Question about Toshiba SD-3990 DVD Player
No disc message appears
When I try to play a DVD, it will not read the disc and only says "no disc." It has been working fine until now.
  • 11 more comments
  • Anonymous Nov 03, 2007
    i had the same problem. had to return and they sent me a new one. fortunately it happened within the year i bought.
  • Anonymous Nov 09, 2007
    same problem. working fine up until 2wks ago, I got this player 10-months ago. calling toshiba tomorrow, hope it has a 1-yr warrenty!
  • Anonymous Nov 13, 2007
    I get the "No disk" message all the time... When I removed the cover, I noticed that DVD was not rotating (just a few jerks at the beginning, then nothing). I called the Toshiba service center (?), and they told me that it could be the laser problem...
    Victor
  • grammyp Nov 21, 2007
    I put a dvd in my Toshiba player. I got a "no disc" message. I tried another new DVD and got the same message. I tried spraying air into the player. No change. I wiped off the DVD. No change. Same "no disc" message.
  • scott Nov 30, 2007
    it says that it will not load a disk and the DVD player flashes bad for all dics that are put into the player
  • Anonymous Jan 28, 2008
    Same problem - bought 5 months ago and that fix worked for me! As it turns out you only need to reseat the main cable, not all of them. THANKS!
  • TomT7461 Feb 23, 2008
    I'm getting a "No Disc" message- plaayer is a year old- never had the problem before
  • Anonymous Mar 03, 2008
    i had the same problem. thanks to the instructions here. i opened the
    unit and just fiddled with the wires, and it started working.
    Deepak
  • Anonymous May 18, 2008
    ccs
  • sean92656 May 18, 2008
    no disk
  • Anonymous May 29, 2008
    All of a sudden, after working fine, either a no disk or bad disk note comes up. If you keep reinstalling a dvd, it might start playing but the picture is poor and drops out and in.
  • Anonymous Jul 07, 2008
    i keep getting a "no disc" message
    "no disc" message
Just re-seating the flat cable, many times, didn't work for me. Instead, I very carefully cut about about 1mm off the end with a straight, smooth edge scissors. Then I plugged it in, pushed the clip down, and it worked! Be sure to cut straight, or the fine pitch contacts might not line up.
Posted on Jul 07, 2008
I also had the No-Disc problem. The disc was not spinning in the tray. My solution was a take on reseat the ribbon cable solution. I tried simply reseating the cable, but that did not work. When I removed the cable I noticed discoloration on some of the pins. Instead of cutting of the end of the cable, I soaked a Q-Tip in rubbing alcohol and cleaned the discoloration and re-inserted the cable.
Posted on Aug 24, 2009
Hey
try opening the unit, and remove the ribbon cable from the mainboard that leads to the dvd drive assembly, then reseat the ribbon. worked like a charm for me.
Posted on Nov 25, 2007
Reseat the Ribbon baby Just worked
Posted on Jul 25, 2009
Used a combination of JoeyJoeJoes & AmGold. No cutting just cleaned and replaced. Thanks to all
Posted on Mar 11, 2010
I unseated all connections between the board and drive and still had the same problem, "no".
Posted on Aug 08, 2009
Re-seating the cable didn't work for me either, but carefully cutting a small portion of the end of the cable and then reseating it (as xr704 suggested) fixed my problem.
Posted on May 26, 2009
  • klevier May 26, 2009
Re-seating the cable didn't work for me either, but carefully cutting a small portion of the end of the cable and then reseating it (as xr704 suggested) did the trick just fine... for the few next months at least!
Posted on Jul 11, 2008
Yep i straightened out the ribbon kinks and tried it. so far so good. although i've found it gets confused with live cds and cuts off the end or beggining.
Posted on Jan 21, 2008
Joeyjoejoes solution is what worked for me but it wasn't as simple. I had to completely remove the optical drive, disconnecting all cables, and reinstalling the drive THREE times to get the player to work again.
I think the problem is the cheap ribbon cables Toshiba is using. After reseating them several times, the player is now back in action.
Posted on Dec 16, 2007
Thank you internets.
You have been very helpful in this area. My boyfriend listened to you.. and now, we can watch a movie.
