Question about Whirlpool ED5FTGX Side by Side Refrigerator
Mold in water dispenser tube
How do I get mold out out the water tube that guides the water into our cups. I have a Whirlpool side by side wtih water & ice dispenser in the door.
  • Whirlpool Master
  • 4,655 Answers
Your refrigerator has a filter system below the bottom and behind the kick plate. Two or three times you need to turn the water supply off to refrigerator and fill the old filter with clorox to kill the algae growing in the storage tank and after you finally get this out and purge the chlorine from system will you be able to use the ice or water to consume. I know this seams harsh but really there is very little else that can remove this without changing the whole water system. Once this is done change the filter regularly and this will help, click on link below and place your model number into the model search feature. This will give you pictures of the parts and there location. Let me know how this goes, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 24, 2009
Whirlpool Gold side by sideGC3PHEXNS00 not making ice but the water works. Already replaced the filter.
put your finger in the ice mold and see if there is ICE in the mold. if no ice then use a turkey baster and put approx 1/4 cup of water into the ice mold, slowly. in about 2 hrs you should hear ice drop and then refill with water. if there is ice in the mold, you most likely need a new ice maker.
Jan 02, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hello i have kemore he2 washer after a load is done the softner slot of the washer has water in it any ideas.
Hello, W/D here.
Remove the dispensing tray and take it to the sink. On the under side of the tray are molded in caps that fit over tubes at the washer. Clean the caps out well. A Q tip works well for this. Also clean the tubes on the inside and outside at the washer.
The way it works is you put the softener in the cup, up to the line. When the washer is ready to dispense the softener, it begins to add water to the cup, raising the level. As the level overflows the cup, it passes under the cup and into the tube, creating a syphon effect, drawing the softener out of the cup. When the level in the cup falls below the level of the cap, the effect is broken, and no more will be drawn into the washer. That's why there is usually a little water left in the cup. Cleaning the cups and tubes allows for more of the water to be removed.
Best regards, --W/D--
Mar 07, 2011 | Kenmore 46462 Front Load Washer
I have a Whirlpool model # ET1CHEXVB00 refridgerator. I just (few minutes ago) replaced the ice maker valve because water was no longer getting to the icemaker. Very shortly after I plugged the...
Sounds like the fill tube at the ice maker is either out of alignment or has a crack in it.
The water supply line from the water inlet valve enters the rear of the freezer and releases the water into a large diameter fill tube. The fill tubes hangs above the fill cup which funnels the water into the ice mold. If the fill tube and fill cup are improperly aligned, water may spill out instead of going into the mold.
Nov 24, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a Whirlpool refrige. side by side and the ice maker has stopped working. The infrared light keeps blinking. I have unplugged it a couple of times as well as turned the infrared off. Any advice?
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig
Sep 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Replace selenoid and water is still not going to ice maker
Did you pour about 2/3 cup of water into the icemaker and did it dump ? If you did pour water into the icemaker , and it did not dump the cubes , then the icemaker is bad . If it did dump , so you replaced the water valve , then the fill tube directly at the icemaker is frozen with ice . It will need to be removed ( fill tube at icemaker ) and the ice cleared out by hot water . On some models , behind the refrig , 2 screws hold the fill tube in place . Remove the tube , and clear the ice . When reinstalling , have someone guide it from inside the freezer , to where it mounts on the icemaker fill cup .
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool gold ice maker not filling with water to make ice
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
KitchenAid Refrigerator water tube needs replacing
Visit my site, I offer free help and model and parts number search feature. Movies and instruction manuals for most brands. seanreezehvac@yahoo.com click on link below, Thanks, Sea Breeze
Please send me your model number so I can give you better instructions. Clorox in the water supply and waiting until the Clorox is cleared from water dispenser and Ice will also do the job!
Apr 04, 2009 | Refrigerators
No ice
pour some water in the ice mold and see if it will kick out a batch if it does get a water valve. If ice is already in the mold then replace the ice mold thermostat. If this is a newer ice maker get a hairdryer and make the mold rotate around. This sometimes gets the newer ones back on track.
Dec 05, 2008 | Whirlpool GD5SHAX Side by Side...
Whirlpool ED5FTGX Side by Side Refrigerator Logo
739 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
