Question about Maytag MZD2766GES Side by Side Refrigerator
Frig side not working on Maytag MZD2766GEW
I have removed power for 5 min.
Ckd circuit breaker
Put hot water in the freezer portion
Still will not cool
Freezer side works proprerly
    Problem Solver:
  • 6 Answers
Freezer not defrosting. probably adaptive defrost board in fridge.
take panel off freezer (inside, back panel). if all frozen, can defrost with blow dryer. best to remove fridge control panel (inside, top of fidge). access adaptive defrost board, jump test to f1 (i think) next to test. this should initialize defrost mode. buy new board.
Posted on Jul 07, 2009
  • 20 Answers
Need to make sure the fan located in the freezer side is operating, also make sure your setting on the dial on refrigerater side is set to mid position. this two things allow air to pass to refrigerator side. last resort is it could be cool on freezer side but not enough to freeze,this is an indication of low on refrigeration.good luck!
Posted on May 23, 2009
What a mess. The instruction manual (really lacking in detail) does not have part numbers or model description. Excess moisture dripping in refirgeration portion of unit (top freezer; bottom...
Yes it could, you will have to check your defrost water drain, if its plugged defrost water won't go to condensate pan under unit, instead will make its way down to refrigerator section
Jun 29, 2011 | Maytag Refrigerators
We have a 5 yo Maytag side-by-side frig. A few days ago the frig started making a buzzing sound that happens every so many minutes and lasts a couple of min. Today it started dripping water from the port...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Maytag Refrigerators
No hot water. Circuit breaker not the problem. Which plate do I open to check the eco?
Remove access panels on water heater's side the top thermostat has a red reset button on it.
Press reset button and it will take about 30 mins or more to get hot water. If you have a meter or test light check wires to elements for power.
This would be the first thing to check on the water heater.
May 21, 2010 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
We have a 8 year old Maytag Side by side model MZD2766GEW and the fidge side doesn't stay cold, just cool. The freezer works fine and there isn't any frost. Any idea what we need to do? Thank you, Greg
For those who had the control board replaced or are experiencing the frig side warming while the freezer side continues freezing; The problem may (still) be a faulty control board. I fixed the issue by replacing a $1.00 capacitor on the board. I'm not a techy and it wasn't too difficult to solder. More info on what to do here; DIY Chatroom
In the mean time, there is ice forming behind the back panel in the lower section of the freezer. This blocks airflow to the frig side.
I use a pump pressure garden sprayer with hot water to defrost the coils. Gets the job done in 20 minutes and I don't have to worry about defrosting items in the freezer.
Jul 17, 2009 | Maytag MZD2766GES Side by Side...
Frig not working but freezer is
check and make sure you dont have frost on the back wall of your freezer on bottom and make sure fan is working
Dec 29, 2008 | Maytag MCD2257HES Side by Side...
Dometic 2652 runs sparatically, then quit
If the burner area is geting hot its has a leak
Dec 11, 2008 | Dometic RGE400 Top Freezer Refrigerator
Frig side by side problem
I rolled the frig forward enough so I could unplug the power cord from the outlet. Then
I removed the freezer back panel and found the evaporator coils completely encased in frost. I used hot water in a 20 ounce sqeezable water bottle to remove the caked frost from the coils. I used the back panel as a chute to route the water into a large square bucket I placed on the floor right in front of the freezer. I then disconnected the defrost heater and checked continuity with my meter on the Rx1 scale. Meter needle did not move when connected across the heater indicating that the heater was bad. Called the local parts supplier and gave them the numbers off the old part. They had it in stock for $27.31 so went and picked it up, plugged it in, put in the mounting screws, replaced the freezer back panel, and plugged the frig in. I turned both the freezer and frig thermostats to their normal position. Four hours after my better half got all the food back in the freezer and the frig, the temperature in the refrigerator was 36 degrees.
Feb 28, 2008 | GE GSH25JFR Side by Side Refrigerator
Defrost Problem
there is a drain in the middle of the defrost water collector and it is probably blocked - usually with ice. dry ot the tray and put very hot water in to melt the ice. you may have to do several times. do this until water flows away freely
Jul 25, 2007 | Maytag MSD2756G Side by Side Refrigerator
Maytag refrigerator Model MZD2766GEW
Check the evaporator fan motor located abocve teh cooling coils in the freezer side.
Jun 05, 2007 | Maytag MZD2766GES Side by Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
491 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