Love,
christina
Posted on Jul 17, 2008
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: dvd "unknown disc" message coming up
Have you tryed to use a lens cleaning disc yet. The laser lens on these players and recorders alike, must have the lens cleaned every oince in awhile. If that does not help, most likly you have a bad laser pickup assembly and you will need to replace the plaer as to have that repaiered, you could buy a new unit. Good Luck
Posted on Mar 23, 2007
SOURCE: DVD player recorder won't read or play any disc
This just worked for me. Don't know how long it will last though. I found it on this webpage
http://forum.ecoustics.com/bbs/messages/15118/130292.html
To do a reset:
On the remote control press the SETUP button,
Press the right key on the remote 3 times,
The Preference page will show up,
Press the down arrow five time to highlight
"default", hit right arrow to highlight "reset"
Press enter to reset. Turn off/on machine, etc.
Posted on Feb 14, 2008
mrgreenz
  • 962 Answers
SOURCE: dvd playback
Clean the DVD lens with isopropyl alcohol (rubbing alcohol) and a Qtip. Be careful not to press down too hard. Gently clean the lens all around. Changing Qtips if you see anty signs of debris or dirt on the tip.
Posted on Feb 06, 2009
SOURCE: dvd player keeps saying no disc when I try to play
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would read.now it just wont read. any ideas?
Posted on Oct 13, 2009
How can I play a disc reading incorrect and error It worked fine this morning
Try some other discs first or try that on another player, usually if cannot read the disc either a dirty of bad Optical Pickup in the player.
Dec 16, 2012 | Toshiba SD-V291 DVD Player/VCR
Dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would...
Oct 12, 2009 | Cyberhome CH-DVD 300 DVD Player
Can not read disc
I mainly use my DVR to record TV shows on DVD-RAM discs (Panasonic brand or Maxell). I've had no problems with the DVD-RAM discs. However, today when I put a DVD-R disc in the recorder, I got an "Incompatible Disc" error message. I tried a second disc from the same set, and got the same message. I tried out some of the DVD-Rs that I recorded last year and I could read them. Tried a DVD-RAM. That was OK. So, I tried another DVD-R disc. That one is OK. I don't know if the problem is that these DVD-Rs are getting a little old (2 years??) or if the recorder is developing its own problems reading discs.
Dec 03, 2008 | Panasonic Diga DMR-EH75V DVD...
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Error message when reading DVD
Try changing the region setting to region free.
1. Make sure there is no Disc in the tray.
2. Shut off the unit and unplug it from the AC outlet.
3. Press and Hold the "Play" and "Open/Close" keys,
simultaneously on the player and not the remote control.
4. While holding these keys, plug the AC cord back into the outlet. (TEST and CPU ver# will appear on the display)
5. Release the "Play" and "Open/Close" keys.
6. Press DVD Menu twice on the remote.
7. When the display reads s000 5858 use the up and down buttons to change the 000 to 02E.
8. Using the Left and Right arrow buttons, change the last four digits until they read 0000 for Region Free, 0101 for Region 1, 0202 for Region 2 or 0404 for Region 4.
9. Press Enter on the player.
10. Press Standby and wait 5 seconds.
11. Press Standby again. Your player is now set to the region you requested. If you find some titles do not play on the region 0 setting, you may have to hard select the appropriate region.
Good Luck. Let me know if it works
Jan 09, 2008 | JVC XV-S300 DVD Player
SAMSUNG DVD R120 error EC:0207
I had exactly the same problem -- error message of "This disc can be neither played nor recorded. Please check the disk [EC:0207]" after the machine had been working fine for a year. I downloaded the latest firmware from the Samsung website, burned it to a CD-R disk (took three tries until the DVD Recorder recognized the disk -- worked when I used Rocio CD Creater software), then loaded the firmware updates to the DVD Recorder. On the Samsung website you can retrive the firmware update instructions as well. I had to perform the firmware upgrade several times until it successfully updated both the system firmware as well as the disk firmware. After successfully updating both, the Recorder now recognizes the DVD-R disks and I was able to resume recording. I have however, noted some choppiness with the playback of the newly recorded disks. Other than that, the firmware upgrade successfully resolved the problem.
Oct 29, 2007 | Samsung DVDR120 DVD Recorder
A message appears saying "no disc" and DVD are not recognize anymore
If this unit has a built in DVD player, then the player's lens may need cleaning. There are lens cleaning discs available for this. If the unit does not have a built in player, then the same applies to your player & there is no problem with the projector itself.
Jul 10, 2007 | Optoma MovieTime DV10 Multimedia Projector
'CANNOT PLAY' message
disc may not be spinning due to motor failure. remove top and observe is disc is spinning or not. my sony dvp-ns41p failed this way
Jun 10, 2006 | Sony DVP-NS575P DVD Player
Toshiba SD-3990 DVD Player Logo
2,055 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
