Question about Garden
Craftsman 6.6 self prop lawn mower
Restarted after winter but will not get to full rpm. just barely idles seems to be a carb issue
  • KEN LaPOINT
    KEN LaPOINT May 11, 2010
    did you replace the fuel in the tank or just use the existing fuel from last season? Gas has a "shelf life" and will start turning unusable after a period of time. Try draining the tank, the carb, and if you can, remove the carb bowl and wipe it clean.
    Then refill with new gas... you can also buy a conditioner that will allow you to store your mower with the gas in it each season... used it on our boat with great success..
  • 10,865 Answers
Yes it is a gummy carbeurator. Put in fresh gas if you havn't already and put in a new spark plug. Then get a can of carbeurator cleaner and follow the directions to get your carb up and running again. While you are at it I would also install a new air filter.
Posted on May 23, 2009
Where is the rpm and idle screw located on a 2005 Craftsman riding mower
place throttle control to full throttle. loosen the clamp on the throttle cable at the carb control. pull the cable tight and retighten the clamp. That is your adjustment for full throttle. The idle screw is located on an external tab on the end of the throttle shaft.
Sep 01, 2014 | Garden
Why does my craftsman 2-cycle model 316.791860. Gas trimmer die?
Those little carbs clog very easily and what you experience is a common symptom. Go to any bog box home store and in the mower area pick up a can of small engine carb cleaner.
Remove the carb, take it apart as far as you comfortably can and soak all pieces in a can/jar of CLEAN gasoline for 10 -15 mins. Agitate to get the gas moving.
Remove the carb, and drip clean then use the carb cleaner to blow out every port you can see. reassemble and install the carb, it should work fine.
Before storing for the winter drain all gas from the tank and start it allowing the machine to run till it stalls out due to no gas. You should be fine for next season that way.
Apr 27, 2014 | Craftsman Convertible 25cc. Gas Line...
I HAVE A CRAFTMAN LAWN MOWER 6 HP SELF PROP RUN FOR 2 OR 3 MINUTES ONLY I CHANGE THE OIL GASOLINE AND S/PLUG CAN YOU HELP ME TO FIX IT?
It sounds like you have a bad Ignition Coil (Module). This is how they act when they start going bad. When they get warm, they quit. Some will last up to 20 minutes before they shut down. You can sometimes find a used one pretty cheap at a small engine shop.
Jim
Aug 07, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
I have an old Craftsman 286707 riding lawn mower that will turn over but not start - ideas of where to look - it worked fine 4 days ago for the first time this season but took about 5 tries
Did you have gas in it over the winter? I would try some starting fluid and see if its fuel related or something else.. If it will run with a little starting fluid for a minute then you have some kind of fuel issue.. Gas with ethanol blend is bad for carbs over the winter. .. I would use some really good fuel stabilizer once you get it working again.
May 05, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My Craftsman 675 190cc starts in full throttle what could be causing this
sounds like the carburetor is a little gummy and when the engine shuts off it goes to full throttle by the govenor for easy starting but is supposed to return to the set 3600 rpm. try spraying carb clean on the carb and wiggle the govenor arm to make sure it move freely
Feb 23, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
8 year old Eagle I Craftsman 6.5 starts and quits? Help!
it sounds like a gumed up carb strip the carb and clean out all the running jets with carb cleaner,,,dont go poking wire into the jets you will only distroy them,,,also check that the air cleaner is clear if its cloged up the engine cant breeth and wont rev up and it will be running very ritch as well,,,check you have good flow of fule from the fule tank,,,winter takes its toll on garden tools that are stood up most of the time
Jul 10, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Lawn mower will not start and run
Sounds like a clogged carb or a cracked primer bulb. I would install a carb rebuild kit and new primer bulb if your mower uses one.
May 18, 2009 | Craftsman Garden
When my 20hp Craftsman lawn tractor cranks it does not quit pumping gas in to the carburator, and floods it out - what do I need to look for??????
Sounds like you have a Float in the Carb has a hole in it or it is getting stuck open there is a needle valve that it pushes on when the bowl is full and it sounds like its not or something is stopping it,, did it have gas in it all winter? ,, I would buy a Carb kit for that model and change out all the parts that come in the kit and clean the carb
Apr 17, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
98 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
