Question about Kenmore HE2 Plus Front Load Washer
A wire ring came off
A wire ring, the size of the diameter of the opening of my He2 washer came loose. How do I re-attach
    President:
  • 331 Answers
Hi Bert,
That ring (it has a spring on it, right?) is used to clamp the outside of the rubber boot to the outside of the frame <--- where the door closes.
All you have to do is open the door and kneel down in front of the washer. Now, with clamp in hand, work it back into the groove around the outside lip of the boot. Here's the thing you have to know... That spring? It MUST be located at the 6 o'clock position! So when you are putting this thin back, just make sure the spring is located properly.
The reason? Frankly, I don't know. But the Kenmore/Whirlpool service repair manuals say so! So that's what I do, HA!
Anyway, If you don't replace that clamp and you continue running your washer that boot will dislodge from the front panel. Know what happens then? Call Noah, cause there's gonna be a flood.
Hope this helped you! If so, would you please be kind enough to rate me? Thanks!
SG
Posted on May 23, 2009
What would cause a Kenmore HE2 washer to turn off as the washer gets water/weight added to it.
check the wires under the tub. as the tub get weight in it it drops down a little bit it could be loosing or shorting one of the wires
Aug 28, 2012 | Kenmore HE2 Plus Front Load Washer
I push the reset button on the badger 5 unit nothing happen. The unit doesn,t make a sound when I try to turn it on.
These motors gradually slow up, and the slower speed causes motor to overheat.
Reset is supposed to detect high heat, but in any case, the motors go bad.
Used to be, there was a motor shop in town and they would rewind motors, but today we throw all the copper and metal into landfill unless old disposal is taken to recycle center and shipped to Bangladesh for dis-assembly and salvage.
Check that your wall switch has power, and that switch is good, and there is no loose wire.
Also check for loose wiring at disposal.
If reset is tripped out and won't reset, then disposal is bad.
Tips for installing new disposal:
Here are basic disposal parts:
1) Sink basket that connects to sink and is held with 3 screws from below.
2) Disposal body which connects to sink basket using metal ring.
3) Rubber washer between disposal and sink basket.
4) Dishwasher connects to upper part of disposal with a hose.
5) Electric wire coming from disposal switch connects to disposal near red reset button.
6) Tubular drain pipe connects to side of disposal
When I worked apartment maintenance, we replaced disposal with same size and brand disposal.
That way we didn't have to change out sink basket or move pipes around under the sink.
How to: Disconnect 2 nuts on p-trap and trap falls loose.
Using hammer and screwdriver, rotate steel connector disk that holds disposal to sink basket, and disposal comes off.
Before installing new disposal.
Attach electric wire to new disposal, black wire to black and white to white and ground to green screw or wrap around screw cover, and push in red reset button.
Attach dishwasher tube to new disposal. Knock out plug inside dishwasher opening.
Lift new disposal up into place, and attach to old sink basket.
There is a rubber washer between disposal and sink basket, Use new washer.
Connector ring catches at three points, all three have to connect.
You can use bottle jack to lift disposal if you have problem.
Re-assemble tubular pipe.
Image shows direction for connecting new disposal.
If this is your home, you want new sink basket that comes with new disposal because it looks shiny and new.
Buy a tub of plumbers putty also.
Remove 3 screws that hold sink basket, remove basket and clean sink opening.
Put finger-size roll of plumbers putty around sink opening, and then push new strainer basket into plumbers putty.
Tighten basket from below, wipe away excess putty around sink opening.
Install new disposal as described above.
Tips for tubular pipes:
When taking apart tubular pipes, start at p-trap and take apart as few pieces as needed to do job.
On image above, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Any tubular drain pipe that gets moved while working under sink needs to be disassembled, cleaned and re-assembled.
Metal pipes have rubber washer >> always use new rubber washers.
Plastic pipes have plastic washers > plastic washers can be cleaned and re-used.
Plastic washers have flat side that goes toward nut, tapered side away from nut.
When reassembling tubular pipe, we use rectorseal on washers and joints.
Slap a good amount on washer just before pushing washer in place and attaching nut.
Rectorseal will ensure tubular drain pipes won't leak.
