Question about Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Ultimate Care lsw9750pw3 wont agitate or spin
After filling with water nothing happens,you sugessted replacing door swith if not then timer, I relaced both and same problem, washer is 2 yr
old. Cannot hear timer running as my friends with same model. Reset switch does nothing
  • steve
    steve May 11, 2010
    Your water level switch is not sending power to the timer.
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
I have a Whirlpool Ultimate Care II washer. It fills and agitates but it will not drain or spin. When it hits the spin cycle it sounds like a timer is going off but nothing happens. Does anyone have any...
The only thing I can think of for this is a worn coupling for the motor. Does the noise sound simmilar to a grinding sound? if thee is no noise from the motor then I would suspect the timer. I have had both of these go out on me and they seem to be common problems. I hop this helps.
Nov 11, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Does not spin or empty
it might be jammed or there might be dirt or some sort of a clog. I would suggest you clean it out.
May 29, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool washer stoped after the agitate cycle
If it fills with water, agitates then stops still full of water (even if you manually advance the timer), you have a bad lid switch. This is an inexpensive repair, or even a do it yourself project.
May 19, 2009 | Whirlpool Washing Machines
Stuck in spin
Hi!
If the Washer is stuck in spin then either the timer or a cold-water supply problem is causing this :
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance, then you need to replace the timer.
Do rate the solution as FixYa and revert for further clarification.
Thanks
Rylee
Apr 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer wtw5200sq0 fills with water and stops. no agitation - no sound -- replaced timer but nothing
instead of timer soinds like a faulty lid switch, the unit not recognizing the door is closed so will only fill with water
Feb 21, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Will fill water but agitator wont run.
Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
WATER FILLS AND DRAINS BUT DOES NOT AGITATAE OR SPIN
motor coupler is goingto be the issue, easy enough to replace, you can find a video on you tube, search "whirlpool motor coupling"
Jan 25, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
No agitation on any cycle.
Check out the posting for replacing the agitator dogs. They are usually located inside the agitator under the fabric softener dispenser.
Apr 17, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will fill but won't "wash"
what kind of click are you hearing like a timer advancing or a hum them a click about every 10 minutes and dont rate me yet till were done
Jan 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Calypso GVW9959K Top Load Washer Logo
165 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
