Question about GE Profile Spectra JGBP79 Gas Kitchen Range
Oven door won't open
My ge spectra electric oven door will not open, any ideas how to fix this?
  • lucybtoo May 24, 2009
    The stove is ELECTRIC not gas. but I solved the problem by running the self-cleaning option, when it completed, the lock released.
  • lucybtoo May 29, 2009
    umm no it is not. because I don't have to turn off the gas and there are no surface burners.
    But no worries, I fixed the problem without your help.
  • GE Master
  • 3,361 Answers
The micro switch in the latch has failed.
You must turn off the gas supply.
Remove the screws from the surface burners.
Raise the lid to access the door mechanism to open the door and to replace the switch.
Posted on May 24, 2009
  • steve
    steve May 24, 2009
    Your post indicates a gas range model number JGBP79.
    Please do not give me a bad rating when the information posted is incorrect.
    Thank you.
  • steve
    steve May 28, 2009
    The repair is the same regardless of gas or electric.
General electric spectra electric oven, door doesnt close complete. Heat from the oven comes out.
please,i need help!i have a problem about my GE spectra electric oven door is loocked i cannot open at all,what i can do?to be open?
Mar 29, 2011 | GE Spectra JBP78 Electric Kitchen Range
Flashing f2 preheated on a ge-spectra
F2 fault code indicates the oven exceeded 590 degrees with the door unlocked. This could be caused by a stuck relay on the oven control board or it could be caused by high resistance in the oven temperature sensor probe.
Feb 20, 2011 | GE Profile Spectra JBP95 Electric Kitchen...
GE spectra jbp66 oven is off but F2 error comes up and oven turns on and wont turn off. ive already unhooked and rehooked temp probe and took out the plastic connector and used wire nuts instead and...
Hi There
I have found this for you to read and hope this helps you.Let me know how it goes.
F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensorThank you for writing to fix ya.
Best Regards Richard
Jan 07, 2010 | GE Spectra JBP78 Electric Kitchen Range
GE Profile Spectra Electric Oven.
call a appliance and parts store give them the tear and model number from stove it is inside the door or on back it5 mkay also be on the top under the fuse panel access door
Dec 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE spectra JBP66 electric oven that displays the F2
f 2 code states that oven has exccded 590 deg w/door in unlocked position or 990 f in locked . either the themp prop is bad or the relay in the EOC ( clock ) is welded closed . I would replace the prob first ( less expensive ) then the clock if needed .. **** ..
Dec 23, 2009 | GE Spectra JBP78 Electric Kitchen Range
Do you kep door closed when broiling
Hi, yes, your oven door should be closed , at all times whenever you're using it, otherwise your home will become oven, use oven thermostat to maintain temp, door should be closed, especially on broil. knob you turn, to light oven is also a thermostat. good luck.
Aug 10, 2009 | GE Spectra JBP78 Electric Kitchen Range
Www.ge.net How to get rid of flashing lock door on JGBP35
There is a button on the left upper corner by the door when you open oven. Hold the button down and press the clear button on the panel till the display clears itself. Just like that you have a functional oven.
Jun 25, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Trying to remove oven door
ge spectra elec., how to remove the oven door
Jan 30, 2009 | GE Spectra JBP78 Electric Kitchen Range
GE XL44 pilot
I dont know if you recieved an answer yet but this is a fairly easy fix. Open your oven door and remove your bottom oven plate. You now should see the burner element running down the middle. at the rear of the burner element is the ignite r (small porcelin bugger with two wires) remove this and replace with a new one GE #WB2X9154 available from the repairclinc.com website for 69.80 plus shipping. i just ordered (2) they seam to go out like clockwork every 2-3 years. To be safe unplug your ovens 110 volt cord first.
Good Luck
Jim
Aug 05, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP79 Gas Kitchen Range Logo
374 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
