Question about Sanyo Split System Air Conditioner
Cannot set a/c to operate automatically
Sanyo split system SAP121K, an older model with a wired remote control. I must leave the remote set to manual and the fan speed must be set manually. But then it has no automatic shutoff when correct temperature is reached, and will sometimes ice up the outside unit if it gets cold out at night. The "auto" setting does not work. What do I do? This unit came with a house I purchased. Thank you.
  • 10,865 Answers
Here is the sanyo link which will give you a manual once you enter the model number.
http://www.sanyohvac.com/docs.php
That being said, did you put new batteries in the remote? get back and let me know i want to help you.
Posted on May 23, 2009
    President:
  • 3,433 Answers
Sound to be in heat modenow. If you are after the cool mode, then if you have a cool setting and a heat temp setting, Lower the heat to almost off and set the cool setting to 74 degrees. See if the outside coils get warm. Make sure you are off manualo and n auto. If it runs, give it some time and the tenp of the outside coil will rise and the inside will get cold. Food Luck
I want to know that how mini split system automatic work? there is any thermostate or any other device?
Generally, they are operated by a remote control (similar to a television), although some units do have a wired wall control option as well. The indoor and outdoor unit has sensors that measure temperature (to control the operation of the mini-split) and (once the remote is set) the sensors control the system until it reaches the set point set on the remote.
Jul 25, 2016 | LG LS-K1830CL Cool Mini Split Air...
What is the code for a sanyo tv and how do I program it
If your TV is older than the URC-4220, the code should be 0154. (The universal remote generally can only control devices that were released about 6 months or more before the remote was programmed.)
To program the remote, turn on the TV manually. Then press the TV button on the remote once. Press and hold Set until the LED blinks twice. Release the Set button at that point. Enter 0154, check if the LED blinks twice again. If the LED blinked properly, point the remote at the TV and press Power. If the TV turns off, this is the correct code. If you take too long between steps, the remote may leave the setting mode. If the LED didn't blink, start over from pressing the TV button on the remote.
The manual for the One-for-All URC-4220 remote is available here: http://voxrightnow.custhelp.com/app/answers/detail/a_id/11828/~/programming-and-operating-the-oneforall-urc4220-universal-remote-control . Scroll past the directions for using and programming the remote to the link to the Owner's Manual. The list of codes starts at page 36.
I hope this helps.
CIndy Wells
Feb 10, 2015 | One For All URC4220 Remote Control
I have a Sanyo TV which is an older model and I have a RCA remote how to I program it??
RCA remote control have no set-up codes to Sanyo TV.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 17, 2014 | Televison & Video
Error c5
C05 error indicates no communication between indoor and outdoor units and remote control. Replace the remote batteries with fresh duracells first. If that doesn't fix the problem, verify the indoor and outdoor unit are wired together properly. If still no love, a tech will need to come visit. CALL SANYO TO SCHEDULE A TECH IF NEEDED. Mini-split units are new to the industry, and not all HVAC techs are good at fixing them.
Mar 30, 2014 | Sanyo Split System Air Conditioner
How can i program my remote control to operate my TV?
You will need to get a programmable remote. The one you have will not work.
Jan 26, 2014 | Televison & Video
I need a setup manual for the hype 4-in-1 universal remote control along with codes to a sanyo lcd tv
Common set-up codes for Sanyo band TVs are; 0291,0299,0295,0297. Try these codes. For more information check this link. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Dec 07, 2013 | Universal Remote Control Televison & Video
How do i set unit for moisture removal
there would be a button nameng mode on your remote control press it untill it shows dry mode now it will remove moiture from the room as long as it works in dry mode.
Jul 09, 2009 | Sanyo 12KHS71 Split System Air Conditioner
Manual Controls Insufficient
What is your universal remote control? if its not philips magnavox you try this universal remote control you will set the code match to your tv sanyo which you will see at the back of the instructions manual when you buy this remote control. follow the instruction of the manual on how to enter the code for tv. thanks.God bless you. i hope it will help.
Jun 11, 2007 | Sanyo DS20930 20" TV
Sanyo  Split System Air Conditioner Logo
347 people viewed this question
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Tim Whalen
Chuck
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
