Question about E-Machines eMachines Desktop PC
Model 333cs How do you get to set up.
I JUST GOT THE COMPUTER, i REPLACED POWER SUPPLY, ALL WHEN i PUSH THE start button, the fans work, I hear hd turning, but I don not see any ram check going on the screen it just comes up and say that one liner. hoe do I get to set up on this computer. it is a emachine 333cs.
  • 1 more comment
  • snackdude May 23, 2009
    I tried them all, just not the right one yet.
    All I see on the screen is ( ATI MACH64 SDRAM BIOS 3.089 ) ANY IDEALS.
  • snackdude May 25, 2009
    I unpluged the keyboard and the mouse, then turned it on, it come on and said, push F1 to go to setup, but had to turn off to plug mouse and keyboard back in, turned it on and went to setup made a few changes and booted fine, not sure what was wrong. Thanks for your help.
    Brigadier General:
  • 5,158 Answers
Computers are all different for entering setup. f1 f2 f10 or f11... sometimes it's just the delete key that you hit .... do that as soon as you turn on the power... one should work
Posted on May 23, 2009
  • Roberta Smith
    Roberta Smith May 24, 2009
    try tapping on the tab key as you boot up
Gateway gt4016 wont turn on you can hear the fan and light flicks on for a second but then nothing changed the power supply nothing
try rebooting your coumpter is in sleep mode it takes a long time but you will get it back on .... keep pushing the power button aventally it will start up
Jun 30, 2012 | Gateway GT4016 Desktop PC
My computer(desktop) seemed to freeze up so I shut it down by pressing and holding the power button. I rebooted and the monitor says "no signal" and goes blank. I hooked my monitor up to my...
Could be RAM memory, Video/Graphic card, HD, power supply - your description is not that clear.But at least you know where to start.Can you hear fan working,or are there any lights on your power supply?Can you hear Hard drive starting?Open the tower and check memory modules - take out one at the time and try-sometimes changing their places will do. Good luck, and keep us posted.
Nov 17, 2010 | E-Machines eMachines Desktop PC
Fan works randomly....when it's not working plug
Hi, If the computer is hot near the electrical plug in the back of the computer then the power supply needs to be replaced. This will also cause overheating problems if the fan does not exhaust enough air. You should not run the computer in this condition because the power supply can short out and take other components with it. Also there is a risk that it will burn up. Power supplies are very inexpensive and can be changed by anyone with basic computer repair knowledge. Hank
Jul 26, 2010 | eMachines T5212 PC Desktop
No start up. push power button can hear a sound like a relay turning off.
sound that power supply is dead.
probably you need to replace the power supply...
Jan 08, 2010 | Dell W4200 42 in. HD-Ready Plasma...
I have a gateway 506gr with a Bestec atx300 psu. I was having problems being able to turn the computer on, then one day it would not turn on at all. I can push and hold the power button, and hear the psu...
Your psu is works fine.
First open cpu cabinet and find motherbord.
Pull CMOS cell from m/b for 10 minutes.
Refix RAM Memory.
Pull procesor fan and processor clean dust from all parts.
Then fix processor fan and processor.
Reconnect ATX connector to m/b.
Remove pci cards from PCI slot then check.
Let me know if you need more assistance.
Thanks.
Oct 01, 2009 | E-Machines Bestec ATX-300-12E Rev. D 300w...
Emachine wont start
remove all external and internal peripherls.
example for external: mouse, monitor, keyboard, printer.
Internal: hard drive, memory modules, video cards, modem (if there's any), optical drive or dvd drives.
just leave the motherboard, power supply and processor intact, try turning on the computer with out those components mentioned. see if you get a beep sound before it turns off, but if not the most logical part that needs to be replaced on this type of problem is the power supply if that doesn't work the next thing to do is replace the motherboard. hope that helps
hit me back on the results. thanks!
May 25, 2009 | eMachines T6211 PC Desktop
I'm having problems starting my desktop computer. After I push the power button, I hear the computer working but it doesn't fully com on. There's no display on the monitor and I continue to hear the...
When you say you hear the computer working and working do you mean that the fans are going and the lights are on?
i ask this because the fans and power lights can come on just from the power supply coming on when you push power but that doesn’t necessarily mean the cpu is functioning.
Do you hear a post system beep and the hard drive reading files also?
Or does it just sound like only the fans cam on ?
If you think that possibly only the fans are working then try this
Shut down the computer and unplug the power cable.
Check to make sure monitor cable is connected all the way
Open the case and check to see that the video card is inserted all the way into the board properly
Remove the memory (RAM) and then put it back in to make sure it is properly seated in the slots
Plug in computer and try it again and if it still does not work then try clearing CMOS
on some systems you can clear the CMOS very easily by just holding down the insert key on your keyboard while pressing power button and continue to hold it down when releasing power button until you see something on the screen but since this does not work on all computers you might have to do it manually by moving the CMOS jumper on the board
(the CMOS jumper on the motherboard is usually the one closest to the little battery that you see on the board. with the computer off move the jumper over one notch to the other pin for a second and then put it back where it was (there are usually only three pins so this is easy step)
You should now be able to boot but you will need to go into the CMOS setup and set the clock again and other settings
If you still have a blank screen then let me know and i will take you to the next diagnostic step...
Hope this info helps
Nov 19, 2008 | Computers & Internet
Won't boot up, Fans are on non-stop
Open up the pc with power off. After cleaning with a blowing or sucking device, gently press on the connections and plug-in devices. Retry.
If no avail, the power supply or the motherboard may have bit the dust. U can get them repaired or replaced.... or save the HD and buy a another pc and add the old HD as a data disk.
May 11, 2008 | Gateway GT5056 PC Desktop
My computer won't start! It was shut down by the start menu and when I went back to it about an hour later, I push the button in to power the computer on and nothing is happening. Yes, it is plugged in...
Unplug it and hold the power button in for up to 60 seconds to discharge.
Is there an I/O button in the back of the computer? Make sure it is set to I.
Apr 10, 2008 | Computers & Internet
Emachine eTower 333cs restore Cd does not reload on HD
when you cleaned the HD you did eraser some of the software that was on the hardrive that is need to do the Quick restore and know the only way to fix this is to installe a new copy of windows and look up the drivers for the motherboard.
Oct 13, 2007 | E-Machines etower 333cs PC Desktop
E-Machines eMachines Desktop PC Logo
71 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
