Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door opener won't open garage door
Our car slid into the garage door. the car nor the garage door was hurt but now the door won't open the overhead light flashes and you can hear the door trying to open but nothing happens. the over head light stays on. you can manually open the door. the opener is a craftsman i/2 hp. we have tried unplugging it hoping that it just needed to reset but it didn't help the overhead light flashes and nothing happens. the over head light stays on. you can manually open the door. the opener is a craftsman . we have tried unplugging it hoping that it just needed to reset but it didn't help, also checked the sensor and they are ok
  • Steve Brown
    Steve Brown May 11, 2010
    does the motor on the opener run and the chain move but the door won;t come up?
    there is a safety lever near the front that if pulled unlatches the chain drive. make sure it is latched in locked position and try it again.or unlatch it and see if the chain drive works.
    If it doesn;t workj at all it possibly is jammed somewhere start looking for that.
    if it comes on and acts like it working but does nothing look at the sprocket shaft and see if a keyway snapped.
    President:
  • 3,197 Answers
Remove the cover and take a look at the drive gear. It sounds like it is stripped.
Posted on May 26, 2009
2 Suggested Answers
  • 548 Answers
SOURCE: garage door opener won't open garage door
did you use the manual release to unlatch the door from the opener? You may have a problem with the door binding and opening it manually will confirm that. You may also have misaligned the sensors at the base of the door so check that too.
Posted on Feb 06, 2009
My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
Feb 22, 2012 | Sears Craftsman LiftMaster Chamberlain...
My liftmaster garage door opener will open the garage door but won't close it from the wireless remote in my car. what could be the problem
Check your door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering ever so slightly. Tweak them a bit. If you cannot get both lights to light you have bad sensors.
Sep 12, 2011 | Sears Craftsman LiftMaster Chamberlain...
Wireless keypad won't accept our original code. Door won't open. When I enter the code the backlight on the keypad blinks rapidly. I need help. I have no other way to get in my...
Sounds like the receiver in your opener has quit working. Unless you break in you need to call a door technician. They can drill a hole in the door, use a special tool to pull the manual release and open the door. You should then have them install a keyed manual release if this ever happens again. They can also repair or replace your opener.
Jun 20, 2011 | Sears Craftsman LiftMaster Chamberlain...
My nephew kept opening and closing my garage door, now the door won't open with the opener and I can lift it by hand. I tried pulling the cord to move it back to electric but it won't work... any...
The motor has a thermal protector that will cause the motor to quit when it gets hot. If you let it cool off it will automatically reset and should work again.
Jun 16, 2011 | Sears Craftsman LiftMaster Chamberlain...
Feb 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't open
You probably have a broken spring on your door
Nov 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,052 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
