Question about Acer Computers & Internet
Aspire 9300/7000 series fails to charge the battery. I need a new motherboard or a properly repaired used one. Can this seventy- nine year young senior find a solution, for this problem
  • 8 more comments
  • stan172 May 23, 2009
    To the first part of your question: Yes, it works well with charger.
    The charger light is on! And the color light orange.
    Thanks
    Did replace the battery and it also failed!
  • stan172 May 24, 2009
    Cannot answer yer or no to the question if the charger light was green then turned to light orange. I just want to finf a repair shop who can address and correct this problem.
    Thank you,
    Stan172
    I shall try to have an answer for you on Tuesday. That's the best I can do.
    Stan172
  • stan172 May 26, 2009
    To answer your question: Installed the new battery and the color was light orange from the start and never changed. Meeaning when plugged in AC now the color in orange.
    Thanks
    Stan172
  • Frank Zhang
    Frank Zhang May 11, 2010
    please enter windows -->control panel -->power setting or managment-->meter check your battery how many % currently?
    or exist charging? or no charging?
  • Frank Zhang
    if you cant answer my question, so no solution offer because still cant make sure your battery is good or fake one.
  • Frank Zhang
    sorry how old the battery used?
  • Frank Zhang
    how ling the battery used? do you put back the battery when laptop turn on while can you see the battery lights turn green very shortly then to orange?
  • Frank Zhang
    could your laptop works ok use adapter without the battery ?
    and are you see the battery charging light on? whats color?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 381 Answers
Sir 1st check the charger DC output if the charger is OK the battery pack no charging u need to re-pack the battery pack or replace the battery...Thanks and Good Luck..
Posted on May 23, 2009
Braun series 3 no longer holds a charge. what can I do?
It is not that young anymore. The rechargeable battery is (almost?) dead. It is almost impossible to replace it. I once tried it, took me more than a day yo put everything together and still it never was as before.
I have bought a new Braun (799) and I'm convinced this one will live longer. The rechargeable battery in this one, you can shave one hour before you need to recharge it. It lasts a week with me, or sometimes even longer, before I have to charge it again.
Perhaps you just use the shaver with the power cord, like we used to do for 20 years, and start saving for a new one?
Oct 14, 2014 | Braun Series 3 Electric Razor Shaver 370cc...
My acer aspire 1 wont charge at all
Take a stiff toothbrush and clean the laptop battery terminals and the battery itself, sometimes dirt buildup will prevent proper connection. If this fails you may need a new rechargeable battery, especially if it's one to three years old or more, go to www.ebay.com Type make and model of laptop, refine search to battery.
Jul 07, 2012 | Computers & Internet
I have an Acer Aspire 7741Z-5731. I've had it for
If you changed your laptop battery and charger now nothing left to change. It could be problem related to you laptop motherboard.
On your laptop battery charging section not working properly. you can check you your laptop motherboard.
Jun 16, 2012 | Computers & Internet
When i remove the charger from my pc(acer aspire one zg5) the notebook just shut down, i was told that the battery is deadand must be replaced, so i want to ask if there is any way i can fix it again...
the problem you have can be one of two. 1 the battery is dead and needs replacing to use it without the charger plugged in 2 the charging circuit in your laptop has failed and will not charge the battery As the laptop works when plugged in then I would guess it's the battery. If the battery is dead, the only way you can repair it is to open the battery case and replace the individual cells which can be dangerous if you don't know how to handle the cells properly. I would recommend buying a new battery before trying to repair it if you really need one.
Jul 03, 2011 | Acer ASPIRE ONE ZG5 COMPATIBLE LAPTOP LCD...
Acer 5920 will not power up how do u test the battery. charger seems fine so not sure how to procide
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 24, 2010 | Acer Computers & Internet
Got new battery for acer aspire 6920. not charging
You ordered the wrong battery, theres two types, your original would have been 11.1v if you check the new one it will be 14.8v. They are not compatable.
Nov 19, 2009 | Acer Aspire 6920 Notebook PC
Battery fully charged but still shutting down when disconnected from mains
Find another battery it says like the one you have is faulty. If you try another known good battery and that fails just like yours then try a know good ac adaptor. If that fails, then its a problem with the motherboard not charging batteries properly but it really does sound like a faulty battery from my experience.
May 08, 2009 | Acer Aspire One PC Notebook
Acer laptop (aspire 5570z series) won't charge/turn on
I have the same piece a junk,the poor design of the power conector allows the barely soldered center pin to come out with the charging conector,mine lasted about a year,it was tight when it was new, have always been very careful with it and it still broke ,what a joke ,If you pull the pin out of the conector slightly then put it in slowly until you see the charge light go on in front of the computer,it wil charge
Jun 19, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acre Aspire -- 3000 series notebook -- Power adapter issue
It's a loose connection on the motherboard. The power connector on the motherboard will need to be re-soldered. You really don't need a new motherboard. You need to find a good Technician that can do this. I use to do this at my old job. We charged $65. Some places will charge up to $90 or so.
Jun 29, 2007 | Acer Aspire 3000 Notebook
Computers & Internet Logo
143 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
