Question about Mtd 22" Yard Machine Push Mower
Lawnmower wont start
I have a Yard Machine by MTD , changed spark plug and it still wont start, what next
  • 22 Answers
Possible Causes Corrective actions
Unit will not start Control handle is not engaged Engage control handle lawnmower wont start - spacer.gif spacer.gif
Spark plug wire is disconnected Connect spark plug wire spacer.gif lawnmower wont start - spacer.gifmg src="http://i.fixya.net/uploads/images/spacer.gif" alt="spacer.gif" class="h_mi" />
Fuel tank empty or stale fuel Relawnmower wont start - spacer.gif clean, fresh gas spacer.gif lawnmower wont start - spacer.gif
Blocked fuel line Clean fuel line lawnmower wont start - spacer.gif="http://i.fixya.net/uploads/images/spacer.gif" alt="spacer.gif" class="h_mi" /> spacer.gif
Faullawnmower wont start - spacer.giflug Replace, clean, or adjust gap spacer.gif
Air filter filled with dirt or debris Replace or clean air filter
Posted on May 23, 2009
  • 121 Answers
You can make sure your carburater is clean. Clean the filter. Some time you can get a enpty coffee can and pour some gas in it and rinse the filter out repeatedly. Check the oil also that should get you back on the green..............: )
Mtd gold lawnmower wont run
Try changing your spark plug!!! Mine wouldn't start for weeks and changed the spark plug and it worked! 12_4_2013_4_38_26_pm.png
Dec 03, 2013 | Garden
Wont start
Since you changed the spark plug, you obviously know how to get it out. Take it out again, and install the spark plug wire back on it. Now, hold it with an INSULATED pair of pliers or channel locks. Hold the spark plug against the head of the mower, to ground it out, and have someone pull the start rope and see if there is a spark arcing across the end of the plug. If not, remove the plug from the wire, and gently insert a round tip screwdriver (like a phillips head) into the spark plug wire. Now, hold that screwdriver withing an 1/16 inch from the cylinder head of the mower. Have someone pull the rope to start it. If you get a spark between the screwdriveer blade and the cylinder head, you are good for that. Then, you have a fuel problem.
What most usually happens is, the gasoline evaporates in the carburetor after a few weeks of sitting, and turns to a gummy deposit. Then, it will no longer work until it is cleaned out so gasoline will flow through it.
2 solutions. One, start and run the mower every 2 or 3 weeks to keep it from gumming up. 2, add a gasoline additive that will keep that from happening. Stores have lots of additives, but I don't know of the name of one that is exactly what you need.
Be blessed.
Jun 24, 2013 | Mtd 22" Yard Machine Push Mower
2008 mtd lawnmower tries to start when sprayed with carb cleaner but stops after 3 seconds
If the spark plug is in great condition, remove and clean the carburetor. This will require soaking if needed with a good solvent or carb cleaner and compressed air to blow out the tiny passages that are clogged for the idle jet circuit and high speed circuit.
Apr 29, 2011 | Mtd 22" Yard Machine Push Mower
Lawnmower won't start
Remove the bowl from the carb. and blow it out with air.
May 07, 2010 | Mtd 22" Yard Machine Push Mower
What is the spark plug gap on a 4.5 HP 21" cut
With out the model # of engine or plug not 100% certian but 99% of those mower engines run a .8 or .9mm plug gap you will be preety safe setting it at that
Regards
Brad
Feb 05, 2010 | Mtd Products Yard Machines 158CC Tiller
Need a spark plug size for a yardpro self propelled lawn mower model number yp6y22cha briggs and stratton 6hp
If your mower does not have "OHV", overhead valves. You can use a Champion j19lm spark plug.
If you discover you do have overhead valves; A Champion RC12YC, will work.
Apr 28, 2009 | Mtd 22" Yard Machine Push Mower
Mtd 22" Yard Machine Push Mower Logo
1,236 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
