Question about Netopia R3100 ISDN Router
ISDN router wont let up
My R-3100 Netopia ISDN router, when I run the smart wizard to set it up, keeps telling me I dont have DHCP enabled on my computer and it cant continue.  When I go to my LAN settings, it says DHCP is enabled.  I am stumped as to what to do, can anyone help?
  • 244 Answers
Hi loveyeshu,
Please try to remove first you network hardware from device manager, then installed it again.
Hope this is helpful for you to obtain the solution of your problem.
Best regards,
Posted on Oct 24, 2007
How do i enable DHCP on my router
The problem most likely is not the router problem since the router use DHCP as default setting.
Oct 25, 2012 | Zyxel Prestige 660HW Wireless Router...
How to instal
You'll wanna check out:
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
Feb 04, 2011 | NetGear WNR1000 Router
Unable to connect to DHCP server. getting 169.254 ip Have already tried the following: unplug/ reset reboot router; ipconfig /release /renew; Run MBAM Version 1.43; System restore to a date when connection...
Whew! Awesome troubleshooting work there.
When it's configured for DHCP, go to the Internet Protocol (TCP/IP) Properties and hit Advanced to bring up the "Advanced TCP/IP Properties" dialog.
Under the IP Settings tab, the top panel should be "IP addresses" and should have "DHCP Enabled" as the only entry, and the default gateway should be blank.
If both of those are correct, then I have one other question for you:
When you manually set an IP, are you able to use the network? If so, are you able to ping the DHCP server's address?
If so, then my guess would be that the DHCP server has a stale record for your Dell's MAC address.
Post back with the "Add Comment" button here and we'll get it working for you.
Jan 06, 2010 | Dell Dimension 3100 PC Desktop
Connecting a linksys wrt54g to a netopia modem
Is this an ISDN modem?
Generally: Netopia Ethernet out -> Linksys WAN port with a standard ethernet cable.
(Not the yellow LAN ports! - They are for your computers/printers.)
Dec 28, 2008 | Linksys Wireless-G WRT54GS Router...
this is not so much a soloution but an idea!
from memory the netopia devices allow you to configure a dmz device by IP or MAC address.
I have had to do something similar but with a buffalo unit instead of your linksys. I ended up having to place the buffalo unitin into a dmz created on the netopia unit. before VPN tunnles were formed correctly.
Nov 01, 2008 | Netopia 2247NWG-VGx Wireless Router...
Netopia DSL Router (DHCP Server) was giving address to connect to Internet
If this is a DSL Gateway Router, check the settings on the modem and make sure that the DHCP server is enabled.
it woould be of great help if you could provide the exact model number of the Netopia modem so that I could check if there is configuration page which you can access and check the settings..
Aug 05, 2008 | Computers & Internet
XBox 360 via wireless
Hi ServiTiendas
To resolve this issue you have to set DHCP client to automatic
Jun 24, 2008 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Netopia losses connection to internet and to server and vp phones
The Netopia Is a business-class router. Not clear from you question are you running Small Business Server or Windows Server 2003? If its the former, it has a wizard that will configure your LAN & the Netopia.
You can configure the Local IPs on the Netopia in the DHCP settings in expert mode.
The VP (VOIP?) phones are acting as a DHCP server & re-configure the network to their defaults.
Any 1/2 decent IT person (witth some real qualifications) could figure straiten this out...beware of "Techs"
Mar 04, 2008 | Netopia (3347NWG-VGX) Wireless Router...
How can i unlock my router?
Firstly... avoid showing your SSID (eircom-123456789) here, as the WEP key can be reverse engineered from the SSID.
To change your SSID, connect your router to your PC with an ethernet cable, go to your web browser (Intenet Explorer, Forefox, etc) and type, and press return.
This will open the control panel for the router.
Select 'EXPERT MODE' from the menu on the right, and accept the warning prompt. Then click on 'CONNECTION' and the 'WIRELESS' on the menu on the right.
In the main window you can then change the SSID for your network.
You can also change some of the other options in this window such as enabling closed mode, change security protocol, password, etc.
Feb 13, 2008 | Netopia 2247NWG-VGx Wireless Router...
Xbox 360
Either the network connection between the 360 and router is not working correctly, or your router is not configured properly for DHCP.
DHCP (Dynamic Host Configuration Protocol) is a protocol that automatically assigns a network address (and some other settings) to your computer....or Xbox in this case. It works like this....when your Xbox connects to the network, it sends out a broadcast packet on the network that looks for a DHCP server. If a DHCP server is present, it responds. Next the Xbox requests its network address and other settings from the DHCP server. Your WGR614 router has a DHCP server function built in, but it may not be enabled. Try reconfiguring the router using the Netgear "Smart Wizard" installation CD and be sure to enable the DHCP capability, if asked.
Jan 10, 2008 | NetGear WGR614 Wireless Router
Netopia R3100 ISDN Router Logo
57 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
