as if this isnt the problem I have additional steps for you to take. I want to help you get your machine up and running so let me know.
Posted on May 23, 2009
  • Joe Hogan May 24, 2009
    Hey there Mamamo.... thanks so much for the kind words. You made my day! Have a grand holiday! If you ever need assistance again come back!
Washing machine does not resumes from where it pause after the power cut. Washing machine model is WAX16161IN. Is there any fault?
it would be unlikely to have a memory setting
normal machines start at the beginning and work through the program
if there is a reason for the pause 9 out of balance , door/lid opening or just pause to go out) that would be held because there is still power to the program board
however on a power outage , it would not know where it was at in the program
Jun 06, 2016 | Washing Machines
Amana front loading washer won't run after power outage. Panle does light up.
Possible that the program controller unit has failed if there is no display or power in the indication. You will need to remove panel to check on the fuse and if the new fuse fails it is possible there are error or hardware failure within the board.
Please remove and check the power panel for shorted drive, rectifier or capacitor, if not the panel must be replaced.
Jul 04, 2012 | Amana Washing Machines
Power in house went out. T.V. wont turn on.
Did you have a surge protector on the TV? Have you tried unplugging it for 5 minutes, if not try that. If it still won't work contact your local electrical power provider and start a claim for damages from the power outage.
Jan 24, 2012 | iLO Televison & Video
My maytag washer mah5500b would not start after a power outage. it displays a code "do" and that's it. could you please tell me how to fix this?
power outage should not have caused this / but the do is (door) code it either didn't lock . or is unable to lock . the latch assem may have to be leplaced . try turning power of /just unplug and plug back in and try to program .. if it doesn't i would repl door latch .. pls feed back mm
Dec 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
My power to the house went out. now my printer
That outlet may have been blown from the power outage. Try changing the fuse in your fuse box or reset the breaker
Nov 27, 2009 | Lexmark Z735 InkJet Printer
My Maytag Neptune washer stopped in mid cycle because of a power outage. Now it will not complete a full cycle. When I open the door, there is a pool of water in the tank. I have unplugged it, started it...
Try spin only cycle. Should drain water then spin. If that doesn't work it may be the power outage started as a power spike and fried your control board. Good luck.
Mar 01, 2018 | Maytag Neptune MAH5500B Front Load Washer
Had power outage and now the Neptune Washer won't even light up. Washer was not in use at the time. Checked the breaker and outlet and all live and functioning. Is there a reset button that will reset the...
no! did the porew surge when it came back on,like the lites in the house went briter than normal/may have damaged main control board in top console.you will also fine a tech sheet up there.see if you can get some glues their.God bless.tom
Dec 28, 2008 | Maytag Neptune MAH5500B Front Load Washer
Power out when running. showed code F 71 now not working.
After power outage that will happen do this to fix.
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
Dec 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 has power but not starting wash.
for service.
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag washer not reset after power outage
The magnetic switch was stuck due to power outage / contactor are spark connect the contactor stuck together .Magnetic switch to replace.
Jan 09, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
412 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
