Question about Ricoh Aficio 1035 Copier
Sc 545error when the machine start error sc545 is comming
  • 162 Answers
The thermistor must be dirty clean or replaces. Reset pressing total clear (yellow key) 107 and press and hold clear stop key (orange key) more than 3 sec the display change to service mode. turn the copier off and on.
good look.
Posted on Nov 15, 2009
  • Delfor Tomás Acosta Nov 15, 2009
    The thermistor can be out off position verifies.
Fuser error. usually can be reset by entering service mode then turning machine off/on (with red switch)
Posted on May 26, 2009
What are the steps to solve the SC545 error code?
SC:545 Fusing lamp overheat error (center)
Symptom: After the fusing temperature reaches
the target temperature, the fusing lamp
does not turn off for 12 consecutive
seconds.
Possible Cause:
• Fusing thermistor defective or out of
position
• Power supply board defective
Jan 31, 2011 | Ricoh Office Equipment & Supplies
Sc 545-00
SC545: Fusing overheat error 2
-Definition- [A]
The fusing lamp stays on at full power for 30 seconds while in the stand-by
condition after warming-up is completed.
- Possible causes -
· Fusing thermistor out of position
check/clean the thermistors
and ull need a service engineer to reset the code
Nov 25, 2010 | Ricoh Aficio 450 Copier
Ricoh 3045 printer stopped printing error code SC545
Hello, you´re found problem in the fusion unit. Clean the thermistor, and try again. Before try it, most reset the Sc code with service code....Good Luck!
Feb 08, 2010 | Ricoh Office Equipment & Supplies
Ricoh 1045 showing code SC545. First was SC 546 and now SC 545 can somebody help?
SC545 and SC 546 are fuser temperatyre error. pls. check thetmistor/ thermostats, connectors if thernistor are deffective replace thermistors. after replacement or checking of this parts do the SC reset. 107 # turn off copier then on after 5 sec.
Jan 26, 2010 | Ricoh Aficio 1035 Copier
This is the code on the mach sc 545
Hello sir; The code sc545 means fuser unit temperature too low it can be reset;
press "clearmode" "107" and thenpress and hold "clear/stop" key untill display "copy sp" show up, then turn power off and back on.
Apr 09, 2009 | Ricoh Aficio 2022 Black and White Copier
Fuction problem code SC545
You have a fuser problem, but sometimes it is just a false reading.
Try this:
press clearmodes, 1, 0, 7, and press and hold clear/stop, until the screen changes. Select 1, for copy SP. Select 7 for Data log. Scroll down to 7807. This will be SC/Jam counter reset.
Select it, and execute. Exit all the way back out. Turn machine off and back on.
May 12, 2008 | Gestetner DSm515pfd Digital Copier -...
Ricoh Aficio 1035 Copier Logo
224 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
