Question about ASUS Eee PC 701 Notebook
Advanced in advanced i found these options 1) IDE CONFIGURATION a) ide master b) ide slave 2) ON BOARD CONFIGURATION a)usb ports b)usb controllor c)on board LAN d)on board audio e)on board WLAN\ f)on board camera g)on board card reader no idea wat to do WHICH ONE SHOULD I FOLLOW .....
  • Roberta Smith
    Roberta Smith May 11, 2010
    depends on what you are trying to accomplish
    President:
  • 2,004 Answers
Go to control panel and look around for system mentainance, click the restore option and run restore to factory setting.
Posted on May 23, 2009
How do you connect the cables or jumpers?
the leads from your ((motherboard to your hard drive)) they might have a 40 pin on the hard drive or a sata they just push on to make a connection make sure they have a secure connection
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
?don't forget to vote
Feb 08, 2011 | Western Digital Caviar SE WD3200JS...
What are the 2 pins in the back for? master slave configurations? If so what jumper setting makes it a slave?
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
hope this helps
dont forget to vote
Feb 06, 2011 | Hitachi Deskstar 7K160 HDS721616PLA380 160...
I need to put my hard drive into an enclosure but I cannot figure out if I need to switch it to a slave before adding it to another computer
i have done this alot for my customers and its really simple. if you look up your drive and get the jumper settings for it and set it to cable select or master in a one drive enclosure it will work well. i do not recommend putting it on slave because some enclosures will not recognize the drive, I do recommend having an enclosure with a fan on board and an external power switch. the reason it the fan will extend the life of the drive and the power switch eill allow you to power it on and off without having to flatten (power hot swap) the drive. Hot swap is ok but this is better than just unplugging the drive. removing the power from the drive keeps the drive in park until you re-power. as long as the drive is "parked" it is les likely to cause read/write sector errors.
If you have any problems let me know and please leave positive feedback for me. Jethro
Feb 01, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Is there a slave or master switch on the hard drive want to hook up a external hard drive enclosure
hope this helps
Jan 29, 2011 | Hitachi Deskstar 7K500 500 GB Hard Drive
What is the position of the link do I need to change to master/ slave etc
hope this helps
Jan 28, 2011 | BenQ CRW-5232W 52X32X52 IDE CD-ReWriter...
Hd western digital wd800jd - preciso do manual do hd. e tambem configurar jumpers. grato!
hope this helps
hope this helps
Dec 10, 2010 | Western Digital Caviar SE WD800JD SATA...
Blue screen arrives ...system not working
At bootup press F9 to restore to factory condition
May 23, 2009 | ASUS Eee PC 701 Notebook
945GCT-M/1333 recognize Primary IDE Master as IDE 3 Master
Hello. Some motherboards set SATA1 as IDE primary master, for compatibility. Try connect the DVD RW to SATA2 or SATA3 Port.
Feb 26, 2009 | Computers & Internet
ASUS Eee PC 701 Notebook Logo
115 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
