Question about Toshiba Satellite A60-S1561 Notebook
My Laptop Will not sleep on AC Charge
I have a Toshiba A200-1VO Equium, I have only just noticed that when the AC adaptor is plugged in and it is charging, that it will not sleep/go to standby, even if I click start and click sleep, I have to unplug it, close the lid/click sleep, wait for the standby light to go on, then plug it in again, I find it really annoying and will be grateful for a solution
  • danspy1994 May 23, 2009
    I have tred looking through these options for hours, I have even copied the exact settings from the battery settings, thanks though
    President:
  • 2,004 Answers
Go to Power options and do some adjustment.
Posted on May 23, 2009
  • 112 Answers
Try using Power Options in the Control Panel. Define exactly how you want laptop to behave with either battery or AC.
How do i test the power button on a toshiba equium l40 laptop
OpenControl Panel, Power settings, Advanced Power settings, change SLEEP to Never, Hibernate to never. Shut down and unplug, if you use mostly on AC, remove battery, your laptop when not in use. It will last longer, if there is a power surge not be damaged, and a reboot every day resets the computer.
Dec 26, 2012 | Computers & Internet
My Toshiba a200 laptop doesn't charge and when I charge the battery in another laptop then install it in my laptop it works and when I plug in AC adapter while the battery is removed the AC LED goes...
It look like you have another portable of the same type If you have the same problem trying your adapter on the other laptop it will be a good indication that the adaptor is deffective
Aug 01, 2011 | Computers & Internet
Lenovo laptop(8932) will go into a sleep like mode (you can still see the screen, very dim) when plugged into ac adaptor. Doesn't do it with battery power. Changed system board, power adaptor - no...
Good Day Psmith!
It looks like the AC adaptor is not making the right supply voltage needed for your laptop.
If you have a multi tester, you can test your ac adaptor to see if it has stable 20V voltage output supply needed for the laptop to make it work.
Set your tester to DC range. Plug the ac adaptor to your wall socket. Hold the other end of the ac adaptor (the one you connect to your laptop. Insert the red (positive) lead into the center of the adapter pin, then touch the black (negative) lead to the outside metal part of the pin.
Read the display in your tester. If the adapter is working properly, the meter should read between 19 to 20 volts of the rating. If the adapter is faulty, the meter will read below 18volts.
If that would be the case, I'm afraid you will need to replace your ac adaptor.
You can purchase online a replacement ac adaptor for lenovo 8932.
1. From this site, it costs $34.99 + $8 https://www.ebuybatteries.com/product/models/2_IBM-Lenovo-AC090W008T15_IBM+Lenovo+ThinkPad+R61+8932.htm
2. From this site, it costs $39.95 http://www.eznsmart.com/p-31667-lenovo-thinkpad-r61i-8932-laptop-ac-adapter-replacement-20v-45a-90watt-charger.aspx
Please accept my answer if this is the information you need.
Don't forget to give a four thumbs up rating!
Thank you for asking Fixya.
Jun 23, 2011 | Computers & Internet
The battery will not charge when the power is plugged in on my toshiba L305-S5021 laptop. Do I need a new battery or ac-adapter?
if the lap top works ok with the adaptor AC , so must to change the battery , find on ebay or amazon good prices
Aug 14, 2010 | Toshiba Satellite L305-S5921 Notebook
My toshiba equium A110-233 malfunction
try removing the battery and power adapter for a few minutes then plug in just the power adapter and boot up. then shut all down and put in battery and adapter and see if that helps.
Jan 02, 2010 | Toshiba Computers & Internet
Want stay charged
Sounds like a bad battery cause its not keeping a charge. Try a new or known good battery and see if it will charge and then unplug the ac adaptor to see if the laptop stays on.
If the laptop stays on with a different battery charged then your old battery is bad. If your laptop doesn't stay on with a known good or new charged battery without the ac adaptor hooked up then its a bad motherboard.
Feb 14, 2009 | Toshiba Satellite A100-S8111TD Notebook
Ac Adaptor not working??
as u said that when u plugged in the ac adaptor into the laptop it recognises that the ac adaptor is connected but it does not charge the laptop in this case what u can do is that if have the same charger extra then u can try with the another charger and if the other charger also does the same thing then in this case u need to replace the mmotherboard and if the other charger is working fine in this laptop then definately chage ur aac adaptor.....good luck...
thanks
Jan 25, 2009 | HP Pavilion dv6000z Notebook
Battery not charging
most probably you have an IC problem have a licenced repair man to check on it.
Dec 11, 2008 | Toshiba Equium 7100S PC Desktop
Toshiba equium A200 15i laptop power problem. The power adaptor jack is getting VERY hot and no charge is reaching the battery! what do i do?
You could buy a new universal power adapter and when you are running it off the mains remove the battery as it will continually charge and burn out.
Nov 03, 2008 | Computers & Internet
Troubleshooting with Toshiba Satellite A75-S211 Notebook
try more chargers, if posible one made for u;re model , so that u;ll know if the charger is the problem !
i susspect that not the charger gives u hard times but the computers power managment hardware/software .... U can try to open the computer, and look for burned, blackened, smoked, components (capacitors usualy), and if so change them (if possible)
Feb 20, 2008 | Toshiba Satellite A75-S211 Notebook
Toshiba Satellite A60-S1561 Notebook Logo
159 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
