Question about ASUS Eee PC 701 Notebook
How can i run system restore ....its a linex system....i cant
Find any restore option....when i press F2 it shows me 5 options
1)main
2)advanced
3)security
4)boot
5)exit
i cant fint any retore option in all these options
please tell me asap
  • oasisofrose May 23, 2009
    i dont know wat happened to it.....noo i didnt make and system restore before there is no option like last good known configuration...i dont know wat to do....and bio comes when i tap F2
  • Dan Todd May 11, 2010
    What happened to it? Did you make the system restore disks when you first got it?
    Reboot it and begin tapping F8 until you get to a page with several options. You can choose "Last good known configuration"
    President:
  • 2,004 Answers
2 advanced
Posted on May 23, 2009
  • Onifade Adewunmi
    Onifade Adewunmi May 23, 2009
    why did you down rate me?
    murphybanton
What do I do when I turn on my Dell latitude xt
There could be a hdd issue or a simple damaged file. Try recovering the system.
Unable to Access the Desktop. 1 Restart the computer.
2 Tap during startup until the Windows Advanced Options menu appears. If the Windows Advanced Options menu does not appear, restart the computer, and try again.
3 Press the until Repair Your Computer is highlighted, and press .
4 In the System Recovery Options window, log in as a user with administrative rights, and click
vista_button_left.bmp OK vista_button_right.bmp . 5 In the Windows Vista Recovery Environment, click to select your language, and click
vista_button_left.bmp Next vista_button_right.bmp . 6 Click System Restore.
7 In the System Restore window, click
vista_button_left.bmp Next vista_button_right.bmp to display the most recent restore points in chronological order. 8 Click the Show restore points older than 5 days check box for a complete listing of restore points.
9 Click to select a restore point. A good starting point is to attempt to restore from the most recent restore point. If this fails to correct the problem, then try the next oldest restore point until the issue is resolved. Any software installed after the selected restore point needs to be reinstalled.
10 Click Next and then
Knowledge Base
Sep 16, 2014 | Computers & Internet
I have an aspire one netbook windows 7 has stopped working after error msg i am left with a black screen and white curser, i know i need to reinstall os so I have bought an external unit to do this but all...
to solve your black screen with just cursor
1. disconnect all (external) devices on your netbook 2. remove battery and adapter then press and hold the power button to drain flea power for about a minute 3. put the battery and adapter back in. 4. power on (as soon as you hit power button tap "F8" key) 5. advance boot options>safe mode (after loading still black screen and just cursor: press alt + ctrl + del then access task manager - new task > run > explorer.exe (should bring up your desktop) 6. access system restore under start > accessories > system tools > system restore 7. restore to an earlier time
to solve your re-installation of OS
1. boot to bios by pressing "F2" or "Del" (depending on your manufacturer) 2. once in bios look for restore defaults 3. save and exit 4. boot options under "F12" highlight media drive press enter and continue pressing enter until you see windows loading screen
Mar 23, 2011 | Computers & Internet
Toshiba nb300 won't boot. PXE-E61 media test failure. check cable.
Hi,Thanks for using fixya,
Remove the battery, and unplug the A/C adapter and hold down the power button, for 40 seconds.Soon your laptop will reset,and run well.Now you will install all the accessories and start.
If the problem is same please restore it ,
System Restore WIN XP systemrestore2 Backing up-System Protection and System Restore in Windows 7 Windows XP System Restore Is Easy to Use Use System Restore to Undo Changes if Problems Occur Using System Restore in XP - How-To Geek
System Restore in Windows 7 http://vlaurie.com/computers2/Articles/windows7-system-restore.htm http://vlaurie.com/computers2/Articles/windows7-system-restore.htm
Restore factorry setting.
For instruction follow the link
http://www.pcrecoverydisks.com/toshiba/toshiba-system-restore-vista/
For XP
press o (Zerro)and start laptop until start restore option
1) Hold down the power button for 10 (ten) seconds to switch off your machine.
Please note: Holding down the power button on the machine forces it to switch off. Any unsaved data will be lost.
2) Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on your notebook.
3) When the machine Starts beeping; release the 0 key.
4) When prompted by the warning screen; select Yes to continue with the system recovery.
5) Select Recovery of Factory Default Software; click Next.
6) Select Recover to out-of-box state. follow the link
http://en.kioskea.net/download/download-793-click-clean
again.
7) Click Next to Start recovery.
I hope you find this step by step solution helpful for you. If so, rate it up.
For VISTA
Pres f-8 start laptop until start restore option
RESET TOSHIBA TO FACTORY SETTINGS WITH BUILT IN BACK UP FILES
1Save your files first to an external memory storage like a memory stick or whatever u may have, plug in your laptop to the ac outlet.then....
2)Shut down your computer turn it on. then immediately press f8 repeatedly until it brings you directly to "advanced boot option".If you see the Windows Logo like "Windows Vista", you need to turn off your computer again and repeat pressing f8 simultaneously until you see the "advanced boot option" menu
4)Under "advanced boot option", highlight the option "repair your computer" and press "enter".
5)System recovery option menu will show up, select country and keyboard layout then press next.
6Then there is the option to log in as a local user so you can access recovery option,enter your password.
7)After that the "system recovery option" will show up and show these options
a)start up repair
b)system restore
c)window pc complete restore
d)windows memory diagnostic tool
e)command prompt
f) toshiba recovery wizard
8) Select "toshiba recovery wizard"
9) There will be a warning that "all files will be lost are you sure you want to continue?" Go on click whatever confirmation message u see.Al files wil be rewritten so there is nothing to worry .From there just go with the flow until recovery has finished.Your computer may restart automatically, thats normal. Hope u find this useful.Cheers
Hope this helps you.
