Question about Fisher and Paykel IWL12 Top Load Washer
Fisher & paykel top load washing machine will not power up
I press power button, nothing. I unplug the washer and plug back in and the lights on circuit board come on and go and off and the electronic notes cycle like normal but then nothing. I have checked input power and it is good. This has happened before and leaving it unplugged for a while worked but not this time. It is an ecosmart.
  • coco1714 May 23, 2009
    I found the problem. The P/B was not lining up with the button on the circuit board. I used my meter lead and started the washer. How do I keep this from happening in the future?
SOURCE: Fisher and Paykel EcoSmart GWL15
tilt the machine to get to the bottom and there is an electric pump that you can remove with no tools, you twist if out. after that is removed you should see what has clogged your pump.. I spent 4 hours disassembling my entire machine , cleaning it, trying to find out what was wrong. And the fix could of just taken me 1 minute.. Next time... But at least I know how to take everything apart now, very easy and simple machine to work on.
Posted on Apr 21, 2009
  • 51 Answers
SOURCE: Fisher and Paykel EcoSmart GWL15 Machine won't
It sounds like you need to re programme the machine.
With the machine plugged into the wall and turned on and the headset turned off this is what you do.
Push and hold down the start button, while doing that you need to then push and hold down the power button.
Hold them down for about 5 seconds, during which time you may a series of up to 3 beeps.
Then release the buttons.
Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle.
This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
Posted on Jun 14, 2009
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
beltronic205
  • 1467 Answers
SOURCE: The washer wont drain
Check clear filter //pump
Posted on Sep 29, 2009
SOURCE: I have a fisher paykel ecosmart wash cycle but when
Tip the Washer and check the hoses.... my husband just found 2 pennies stuck in one of the hoses in my F&P GWL15
Posted on Oct 04, 2009
Replaced water pump and control panel, have power, but just beeps.
Fisher and Paykel GWL11 Top Loading Washer
ths.gardenweb.com > Home Forums > Laundry Room
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... 4) (Rinse Phase) Drain the water, then lock the lid for spin. ..... I plug the power cord in and I have nothing on the control panel. ..... As the controller was only replaced early in January, I've flicked F&P NZ an email to see if it's still under ...
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesI removed the pump and control panel, found no blockage in the pump, so far ... Ihave just tried to fill my F/P machine but the water is just dripping in. ... I have aFisher Paykel washer have replaced the control module and now it .... washing machine MW612, stopped working and displayed beeping sound every second.
Jan 16, 2016 | Fisher and Paykel GWL11 Top Load Washer
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Won't spin gw608u
Fault code 41 if those are the correct lights. Service manual says faulty temperature thermistor & change the control module. Good luck with that as that model is nearly 20 years old and I don't think F&P supply that module any more.
May 02, 2017 | Fisher and Paykel GWL11 Top Load Washer
Will not spin only adgorates gw608u
Hi just read your post.Now your post has indicated the lights that are on while it is beeping are from LEFT to RIGHT are 3, 5, and 8.Is this correct.Please reply back if this is correct and it should not be hard to rectify Looking forward to your post,Lu
Jan 24, 2014 | Fisher and Paykel GWL11 Top Load Washer
Won't spin gw608u
You need to call a repair person. Or if the washer is still on warranty trade it in. This sounds like a problem from the factory
No power,not lighting up when start button pushed. unplugged and replugged several times. no good
is machine lighting up when power point is turned on ?if it isnt then control module is faulty. if it is and your power or start button dont work could b faulty keypad or faulty lid switch.please reply if u need more help
Mar 07, 2010 | Fisher and Paykel IWL12 Top Load Washer
Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Apr 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
After power outtage my f/p washer is dead -no lights nothing
Only reset is to unplug it. Are you sure you have power at the outlet? If you have 120V at the outlet the power surge may have blown the controller, not a cheap fix :(
Apr 12, 2009 | Fisher and Paykel Fisher & Paykel Washer
Fisher and Paykel IWL12 Top Load Washer Logo
159 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