Add a comment for more free help.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on disposal.
Jan 09, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Making a metal grinding sound when turns on but dont feel any forks or spoons in it
Garbage disposals can get noisy and sound like they're eating spoons instead of banana peel.
You can put vacuum hose in sink opening and see if something is in there.
As long as disposal disk rotates freely, and disposal is not shaking around and causing pipes to leak, then you can use it until it dies.
Otherwise, the bearing is probably rusted, or something is loose. Disposals rust out and eventually freeze, or the motor slows down and overheats, or they rust a hole and water leaks under sink.
Garbage disposal mechanism cannot be disassembled for repairs.
I wrote tips for replacing disposals that you can use when disposal gives out.
When I worked apartment maintenance, we replaced disposal with same brand and size disposal.
Rotate steel connector disk that holds disposal to sink basket, and disposal comes off.
Attach electric wire to new disposal, and push in reset button.
Attachment ring catches at three points, all three have to connect.
Remove old sink basket and clean sink opening.
Jan 08, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My Garbage disposal works and it turns but it sounds as if something is loose in there...it's the Insinkerator 5-81.....Is it possible the cutting blades are loose and if so, how do I fix this?
As long as disposal is not shaking around a lot, and causing pipes to leak, then you can use it until it dies.
Here are basic parts:
2) Disposal which connects to sink basket with metal ring.
3) There is a washer between disposal and sink basket.
4) The dishwasher connects to disposal with a hose.
Jan 04, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
How do you disassemble the Badger5 1/2 horsepower sink erator.model #5-81
The badger has two parts:
1) The sink strainer basket that attaches to sink with three screws visible from below.
2) The disposal which connects to sink basket with connector ring.
If you drop disposal loose from the sink, you can get spoons and other stuff out.
The disposal itself does not come apart for repairs.
I wrote tips for replacing disposal, which include information you might be able to use:
When I worked apartment maintenance, we replaced disposal with same brand disposal.
Push new disposal up into place, and attach to old sink basket.
There is a rubber washer between disposal and sink basket, use new washer.
On image below, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Jan 03, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My badger 9 disposal just stopped working. It is less than 2 years old. The blades turn freely, the reset button is in. It does not make any noise. Any other ideas?
1) Test disposal is getting electricity and switch is not bad.
Pull out switch so you can test wires:
Switch in ON position.
Use ordinary tester and test each brass screw to bare ground wire.
Tester should light up on each screw.
2) Next open wire connection at disposal and test & check wiring.
Be careful under the sink. Do not touch anything metal while working on live electricity.
Stay on completely dry surface.
3) In event of bad disposal, I wrote installation tips.
These tips do not include installing new disposal and taking old one back in same box as if it was a defective product.
Attach electric wire to new disposal.
Use new connector washer.
You might want to install new sink basket that comes with new disposal because it looks shiny and new.
Jan 02, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My kenmore he2 plus washer door gasket is loose.
it goes on the groove in the gasket at the door , the side view of the gasket would be a V, it goes right in the middle. make sure the gasket is first snug on the metal frame groove. the spring is very tight, start at top then work down, use a flat screwdriver to pry it in at bottom. it may help to wet the gasket
Apr 27, 2009 | Kenmore HE2 Plus Front Load Washer
How do you remove the washer drum to get a screw out?
your not going to be able to reomveth drum( not with out major expense and lotsa work, if indded you thikn theres a screw betwen the tubs you can removeth lower acess panel(3 screws across the front of unit). formther youll find a hose that leads fom the tub to the pump assy, its about 3 inches in diameter, this is the best acess to remove an item from between the drums. be aware it will be full of water so grab a towell, , UNPLUG!!!, and do be alarmed when oyou see a softball sized piece of plastic in th hose, its meant o be there and NEEDS to be there so dont removeit
Mar 15, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Front Load Washer
Thanks so much for these 2 posts. I had thought I lost my ring in my Kenmore He2 as well, but didn't know where it would be able to fit through to get out of the drum. After 2 months of hoping it would turn up, and many wash cycles later, we checked the drain plug & there it was!
Sep 14, 2008 | Washing Machines
Kenmore HE2 Plus Front Load Washer Logo
259 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
