Question about Syntax LT30HV 30 in. HD-Ready LCD Television
Screen is black, and then turns blue for a sec when you turn off
Ok, here is the issue. I got this tv from my uncle to see what I could do to fix it. So the screen is black he said there was sound and when you turn the TV off the screen will turn blue for a second and then goes off. I have done some research on line and most people have discovered that the inverter board has gone bad, but none of them ever mentioned that the screen would turn blue when the TV was turned off. I ohmed all of the Transformers on the inverter board and the ohmed out correctly. I don't think this is the problem. do you have any possible suggestions what else could be the problem?
  • 11,361 Answers
Verify that for sure you do not have open winding on the seconday side of the inverter transformers (this is a common failure), also check all the surface mounted fuses on the inverter board.
Power supply filter capacitors look OK, no bulging tops?
Posted on Oct 29, 2009
Why does it turn from blue to black after 10 sec.?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
Dec 15, 2015 | RCA Televison & Video
HL32V86 Hisense 32' stuck on standby wont turn on it seems screen stay black
Call the HiSense tech dept. You can find the number on line and they will tell you how to fix it or you can try using the remote and go to settings and see if you can fix it that way. Also the manual for this tv should be available online as well.
Jan 03, 2015 | Hisense Televison & Video
My Philips 50PF7321D/37 TV picture turns blue after about 30 secs of being on and I cant seem to get it to stop. Also when I turn the TV on it has a black screen with sound for about 15 secs before it
Unplug both the set and a box or receiver if used with the set, remove from power for several minutes and replug all to see if a reboot will help or not.
Dec 09, 2012 | Philips 50PF7321D 50 in. Plasma HDTV
Problem with Panasonic PT-53WX54J 53 in. Rear Projection HDTV Television - Green Screen
You may have a component failing in the red drive stage possibly the blue as well or even the quadrature stage. A can of cold shot should help narrow the search considerably. It is also possible the red and blue projection tubes are nearing the end of their service life as well. If you have the means to test the tubes themselves, check the red and blue tubes for gas.
Dec 19, 2011 | Panasonic Televison & Video
Turns on for 30 sec then goes bright blue and goes back into standby. turn back on it does it agian
This is blue CRT problem in tv as it is rear projection tv that has three CRTs red-green-blue inside to project color picture on front screen.
Blue CRT (tube) will be replaced to fix the issue and it is job of Pro because lots of adjustments are required after replacement of tube.
Local tv repair shop will help you for that.
Thanks
Oct 02, 2010 | Sony KP-51WS500 51" Rear Projection...
KP57WS500 Screen turns Blue and then shuts off. Can this be fixed?
Hi Friend,
Please folliow the below steps one by one
Step 1: Turn on the TV
Step 2: Hold the ON/OFF Button for 10 to 20 Secs
Step 3:Without taking the hand from the ON/OFF button unplug the power cable connected to the wall outlet from the TV
Step 4:Without taking the hand from the ON/OFF button put the power cable back to the outlet
Step 5:Now take the hand from the ON/OFF Button and try to turn it ON again and check
Even after that you are facing the same issue please check with the Display Card in the TV,
If you have any Clarification please feel free to contact us
Regards,
Ayyasam
Apr 03, 2010 | Televison & Video
Tv takes to long to turn on and screen resizes
sounds like a power supply issue. partstore.com might have a power supply for this tv
Mar 18, 2010 | Sony KDS-R50XBR1 50" HDTV
When I turned on TV, sound was ok, but there's a black screen
Same thing happened to me. I turned TV off. Then turned it back on holding down both On button & Source button & got the picture back. Doesn't fix it for good. But when it happens, I "fix" it the same way. Happened twice in last three weeks, I'd say. Better than junking it for now.
May 10, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
Syntax LT30HV 30 in. HD-Ready LCD Television Logo
174 people viewed this question
Top Syntax Televison & Video Experts
Computer Repairing
Computer Repairing
Kolbrun...
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