Jan 23, 2011 | Toshiba mini NB305N410WH Netbook
My sony vaio VGN-CS22GH laptop shuts doen by itself randomly. Please help
The issue may be due to any recent hardwrae or software changes and also due to any virus.
1. Remove any recently added hardware/software.
2. Try to boot the computer in safe mode. Press F8 button soon after restarting the computer to enter the advance boot option and select safe mode to boot computer in safe mode.
3. If issue persists even in safe mode, perform a system restore to an earlier time or date when the computer was working as expected. Performing system restore will not delete any data from the computer.
4. Reset BIOS to default values. (Press the F2 key after restarting the computer to enter and access BIOS).
5. Press F3 and F4 keys to reset the BIOS. or press the right arrow key until you reach the exit menu, then select the load BIOS default option.
6. Then, select the Yes option when promted, save the settings and select yes option. restart computer and check.
7. If still persists, perform a system recovery using the VAIO Care Software or the F10 recovery partition.
Note: ensure to backup any important data before perfoming system recovery. System recovery will erase all the data presnt in the computer.
Nov 07, 2010 | Sony VAIO Notebook
My gateway laptop 4540gz cant find opp system
Operating system is the main program of the computer. It can b easily detected by your computer in boot up. So if the computer doesn't detect it, this are the steps you can try :
  1. First try to run system restore if you have one.
  2. If you don't have system restore disk, or back up disk, you can remove your hardisk from your laptop and try to connect it to other computer as an external hard drive. in that, you can copy important files and back up it in other computer if it is not also deleted.
  3. Then if you have back up your file or not, you must format your hard disk. return your hard disk to your laptop and format it.
If you don't know how to format just ask again here.
Feb 28, 2010 | Gateway 4540GZ Notebook
Freezing
So, you post a message like a telegram. "freezing". since you never mentioned any other details, i have no option to assume that its a dell some laptop. the solution which i am writing is universal and applies to all the laptops.
Before we begin: lets check if your hard drive is fine or not. follow the instructions as they are.
1. Turn off your laptop.
2. Press and Hold the Fn fey located at the bottom left hand corner, before you turn on the machine.
3. Then turn on the machine and keep the Fn button down.
4. As soon as you see, Pre boot system assesment, you can release the Fn key.
5. Let this go on, and then you would see a rainbow, press Y to continue.
Results.:
1. No problems have been found on the system, would you like to run the remaining memory test. ANSWER IS : NO. press the power button to turn off the machine.
2. Error code: - 1000-0141, 0142, 0143, 0144, 0145, 0146. or 2000-0141, 0142, 0143, 0144, 0145, 0146.
Replace your hard drive. ASAP.
Now if no error comes, then the best option is to reset the computer back to factory settings the day when you first bought it. but remember you would loose all your personal information on it.
FOR WINDOWS VISTA :
Restore the computer's software to original condition.
1 Turn on the computer.
2 As the computer starts, press <F8> on the keyboard until the Advanced Boot Options menu appears on the screen.
NOTE: -
You must press <F8> before the Windows logo appears on the screen. If you press <F8> after the Windows logo appears on the screen, the Advanced Boot Options menu will not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
3 Press the <Down Arrow> on the keyboard to select Repair Your Computer on the Advanced Boot Options menu, and then press <Enter>.
4 Specify the language settings that you want, and then click Next.
5 Log in as a user who has administrative credentials, and then click OK.
6 Click Dell Factory Image Restore.
7 In the Dell Factory Image Restore window, click Next.
8 Click to select the Yes, reformat hard drive and restore system software to factory condition check box.
9 Click Next.
The computer is restored to the default factory configuration.
10 When the restore operation is completed, click Finish to restart the computer.
The software is now installed as it was when the computer was first received.
FOR WINDOWS XP: -
2 When the Dell splash screen appears during the computer startup process, press and hold <Ctrl> and then press <F11>. Then, release both keys at the same time.
NOTE: Some systems like Inspiron Mini 9 (910) do not support System Restore as they do not have <F11> nor any substitute.
3 In the Dell PC Restore by Symantec window, click Restore. Alternatively, press <Tab> to highlight Restore, and then press <Enter>.
4 When a warning message appears stating that all data will be lost, click Confirm, or press <Tab> to highlight Confirm and then press <Enter>.
The Progress window will appear. Once the restore process starts, Dell PC Restore by Symantec usually takes about 8 to 10 minutes to finish.
When the restore process is complete, the following message will appear:
The system recovery process was successful.
5 Click Finish or press <Tab> to highlight Finish and then press <Enter> to restart the computer.
Sep 22, 2009 | Dell Inspiron 1525 Laptop
My computer wont even let me log in it needs to be wipped .. can any 1 explain in detail how to do it i dont find the restore any were in the f2 settings ....
If your computer has XP try these steps.
If you have Vista try these steps.
new_note.jpg Note: You must press <F8> before the Windows logo appears on the screen. If you press <F8> after the Windows logo appears on the screen, the Advanced Boot Options menu will not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
9 Click Next.
If this does'nt work lemme know with the version of Windows you have.
Jun 18, 2009 | Dell Inspiron 1501 Notebook
Blue screen arrives ...system not working
At bootup press F9 to restore to factory condition
May 23, 2009 | ASUS Eee PC 701 Notebook
Restoring computer factory settings
another suggestion is boot the system from your OS disk, if you have one, and repair or reinstall OS. Reinstall should not cause you to loose any files.
Jan 01, 2009 | Dell Inspiron 531s Desktop Computer
Reboot
Using Dell Factory Image Restore in Windows Vista
9 Click Next.
May 14, 2008 | Dell Dimension C521 PC Desktop
ASUS Eee PC 701 Notebook Logo
140 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
